Year One M&H wiring harnesess
#2381857
10/04/17 04:41 PM
10/04/17 04:41 PM
Posts: 180 Bradford, Ontario
Barrelhouse
Bradford, Ontario
Id like to know if M&H wiring carried by Year One are top quality products as ive been told they are. Are any other companys making complete wiring harnesses for 1972 Demons with 340 and 4-spd like OE Chrysler. N.O.S wiring is hard to find and super expensive. Im in Canada so the exchange rate is crazy. I know of a N.O.S forward headlight harness for my car and he wants $ 750.00 US for it which works out to be close to a $ 1,000.00 Canadian shiped and i have to replace all my wiring front to back. Thanks Moparts for free post great site.
Re: Year One M&H wiring harnesess
[Re: Barrelhouse]
#2381871
10/04/17 05:20 PM
10/04/17 05:20 PM
Posts: 4,269 Morrow, OH
markz528
Morrow, OH
I have several and I thought they are fair. But they do work.
[Re: ahy]
#2382918
10/06/17 12:21 PM
10/06/17 12:21 PM
Posts: 16,122 Mesa, Arizona
dart4forte
Mesa, Arizona
I have the Y1/M&H harness and agree it is a good harness. There are lots of choices for non-stock harness but not much stock replacement. I used the M&H harness to re-do my mostly engine compartment, mostly stock instrument panel and wiring and modified it somewhat for high current alternator and EFI. I was glad to have all the stock bits including pass compartment and instrument cluster referenced to the stock wiring diagrams. Did th entire car, engine, under dash, rear, console. Good quality. My only issue was they didn't have a patch for the console tach.
Abe Lincoln
[Re: dart4forte]
#2383018
10/06/17 04:10 PM
10/06/17 04:10 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
I have the Y1/M&H harness and agree it is a good harness. There are lots of choices for non-stock harness but not much stock replacement. I used the M&H harness to re-do my mostly engine compartment, mostly stock instrument panel and wiring and modified it somewhat for high current alternator and EFI. I was glad to have all the stock bits including pass compartment and instrument cluster referenced to the stock wiring diagrams. Did th entire car, engine, under dash, rear, console. Good quality. My only issue was they didn't have a patch for the console tach. I had a couple of small sub harnesses that I sent to M&H ( ten plus years ago) and they built them for me...
[Re: Barrelhouse]
#2383608
10/07/17 10:30 PM
10/07/17 10:30 PM
Posts: 406 California City, CA
dart440
California City, CA
The one drawback to the harnesses I got for my Duster from YO was that the underdash harness took 8 months to get. Held up my project. The taillight harness came in a few weeks...go figure.
When you work on Spaceships for a living, how bad can a workday be?
[Re: mopars4ever]
#2384161
10/08/17 10:47 PM
10/08/17 10:47 PM
Posts: 7,194 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Plus a NOS harness may have issues also being 40 plus years old. Agreed, depending on how/where the "NOS" harness was stored it still might be a little crispy and not the best choice...
[Re: Barrelhouse]
#2384698
10/09/17 08:39 PM
10/09/17 08:39 PM
Posts: 21,391 It's a dry heat
gtx6970
It's a dry heat
Ive used M+H on maybe 5 or 6 cars so far. Ive had 2 that had issues.
One was the feed wire for the ballast resistor was crimped over the insulation instead of bare wire 1968 B body ( thus no voltage to the coil )
2nd one was a mis-wired bulkhead connector in an E body for the wiper operation ( had 2 wires crossed up )
That said I will not hesitate to use them again and again.
