Inside Rearview Mirror #2383073
10/06/17 06:39 PM
10/06/17 06:39 PM
KY
DougR Offline OP
DougR  Offline OP
KY
The glass in my 1969 Barracuda convertible inside rearview mirror is cloudy. Looking for a new one, it appears you can only buy a complete mirror assembly, and the convertible model is somehow different than a hardtop model. No one seems to offer a convertible model. Does anyone offer a new convertible style, or alternately, can I buy a hardtop style and remove the mirror part from the stem and put it on mine? It is in good shape.
Re: Inside Rearview Mirror [Re: DougR] #2383080
10/06/17 07:04 PM
10/06/17 07:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the rest of the mirror is OK, just the mirror glass can be replaced....check with a local auto glass shop.
Re: Inside Rearview Mirror [Re: DougR] #2383405
10/07/17 01:39 PM
10/07/17 01:39 PM
If someone locally or a yard has a common hardtop model that you could checkout to see if its glass will fit. A glass shop might handle it but a custom cut would likely be pricey. Tell em to treat it like it is a priceless artifact (no scratches) but that for sure wont make your final bill likely be any cheaper!.
Re: Inside Rearview Mirror [Re: DougR] #2383427
10/07/17 02:18 PM
10/07/17 02:18 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I had a local glass shop cut me a replacement mirror for my 1972 Chrysler New Yorker. They charged me $7.00 dollars total. I removed the glass so they could use it for a pattern. The original mirror (which I saved) is day/ night glass. The replacement mirror doesn't have that function. I would need to send the original glass out for re-silvering.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Inside Rearview Mirror [Re: FJR doc] #2384223
10/09/17 01:05 AM
10/09/17 01:05 AM
KY
DougR Offline OP
DougR  Offline OP
KY
I don't have anything to compare it to. I will check out the glass shop option.
Re: Inside Rearview Mirror [Re: DougR] #2384466
10/09/17 02:47 PM
10/09/17 02:47 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Looks like the best option to me and was not addressed.
Simple Allen head screw is it not?
I would think that it will bolt (screw) right on your post.
I have mechanical Aptitude.
I can screw up anything.
