Winter upgrade plans, what are you guys( and gals) doing
#2382508
10/05/17 04:27 PM
10/05/17 04:27 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
I just bought a very nice Cope built 904 for my Dart. Will buy driveshaft and convertor to complete the swap from the 727 over the winter. Also going to paint and install a hemi Dart hood and remove the flat hood without scoop on the car currently. I might be a bit too high on expectations, but my hope is these changes might get this thing to dip into the 10's in good air. The current convertor is way off from where it should be. I have whittled 8 tenths in ET off this thing this season, and the 60 has remained identical. So my hope is i am leaving a TON on the table on the convertor front alone. Also having this hillbilly cage cut out the rest of the way and a proper 8 point installed.
One more outing left this week( not going to be good air) then season is over for me
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Winter upgrade plans, what are you guys( and gals) doing
[Re: B3422W5]
#2382529
10/05/17 04:55 PM
10/05/17 04:55 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Aren't you going to the Halloween Classic
[Re: pittsburghracer]
#2382531
10/05/17 05:02 PM
10/05/17 05:02 PM
B3422W5
Portage,michigan
Aren't you going to the Halloween Classic Own a business. Can only go to some, not all. Norwalk for the Classic is my 4 days of playing hooky. We are gone all of January, thats becone more important to me than racing at this point in my life.... lol
[Re: B3422W5]
#2382678
10/05/17 09:34 PM
10/05/17 09:34 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Working on losing 25-30 lbs, already down 10. Newest in my checklist is to get a new set of pistons. Hopefully, make some serious headway with the rest of the car.
[image][/image]
[Re: B3422W5]
#2382695
10/05/17 10:03 PM
10/05/17 10:03 PM
Posts: 10,020 MN
JERICOGTX
MN
I'll be working as many hours as I can get at work. Have paint supplies, a couple wanted items to buy for the car, and would like to get a HANS device.
69 GTX
68 Road Runner
[Re: B3422W5]
#2382757
10/05/17 11:41 PM
10/05/17 11:41 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I have a few projects for the winter, I am not sure how many will get done.
Finish my Dana Swap(just need to get off my rear and put it in)
I am swapping to a Tunnel Ram with Dual 1000CFM Throttle bodies, I have a Holley Pro Dominator W2 tunnel ram being converted over to EFI as we speak.
Possible swap to a 904 or low gear 904 from 727
Hood Change, lose the heavy stock hood in favor of a six pack scoop. Suprisngly the tunnel ram would work with the stock hood but it would not have room for an air cleaner and I need that fresh air intake. The tunnel ram is coming first, I am not above driving around with no hood lol.
Install Flex Fuel sensor and maybe try E85
I had the intake off to inspect the lifters so I mocked up the tunnel ram before sending it off.
EDIT, I do not know why the pics I upload show up sideways? At least it shows up that way on my end.
68 Barracuda Formula S 340
[Re: B3422W5]
#2382773
10/06/17 12:04 AM
10/06/17 12:04 AM
Posts: 20,166 Park Forest, IL
slantzilla
Park Forest, IL
Lost my mind and bought the Buzzin' Half Duzzin' car from Mike Jeffrey on his retirement sale. I pick it up next spring. Have everything to put it back together. It's been sitting 10 years, what can possibly go wrong?
[Re: slantzilla]
#2382783
10/06/17 12:41 AM
10/06/17 12:41 AM
B3422W5
Portage,michigan
Lost my mind and bought the Buzzin' Half Duzzin' car from Mike Jeffrey on his retirement sale. I pick it up next spring. Have everything to put it back together. It's been sitting 10 years, what can possibly go wrong? Got any pictures of her. What has it run before? Are the Cox brothers still around?
[Re: B3422W5]
#2382794
10/06/17 01:15 AM
10/06/17 01:15 AM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
Finally wking on my Cuda again. The 30 yr old cage is being removed and replaced. Have a new tubular kframe to install and hopefully get one of my old short blocks back together. No real rush as I have my wagon to play with for now.
Ok
[Re: B3422W5]
#2382798
10/06/17 01:32 AM
10/06/17 01:32 AM
slantzilla
Park Forest, IL
Lost my mind and bought the Buzzin' Half Duzzin' car from Mike Jeffrey on his retirement sale. I pick it up next spring. Have everything to put it back together. It's been sitting 10 years, what can possibly go wrong? Got any pictures of her. What has it run before? Are the Cox brothers still around? I may have some pics on my home computer. Mike had it running consistant 10:50's on spray, best was 10:05. I plan on putting it together as just a nice, reliable, slow Pro bracket car running mid 12's or so. The Cox boys are still kicking, but they haven't really raced since they crashed tbeir '66 at the Nats years ago.
[Re: B3422W5]
#2382807
10/06/17 01:53 AM
10/06/17 01:53 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I’m low on funds this year, but my plans are a 6pt roll bar (currently a no-bar car) and reinforce the torque box area. Hopefully I can find enough with tuning the existing combo to offset the added weight and be right back where I was last year performance wise, but have the car set up to handle more punch in the future.
[Re: B3422W5]
#2382828
10/06/17 02:46 AM
10/06/17 02:46 AM
Posts: 326 Alberta
Wookie316
Alberta
Converter adjustment. Maybe go through the trans. Try and shave 150-200 pounds off the car.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2382964
10/06/17 02:14 PM
10/06/17 02:14 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
I already did the hood swap on the challenger due to a little mishap @ Milan. I was thinking about a cam upgrade But I picked up a more door Dart so I'll be working on that. Install my old 340 with a 904, the car is a pushbutton car so I'm looking to keep that if I can find a v-8 pb 904. It also needs a rear axle swap, 8 3/4. Frame connectors. Oh yea and change the bench seat to buckets. Wife want the car ready for spring, I think I have my hands full
[Re: B3422W5]
#2383006
10/06/17 03:43 PM
10/06/17 03:43 PM
Posts: 860 lancaster,california
johnnycuda
I'm looking into getting a Dana for my Cuda, and finish the 69 Valiant, drive it around, maybe take it to the track on a street legal day, should run around 12.0 or so I'm guessing...maybe faster. I'm kicking around going to the Zip-Tie Drags in Arizona in January.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: B3422W5]
#2383013
10/06/17 04:04 PM
10/06/17 04:04 PM
slantzilla
Park Forest, IL
[Re: B3422W5]
#2383024
10/06/17 04:22 PM
10/06/17 04:22 PM
johnnycuda
I'm just getting it done now, haven't drove it yet, but think it should run close to that, 408 w/RHS heads, 10-1, solid lifter .542/.556 cam, LD340, 780 Holley, has a A500 (has a low first), 3.73 rear, Calvert Suspension, drag radials. Apparently my pics are too large to load here, just had it painted B5 blue, ProStars, black interior, bench with column shift.
[Re: johnnycuda]
#2383045
10/06/17 05:00 PM
10/06/17 05:00 PM
Posts: 340 Red Deer, Alberta
Greenwood
Red Deer, Alberta
New valve springs and retainers, plus I think I have my head wrapped around how to sort out my valvetrain deflection/pushrod length situation. I'm giving up a lot of net lift due to bad geometry. Plus, if anyone here has some old Crane 1.6 rockers for a small block that they're not using, PM me. I'm also refreshing the convertor. After the last freshening, it launched the car really well at first, but now it no longer flashes to the needed 4500-5000 rpm my heap desperately needs. (TCS 8") To top it off, after finding out the limitations of my mini-spool behind a a trans brake with new slicks (Yes, Virginia a small-block actually CAN completely destroy every part of a 9" if you really try.), I need every part of a 9" that exists between the end of the driveshaft and the wheels, except for the driveshaft yoke and the housing. Well, not every part. I don't need new nuts for the center section studs.
[Re: Mr340]
#2383118
10/06/17 08:41 PM
10/06/17 08:41 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I already did the hood swap on the challenger due to a little mishap @ Milan. I was thinking about a cam upgrade But I picked up a more door Dart so I'll be working on that. Install my old 340 with a 904, the car is a pushbutton car so I'm looking to keep that if I can find a v-8 pb 904. It also needs a rear axle swap, 8 3/4. Frame connectors. Oh yea and change the bench seat to buckets. Wife want the car ready for spring, I think I have my hands full Now you're an A-body weenie! What year Dart?
[Re: B3422W5]
#2383134
10/06/17 09:37 PM
10/06/17 09:37 PM
slantzilla
Park Forest, IL
Thank you. I really didn't need another project, but I always liked the car and Mike made me a pretty fair deal on it. It has lots ofmoney spent on it trying to get it light.
[Re: B3422W5]
#2383302
10/07/17 06:07 AM
10/07/17 06:07 AM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
Transbrake transmission to go in by december , fit anti balloon plates to current vert as stall is good Hope i dont need a taller radial or i will have to move rearend back a little . Get M1 intake cut to fit motor then try adapter and dominator . Will also probably get Modman cut to fit and try it as well . All to be done and tested by end February . So it will be hot testing over summer .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: dustergirl340]
#2383320
10/07/17 10:28 AM
10/07/17 10:28 AM
Mr340
Richmond Twp. Mi.
I already did the hood swap on the challenger due to a little mishap @ Milan. I was thinking about a cam upgrade But I picked up a more door Dart so I'll be working on that. Install my old 340 with a 904, the car is a pushbutton car so I'm looking to keep that if I can find a v-8 pb 904. It also needs a rear axle swap, 8 3/4. Frame connectors. Oh yea and change the bench seat to buckets. Wife want the car ready for spring, I think I have my hands full Now you're an A-body weenie! What year Dart? its' a '64. I was actually looking for a '60 valiant and this turned up. It kinda spoke to us ...buy me, buy me... I think the engine swap and exhaust will be slightly easier on this one.
[Re: B3422W5]
#2383364
10/07/17 12:35 PM
10/07/17 12:35 PM
Posts: 2,915 A shed in England
Tig
A shed in England
We finally got this back at the track after a 20 month total stripdown, paint and rebuild. Lots of minor issues to sort out. We're starting from scratch again with the chassis after replacing all the worn out stuff and putting re-valved dampers on. We also need to fit the old 8 inch converter behind the back up 572 motor while the 655 gets re-freshed and some upgrades. We tried the 9 1/2 inch converter specced for the 655 but we feel the 8 inch will be better. The suspension has settled after a dozen passes and the camber, castor and toe are a mile out so that needs sorting too. We also fitted the 655 induction system to the 572 to see what happened. Theoretically way over carbed at 2300cfm, we chased a rich bog for most runs until we realised it was sloshing fuel out of the vent tubes.I'm also considering running an electric fuel pressure gauge, a -4 fuel return and an ARC module. We've ran out of racing 'till next season so we'll have to see if we've cured it and continue ironing out the bugs. Motor Shot
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: B3422W5]
#2383383
10/07/17 01:07 PM
10/07/17 01:07 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Out with the 440 and in with a 5.7 based gen III hemi. Probably add a transbrake while I'm at it.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: Mr340]
#2384018
10/08/17 06:03 PM
10/08/17 06:03 PM
dustergirl340
Chicken Little
Chicken Little
Chicken coop
its' a '64. I was actually looking for a '60 valiant and this turned up. It kinda spoke to us ...buy me, buy me... I think the engine swap and exhaust will be slightly easier on this one. '64 Dart is (almost) as cool as a '65 Dart. Sounds like a fun project. It's for your wife?
[Re: dustergirl340]
#2384043
10/08/17 06:51 PM
10/08/17 06:51 PM
dartman366
Mt. Vernon, Ohio
not really doing much this winter, just tidying up some things, don't really need to do much since the motor and tranny are all new, would like to go thru the wiring and re-route a few hoses, and get it ready to send to the chassis shop in the spring for a once over.
[Re: B3422W5]
#2384329
10/09/17 10:54 AM
10/09/17 10:54 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Just need to replace my twisted 35 spline axles and refresh the front brakes on the cuda.
All the while putting the '71 Demon back together.
[Re: dustergirl340]
#2384397
10/09/17 12:46 PM
10/09/17 12:46 PM
Mr340
Richmond Twp. Mi.
its' a '64. I was actually looking for a '60 valiant and this turned up. It kinda spoke to us ...buy me, buy me... I think the engine swap and exhaust will be slightly easier on this one. '64 Dart is (almost) as cool as a '65 Dart. Sounds like a fun project. It's for your wife? This should be a lot of fun because I'll do things to this one I wouldn't do to the challenger. We're calling it "her car" because she's the one that spotted it. If things work out right this will be the race car and the chally will be more street... .. or maybe I'll have to get a stacker. nothing is as cool as a 65 Dart can't wait to see the paint, have you picked a color yet?
[Re: B3422W5]
#2384816
10/09/17 11:45 PM
10/09/17 11:45 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
I'm going to replace my stock gas tank with a fuel cell so I can better manage my weight due to fuel volume (for NSS indexes).
1979 AMC Spirit, NHRA Q/SA
[Re: B3422W5]
#2384922
10/10/17 03:29 AM
10/10/17 03:29 AM
Posts: 9,985 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Working on getting my other 65 Dart running with the 408 I just built for it. 504 hp on the engine dyno, 904, 4000 +stall converter, 3.55 gears, frame connectors, coil over/rack and pinion front end. Plan on M/T drag radicals, not sure what to expect for ET and mph? https://vault.myvzw.com/webcs/app/share/invite/HSTxFoiutR
[Re: B3422W5]
#2384934
10/10/17 08:15 AM
10/10/17 08:15 AM
Posts: 4,647 aotearoa
rebel
aotearoa
having bought another car at the start of our winter, i had something new to explore & pull apart. The car had been running a blown Hemi on alcohol but i'm making the car an 8 sec bracket car. So, i removed 5 miles worth of uneeded wiring, raised the drivers seat & steering column, fixed the geometry of the steering shaft while at it. made a mount to suit a 727, made a new radiator mount, cut the fuel cell down to 1/3 of its size, removed all the decals, checked the driveline angle, made some headers, stripped out the windows so the car is ready for paint, changed the colour of the cage on the inside &relocated the guages from the steering colun & put them into a blank fiberglass dash. And i made a new rear wing coz i didn't like the other one. my old car is getting new Larry Smith ported -1's. a new cam & new HS rocker arms. my race season starts in 3 weeks.
[Re: B3422W5]
#2384963
10/10/17 10:23 AM
10/10/17 10:23 AM
Posts: 4,066 Mo.
racerx
Mo.
^^^Interesting looking E-body there^^^ My plans are to change the carpet to black and install some of those carbon fiber roll bar protectors .
[Re: Mr340]
#2385143
10/10/17 04:04 PM
10/10/17 04:04 PM
dustergirl340
Chicken Little
Chicken Little
Chicken coop
This should be a lot of fun because I'll do things to this one I wouldn't do to the challenger. We're calling it "her car" because she's the one that spotted it. If things work out right this will be the race car and the chally will be more street... .. or maybe I'll have to get a stacker. nothing is as cool as a 65 Dart can't wait to see the paint, have you picked a color yet? Sawzalls are fun on a car. LOL. And definitely get a stacker! The Dart will probably be some shade of green (to no one's surprise), though not high impact. Something to fit the mid 60's era.
[Re: dvw]
#2385242
10/10/17 07:41 PM
10/10/17 07:41 PM
Posts: 676 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
350 passes on my basically stock 727 running low 9's @ 3350lbs. I think I'll take a look. Time to check valve springs, bearings, and add a new pair of slicks. Doug Basically stock?! Haha I've seen the inside of that thing... lol Well we were hoping to just change out oil pans, add a diaper, and freshen the trans.... However, after last weekend looks like we will now throw a set of gears in it, new driveshaft, freshen the trans, perhaps a new sprague, maybe some axles, and a spool... Gotta love racing!!! Casey
[Re: Whompin_Wedge]
#2385379
10/10/17 11:57 PM
10/10/17 11:57 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
350 passes on my basically stock 727 running low 9's @ 3350lbs. I think I'll take a look. Time to check valve springs, bearings, and add a new pair of slicks. Doug Basically stock?! Haha I've seen the inside of that thing... lol Well we were hoping to just change out oil pans, add a diaper, and freshen the trans.... However, after last weekend looks like we will now throw a set of gears in it, new driveshaft, freshen the trans, perhaps a new sprague, maybe some axles, and a spool... Gotta love racing!!! Casey Yea that sucks but better it happened at the end of the year and not the beginning. All that new found power will make any weak links show up. I have a set of 5.88 gears if you are interested. I may try them in mine
[Re: max_maniac]
#2385805
10/11/17 06:43 PM
10/11/17 06:43 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hmmmmm Winter upgrades. The small block in my black Duster will be getting the solid lift cam pulled and replaced with a bigger roller cam. I will also be doing some more porting and flow testing on my 360-1 heads and I may add a few more cubic inches. My 572 for the small tire car has been on the engine stand forever and I may have it done and going into the car by next week. I would LOVE to make a pass or two NA in November before the local tracks close. Another 408 Edelbrock headed build will be started so Matt and I have a fresh bullet sitting on a stand just in case it is needed. I should also have my 512 Mega block done by March with a very nice set of 440-1 Indy heads. The block is ready to go and the assembly is balanced and ready for installation. Matt also wants to switch his car over to a 9 inch rearend and powerglide so I have 3 powerglides that I will be assembling. Hopefully I have 1 or 2 surprises that I may do but that depends on if I can come up with the needed funds. It should be a busy Winter.
[Re: slantzilla]
#2385824
10/11/17 07:23 PM
10/11/17 07:23 PM
Posts: 1,505 TN
SCATPACK 1
TN
I LIKE IT!
Old Geezer Racing
[Re: B3422W5]
#2385827
10/11/17 07:26 PM
10/11/17 07:26 PM
Posts: 1,505 TN
SCATPACK 1
TN
The plans are to pull this 40 year old 440 out of my 70 Challenger and replace it or rebuild it with newer parts that don't sound like a diesel with piston slap when it is cold. Maybe some aluminum heads and put a real 4 833 4 speed in it instead of the 6 cylinder OD trans that came out of a 80 dodge 6 cylinder. Then go to the track where I have not gotten to make a run in 36 years. Not since my son was a year old and we needed family money.
Old Geezer Racing
[Re: B3422W5]
#2385883
10/11/17 09:00 PM
10/11/17 09:00 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
1) Rebuild the 10 year old 670 Street Avenger and get it running right again. The 750 Street Demon I bought is so rich I may as well just run long hose from the local gas pump straight into my intake manifold.
2) Upgrade to a modern ignition system. Probably a Pertronix dizzy, coil, and wires. Realizing that MP orange box conversion on my car is about 25 years old now, and was about 20 year old technology when I installed it.
3) Full suspension rebuild front and rear. When I cruise around the crappy roads in the neighborhood it sounds like someone rolling a 50 gallon drum full of bricks down the road. Sooo many clunks and bangs.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: max_maniac]
#2385897
10/11/17 09:23 PM
10/11/17 09:23 PM
Whompin_Wedge
COLUMBUS, OH
350 passes on my basically stock 727 running low 9's @ 3350lbs. I think I'll take a look. Time to check valve springs, bearings, and add a new pair of slicks. Doug Basically stock?! Haha I've seen the inside of that thing... lol Well we were hoping to just change out oil pans, add a diaper, and freshen the trans.... However, after last weekend looks like we will now throw a set of gears in it, new driveshaft, freshen the trans, perhaps a new sprague, maybe some axles, and a spool... Gotta love racing!!! Casey Yea that sucks but better it happened at the end of the year and not the beginning. All that new found power will make any weak links show up. I have a set of 5.88 gears if you are interested. I may try them in mine Finally going to go 1/8th mile racing?! haha Casey
[Re: Whompin_Wedge]
#2386010
10/12/17 12:16 AM
10/12/17 12:16 AM
max_maniac
Aurora, Oh.
350 passes on my basically stock 727 running low 9's @ 3350lbs. I think I'll take a look. Time to check valve springs, bearings, and add a new pair of slicks. Doug Basically stock?! Haha I've seen the inside of that thing... lol Well we were hoping to just change out oil pans, add a diaper, and freshen the trans.... However, after last weekend looks like we will now throw a set of gears in it, new driveshaft, freshen the trans, perhaps a new sprague, maybe some axles, and a spool... Gotta love racing!!! Casey Yea that sucks but better it happened at the end of the year and not the beginning. All that new found power will make any weak links show up. I have a set of 5.88 gears if you are interested. I may try them in mine Finally going to go 1/8th mile racing?! haha Casey oooops - meant 4.88
