Re: used cam/lifters into another block. Problem or OK?
[Re: RTSrunner]
#2383240
10/07/17 12:34 AM
10/07/17 12:34 AM
RapidRobert
Yeah that'd be the same as what I was considering.
[Re: RapidRobert]
#2383795
10/08/17 11:50 AM
10/08/17 11:50 AM
Posts: 10,666 North Dakota
6PakBee
North Dakota
I think that the statements in the FSM concerning camshaft and/or lifter replacement for stock components is the best guide. I'm not going to post any of the verbiage in the FSM because if you don't have the FSM for your car, you should get one.
[Re: 6PakBee]
#2383821
10/08/17 12:32 PM
10/08/17 12:32 PM
RapidRobert
are you talking about lifter/bore clearances? I'm haveing an issue there too (low psi). I may have to use my solid & tube it (or bush em with the current hyd).
