#2379629 - 09/30/17 09:52 PM For Sale - Elephant Hemi Engines - 4th Quarter
moparts Offline
#2380291 - 10/01/17 09:13 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
938-DAN Offline
Loc: New Jersey
For Sale:
Pair of original 426 Hemi exhaust manifolds. Dated October and November of 1966. Very nice condition but heat riser has been removed and holes plugged and passenger side manifold has a crack in the flange area that will need to be repaired. Price is $700.00 for the pair including shipping within the continental US.
Please email with questions or for more pictures ASonn86814@aol.com .
Thank you.
Edited by 938-DAN (10/15/17 11:30 AM)
#2380295 - 10/01/17 09:16 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
938-DAN Offline
Loc: New Jersey
For Sale:
1969 426 Hemi engine and matching manual transmission from a 1969 Dodge Coronet R/T WS23J9. Block casting date 6/10/68, cylinder heads dated June 18 and June 26 of 1968. Good used cores for a 1969 B body hemi project.
I have the assembled long block with intake manifold, oil pan, heads, rocker arms, valve covers, water pump and balancer. I also have the heavy duty 18 spline four speed manual transmission with matching VIN number and the correct cast bell housing.
I DO NOT have the carburetors, exhaust manifolds, distributor, pulleys, fan, flywheel or starter.
This is not the typical collection of mismatched leftover parts, it is a complete long block and matching transmission as removed from a vehicle. No visible damage but it does appear to have been in storage for a long time and will need to be gone through. Selling the package for $18,500.00. Must be picked up in southern New Jersey, zip code 08096. Please email ASonn86814@aol.com .
Thank you.
Edited by 938-DAN (10/03/17 06:45 AM)
Edit Reason: Pictures Added
#2380625 - 10/02/17 01:07 PM Hemi valve cover gaskets [Re: moparts]
johnnyd Offline
Loc: Boston, MA
2 Sets Hemi valve cover gaskets $35 for both sets NOS Mr. Gasket 374 SOLD!!! Thanks MOPARTS!
Edited by johnnyd (10/04/17 06:35 PM)
#2381478 - 10/03/17 08:46 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
Dragula Offline
Loc: Taxes R-US, NY
$25k price drop.
This is the last time the Callies crank can be turned, and so I am lowering the price. Engine is almost back together and you can hear it run as I am putting it back in the car
All aluminum Indy style Hemi parts purchased from BGR. Complete 1250 carb to pan. I currently have it all apart as we have nearly fixed the last remaining issue from last year. This engine makes over 800hp on pump gas and is an absolute street terror.
Last year I did window it after starving #7 rod bearing for oil. The block was professionally repaired and is currently out for a final line hone just to make sure nothing moved. All parts that were hurt were replaced or repaired professionally. Also, the head oiling has been restricted to better limit oil up top and keep oil in the pan to keep from starving any rods.
All good parts, 11.2:1 compression. Heads ported and flowed..all build specs here...Should have it all back together here in a few weeks. Can hear it run in a few weeks as it will back in the car.
May take a 6.1 Hemi stroker and $$$ in trade...
All build specs here
http://board.moparts.org/ubbthreads/ubbt...ld-updated.html
Very Streetable:
https://www.youtube.com/watch?v=WYw6RA-k5Bk&t=37s
Edited by Dragula (10/03/17 08:48 PM)
'71 Duster Pump Gas 512RB
https://www.youtube.com/watch?v=Z_XTmRBuvWs (6.19)
https://www.youtube.com/watch?v=gQZGfDBPROM (9.70 at 138.5mph)
'70 Cuda NO Hemi, again
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.31)
#2381623 - 10/04/17 04:57 AM Hilborn Fuel Injection [Re: moparts]
70HemiGTX Offline
Loc: PA
SOLD. Thanks Moparts.
Edited by 70HemiGTX (10/11/17 04:37 PM)
#2381762 - 10/04/17 11:29 AM 572 Race Legend new [Re: 70HemiGTX]
67R/T4speeder Offline
Loc: Pismo Beach,California
part# 426-c6-572-960
In the crate
$21,000.00
zip 93433
troxellsgarage@gmail.com
Andy
www.troxellsgarage.com
#2382052 - 10/04/17 06:45 PM Hemi race weight valve covers [Re: moparts]
70HemiGTX Offline
Loc: PA
For Sale: Hemi dual plug light weight aluminum valve covers. Very nice condition. I polished them. What you see is what you get. One full set of single hole block-offs. One full set of twin plug block-offs. 4 new breathers. They are ready to bolt on. $600 shipped to the lower 48. Email me at: trdeppen"at"comcast.net or pm me here.
#2386259 - 10/12/17 11:31 AM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
36viper Offline
Loc: MN
For sale: '68 HEMI block with racing modifications. #MN42623230027
#8G19019
Also included are Keith Black aluminum main caps, BRC aluminum rods, 12.5 : 1 CR forged pistons.
Has had oil galley bypass done (right side),as per instructions from the Direct Connection Performance Bulletin. The block was run 12-15 times on the quarter mile track before the previous owner went to an aluminum block. The bores look fine.
Block has passed magnaflux and pressure tests. Block was inspected by Bruce Crandall at Total Engine Service in Bloomington, MN on Oct.10th, 2017.
Here are his findings: bore size 4.260 (.01 or less oversize), deck height 10.62 (.100 removed), Lifter bores OK for roller camshaft. He recommended honing the lifter bores slightly.
This would be an excellent HEMI block for a drag car or possibly a really fast pro-street, as the engine work has already been done for the most part.
Price: $4000.00 firm
I could bring the block from MN to NY , or somewhere in between this fall with a sufficient down payment.
Please contact me at 7633007118 or videen36"at"msn.com .
Thanks much!
Brad
Edited by 36viper (10/13/17 10:59 PM)
Thank you Moparts for the help!
#2386416 - 10/12/17 04:17 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: 36viper]
HemiGreg Offline
Loc: L.I. N.Y. Hemi Street
Hemi factory blocks std,+30,+60
all never hurt 66,68,69,69,the 69s are unstamped
$4500-6000 pickup only li.ny 11783
5167817653 leave message
http://www.hemigreg.com
Orignal Hemi Cuda (shaker is in garage)
"No clones allowed"
#2387365 - 10/14/17 01:01 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
old_racer Offline
Loc: Wi.
new in box mopar perf crossram intake never mounted. $625.00
email for pic's
hemimax@hotmail.com
#2387403 - 10/14/17 02:46 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: old_racer]
dsd70bee Offline
Loc: oak park, il.
One set of 426 HEMI rocker assemblies, Everything aftermarket for a Top Fuel or Alcohol aluminum type head, Stage V roller tip intake rockers $2000.00 for the pair (708)288-2879 Scott
#2387416 - 10/14/17 03:06 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One set of eight 426 HEMI Stage V roller tip intake rockers in excellent used condition $750.00 for the set (708)288-2879 Scott
#2389469 - Yesterday at 05:39 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
70HemiGTX Offline
Loc: PA
For Sale: I have 3 Hemi valve covers.
1. Chrome Direct Connection 70-71 passenger's side valve cover. Very nice condition. Has spark plug loom. Never had the wireloom tabs. No dents. $400 shipped to the lower 48.
2. Chrome 70-71 passenger's side valve cover. Ok condition. Has spark plug loom. Wireloom tabs are missing. $300 shipped to lower 48.
3. Chrome 69 and earlier valve cover. Chrome is nice. Had a hole drilled in the backside of the valve cover. Has an AN plug in it. What for????? $95 shipped to lower 48.
Email me at: trdeppen"at"comcast.net or pm me here or call 7one7-five71-518zero.
Thanks for the ad.
24,898 Registered Members
184,231 Topics
“The Juicer” Dodge Truck Commercial
by theraif
10/19/17 04:00 PM
by theraif
10/19/17 03:59 PM
Cheap gen III hemi builders
by NTOLERANCE
10/19/17 03:41 PM
Exhaust off a 17 SPack Challenger
by cudaman1969
10/19/17 03:40 PM
