Re: BES at engine masters getting it done with a bb mopar
[Re: mcat4321]
#2382026
10/04/17 07:26 PM
10/04/17 07:26 PM
Posts: 1,048 The Great White North
RAMM
I have been watching the Live feeds on FB. What heads are those on BES's 451 BBM? I heard peaks of 670 HP/ 640 tq and they are currently in second place with 2630 pts. Just really curious about his choice of heads. They seemed really disappointed in the interview at the end. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: mcat4321]
#2382124
10/04/17 11:09 PM
10/04/17 11:09 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Yeah Kasses engine was very interesting
68 Barracuda Formula S 340
[Re: Bad340fish]
#2382322
10/05/17 10:30 AM
10/05/17 10:30 AM
KOS
Yeah Kasses engine was very interesting ya looks like a real simple build....LOL very curious to learn more about the mopar build can't see it being nowhere as exotic as the ford.
[Re: mcat4321]
#2382370
10/05/17 12:53 PM
10/05/17 12:53 PM
Posts: 1,505 TN
SCATPACK 1
TN
Kasses engine is bogus and not even close to being within the rules. Should have been thrown out.
Old Geezer Racing
[Re: RAMM]
#2382384
10/05/17 01:17 PM
10/05/17 01:17 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I have been watching the Live feeds on FB. What heads are those on BES's 451 BBM? I heard peaks of 670 HP/ 640 tq and they are currently in second place with 2630 pts. Just really curious about his choice of heads. They seemed really disappointed in the interview at the end. J.Rob 640 is a big tq number for a 451, and I realize it's all about making big numbers within the specified rpm band....... But to only end up with 670hp when you had 640tq in the lower revs....... It must have fallen off pretty quickly.
[Re: fast68plymouth]
#2382452
10/05/17 02:58 PM
10/05/17 02:58 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
I have been watching the Live feeds on FB. What heads are those on BES's 451 BBM? I heard peaks of 670 HP/ 640 tq and they are currently in second place with 2630 pts. Just really curious about his choice of heads. They seemed really disappointed in the interview at the end. J.Rob 640 is a big tq number for a 451, and I realize it's all about making big numbers within the specified rpm band....... But to only end up with 670hp when you had 640tq in the lower revs....... It must have fallen off pretty quickly. the peak numbers mean nothing,that's where most builders go wrong at EMC..im sure you understand the scoring procedure. If peak go was the focus,I'm sure it would be , and did you see the torque curve
[Re: mcat4321]
#2382462
10/05/17 03:07 PM
10/05/17 03:07 PM
fast68plymouth
So. Burlington, Vt.
If peak go was the focus,I'm sure it would be , and did you see the torque curve Actually, I couldn't find any info on it at all. My point in the previous post was, the tq curve must be falling off pretty quick at some point in the run to only end up with 670hp when there were tq numbers in the 640 area within the tested range. In other words, I'd think those 640tq numbers must have happened pretty early on in the pull. If you have a link to where the results of the pulls are posted, I'd like seeing them.
[Re: mcat4321]
#2382555
10/05/17 05:43 PM
10/05/17 05:43 PM
fast68plymouth
So. Burlington, Vt.
I looked over the rules for that class.
Those are pretty impressive numbers when you look at the restrictions.
#2382564
10/05/17 05:58 PM
10/05/17 05:58 PM
Posts: 11,706 Portage,michigan
B3422W5
Portage,michigan
Those are pretty impressive numbers when you look at the restrictions. When that little 318 i had in the white Duster was at enginemasters, they scored it from 2500-6500 rpm
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: WedgeFED]
#2382621
10/05/17 07:59 PM
10/05/17 07:59 PM
RAMM
Not Victors--only allowed stock offset rockers. I'm thinking they are TF's. J.Rob
[Re: mcat4321]
#2382731
10/05/17 10:56 PM
10/05/17 10:56 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I don't see how that MEL fits the letter of the rule at all no matter how hard I squint and plain as day don't fit the spirit of the rule whatsoever.
[Re: mcat4321]
#2382857
10/06/17 09:24 AM
10/06/17 09:24 AM
BradH
Find the video and check it out . The shop can build big power out of anything Does BES build your engines? EDIT: After seeing both BES and Kasse's EMC entries over the years, I've come to the opinion that Bischoff is amazing, but Kaase is the brilliant Mad Scientist who can re-think just about any perceived obstacle in ways that would never occur to others.
