Page 1 of 4 1 2 3 4
Winter upgrade plans, what are you guys( and gals) doing #2382508
10/05/17 04:27 PM
10/05/17 04:27 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I just bought a very nice Cope built 904 for my Dart. Will buy driveshaft and convertor to complete the swap from the 727 over the winter.
Also going to paint and install a hemi Dart hood and remove the flat hood without scoop on the car currently.
I might be a bit too high on expectations, but my hope is these changes might get this thing to dip into the 10's in good air.
The current convertor is way off from where it should be. I have whittled 8 tenths in ET off this thing this season, and the 60 has remained identical. So my hope is i am leaving a TON on the table on the convertor front alone.
Also having this hillbilly cage cut out the rest of the way and a proper 8 point installed.
One more outing left this week( not going to be good air) then season is over for me
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382529
10/05/17 04:55 PM
10/05/17 04:55 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Aren't you going to the Halloween Classic
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: pittsburghracer] #2382531
10/05/17 05:02 PM
10/05/17 05:02 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Own a business. Can only go to some, not all. Norwalk for the Classic is my 4 days of playing hooky.
We are gone all of January, thats becone more important to me than racing at this point in my life.... lol
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382600
10/05/17 07:11 PM
10/05/17 07:11 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Getting your HIP fixed should be your biggest upgrade screw all the rest of the stuff
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382609
10/05/17 07:37 PM
10/05/17 07:37 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Your car should like the 904, mine did. I changed from a 727 to a low gear 904 and it picked up 3mph in the 1/8th. The scoop will help too, especially if you seal it off with an air box. I have another low gear set cheap if you’re in the market.
This winter’s projects for me are to lose another 100 - 150 lbs, and focus on the rear suspension. Move the springs mounts into the frame rails, install 25” front spring segments, mount the shocks straight up (maybe move to the front of the axle), and sliders.
Cheers.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382678
10/05/17 09:34 PM
10/05/17 09:34 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Working on losing 25-30 lbs, already down 10. Newest in my checklist is to get a new set of pistons. Hopefully, make some serious headway with the rest of the car.
[image][/image]
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382695
10/05/17 10:03 PM
10/05/17 10:03 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I'll be working as many hours as I can get at work. Have paint supplies, a couple wanted items to buy for the car, and would like to get a HANS device.
69 GTX 68 Road Runner
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382709
10/05/17 10:29 PM
10/05/17 10:29 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I think you'll really like that 904. A833 will always be my favorite Mopar transmission but the 904 in our Dart kicks ass.
Husband has already started body work on the '65 Dart in preparation for paint next year. It's going to look absolutely horrible for the Halloween Classic but oh well, I'm still racing it. LOL.
Still debating whether to go with a flat hood or a hoodscoop.
And the Edelbrock heads will get some porting done, they haven't been touched yet.
And next week we're trying a 950 Holley on it and see if it likes it better than the 750.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382744
10/05/17 11:11 PM
10/05/17 11:11 PM
fullmetaljacket Offline
This Winter, I plan top get the car on the scale and go from there.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382757
10/05/17 11:41 PM
10/05/17 11:41 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have a few projects for the winter, I am not sure how many will get done.
Finish my Dana Swap(just need to get off my rear and put it in)
I am swapping to a Tunnel Ram with Dual 1000CFM Throttle bodies, I have a Holley Pro Dominator W2 tunnel ram being converted over to EFI as we speak.
Possible swap to a 904 or low gear 904 from 727
Hood Change, lose the heavy stock hood in favor of a six pack scoop. Suprisngly the tunnel ram would work with the stock hood but it would not have room for an air cleaner and I need that fresh air intake. The tunnel ram is coming first, I am not above driving around with no hood lol.
Install Flex Fuel sensor and maybe try E85
I had the intake off to inspect the lifters so I mocked up the tunnel ram before sending it off.
EDIT, I do not know why the pics I upload show up sideways? At least it shows up that way on my end.
68 Barracuda Formula S 340
87 "Chrysler" Conquest
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382773
10/06/17 12:04 AM
10/06/17 12:04 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Lost my mind and bought the Buzzin' Half Duzzin' car from Mike Jeffrey on his retirement sale. I pick it up next spring. Have everything to put it back together. It's been sitting 10 years, what can possibly go wrong?
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: slantzilla] #2382783
10/06/17 12:41 AM
10/06/17 12:41 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Got any pictures of her. What has it run before?
Are the Cox brothers still around?
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382794
10/06/17 01:15 AM
10/06/17 01:15 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Finally wking on my Cuda again. The 30 yr old cage is being removed and replaced. Have a new tubular kframe to install and hopefully get one of my old short blocks back together. No real rush as I have my wagon to play with for now.
Ok
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382798
10/06/17 01:32 AM
10/06/17 01:32 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I may have some pics on my home computer.
Mike had it running consistant 10:50's on spray, best was 10:05. I plan on putting it together as just a nice, reliable, slow Pro bracket car running mid 12's or so.
The Cox boys are still kicking, but they haven't really raced since they crashed tbeir '66 at the Nats years ago.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382807
10/06/17 01:53 AM
10/06/17 01:53 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I’m low on funds this year, but my plans are a 6pt roll bar (currently a no-bar car) and reinforce the torque box area. Hopefully I can find enough with tuning the existing combo to offset the added weight and be right back where I was last year performance wise, but have the car set up to handle more punch in the future.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382810
10/06/17 01:58 AM
10/06/17 01:58 AM
MI
MI Mopar Works Offline
MI
Pull weight out and change converter.
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2382828
10/06/17 02:46 AM
10/06/17 02:46 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Converter adjustment. Maybe go through the trans. Try and shave 150-200 pounds off the car.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: Wookie316] #2382964
10/06/17 02:14 PM
10/06/17 02:14 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I already did the hood swap on the challenger due to a little mishap @ Milan. I was thinking about a cam upgrade But I picked up a more door Dart so I'll be working on that. wrench
Install my old 340 with a 904, the car is a pushbutton car so I'm looking to keep that if I can find a v-8 pb 904. drive It also needs a rear axle swap, 8 3/4. Frame connectors. Oh yea and change the bench seat to buckets.
Wife want the car ready for spring, I think I have my hands full panic
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2383000
10/06/17 03:23 PM
10/06/17 03:23 PM
Cochise Co, Az, From Detroit
moetown Offline
moetown  Offline
My plans are to finish car so it is ready by January.
Finish updating roll cage and get it recerted 25.1G.
Finish bodywork and paint cage and body.
Setup car for my BBC and glide combo, was setup for hemi.
Build headers for BBC.
Add all wiring and plumbing.
Finish wheelie bars.
Setup 4 link.
I'm planning on it being done by January, but might not be done until MATS.
Re: Winter upgrade plans, what are you guys( and gals) doing [Re: B3422W5] #2383005
10/06/17 03:34 PM
10/06/17 03:34 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looking for sponsors.
Page 1 of 4 1 2 3 4
