Re: Plugs and plug wire recommendations needed [Re: MR_P_BODY] #2383344
10/07/17 11:30 AM
10/07/17 11:30 AM
michigan
turbo toad Offline OP
michigan
Originally Posted By MR_P_BODY
[quote=turbo toad][quote=FastmOp]
Where are you at in Mich
wave
Just south of Jackson about 5 mins from MIS I grew yp in wayne county.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383345
10/07/17 11:32 AM
10/07/17 11:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
51515... 51515R is the race filter and it
flows more but has less filtration
wave
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383373
10/07/17 12:47 PM
10/07/17 12:47 PM
michigan
michigan
I had to download a app to downsize a couple pics
The car has come along way in the last year
Swaped to big bolt pattern disk
Dana60 swap with disk brakes.
Mini tube
Anti roll bar installed
Upgrade the roll bar to a 10pt cage with funny car add on
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383376
10/07/17 12:53 PM
10/07/17 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Who did your headers.. nice job
wave
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383377
10/07/17 01:00 PM
10/07/17 01:00 PM
michigan
michigan
Mr P everything was done by me In my 2 car garage expect tig welding alum I got a friend to do it as I haven't tired my hand at it yet.
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383379
10/07/17 01:04 PM
10/07/17 01:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Nice job on the headers
EDIT
yeah I use to do all my work out of my 2 1/2
car garage till I leveled it and built a
larger shop a few years back
wave
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383384
10/07/17 01:10 PM
10/07/17 01:10 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Very nice setup.
[image][/image]
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383386
10/07/17 01:13 PM
10/07/17 01:13 PM
michigan
michigan
Thanks Mike
Yah a pole barn/shop is next on my list of things to do. I'm over rolling around on the ground and ive out grown my working space with the equipment needed to tackle a job like this. Its probably been the worst part of this build.
Re: Plugs and plug wire recommendations needed [Re: sgcuda] #2383393
10/07/17 01:24 PM
10/07/17 01:24 PM
michigan
michigan
Originally Posted By sgcuda
Very nice setup.
Thank you
Here's a couple pics during the mock up stages
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383403
10/07/17 01:37 PM
10/07/17 01:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By turbo toad
Thanks Mike
I know what ya mean.. I built the place I have
now and built it the way I wanted.. it has in
floor heat which is really nice.. I also have
a mill and lathe in there along with a 10 ton
hoist.. I also have a large sand blaster and
a bunch of other things.. I sold off my tubing
bender that I used to build chassis's since I
quit building them now days... when you do build
just make it BIGGER than you want.. they are NEVER
big enough
wave
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383767
10/08/17 10:41 AM
10/08/17 10:41 AM
michigan
michigan
Mike it sounds like you set your shop up about like what I had envisioned mine could be, except Id like a paint booth at one end of the building. Maybe one day I can make it a happen.πŸΈπŸΈπŸ‘Œ
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383777
10/08/17 11:12 AM
10/08/17 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a temp paint booth in my shop when I was
painting my Rampage.. but to me a paint booth
isnt worth the time.. you only use it once in
a great while
wave
