Key stuck in ignition in key on position #2382992
10/06/17 03:14 PM
10/06/17 03:14 PM
Suffolk County, New York
1mean340 Offline OP
1mean340  Offline OP
Anyone know of any tricks to free it before I take apart the column? No lockout button I could see on the column. Tried tapping it with a screw driver, wiggling it in all different directions, turning the wheel etc.. but couldn't get it to budge. Ignition cylinder will turn to start from where it's at but can't get it back to off to pull the key out.
Re: Key stuck in ignition in key on position [Re: 1mean340] #2383032
10/06/17 04:48 PM
10/06/17 04:48 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
what car?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Key stuck in ignition in key on position [Re: 1mean340] #2383042
10/06/17 04:56 PM
10/06/17 04:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried turning the shifter collar on the column or the collar other than the one the key is in?
Re: Key stuck in ignition in key on position [Re: 1mean340] #2383047
10/06/17 05:04 PM
10/06/17 05:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If it is a 1970 model, adjust your lockout linkage.
If it is a 1970 3 speed or 4-speed manual transmission car, the key only comes out with the gear selector in reverse when the lockout linkage is adjusted right.
