#2379610 - 09/30/17 09:45 PM Mopar Transmission Wanted - 4th Quarter
moparts Offline
#2379890 - 10/01/17 10:49 AM WANTED - 270 & 271 shift levers for a '70 B-body 3-speed [Re: moparts]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Still moving in.
WANTED - 270 & 271 shift arms for a '70 B-body 3-speed A-230 manual transmission with the shifter on the floor.
The numbers are clearly stamped in each lever.
These are the last two parts I need to complete my second set, but if you have the whole setup & do not want to split it up I cam make that work too.
Please send photos with price to sixpak340(insert at symbol here)att.net
#2379941 - 10/01/17 12:16 PM WANTED - Barrel spacers for a '70 A-body 3-speed A-230 trans [Re: Alaskan_TA]
Alaskan_TA Offline
Fluffy Balladeer
WANTED - Barrel spacers for a '70 A-body 3-speed A-230 manual transmission with the shifter on the floor.
These spacers go in between the shifter & the mounting pad on the transmission, they are just over 3/4" long.
They are very similar to alternator spacers, so please check any spares you have for this length?
I need two more of these spacers to complete a set, but I would buy a set of three if you do not want to break up a complete set.
#2380261 - 10/01/17 08:15 PM Re: Mopar Transmission Wanted - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Wanted; Big block 727 transmission with part of #3515848. I would also consider part #3410670 or #3515846. Prefer if in the Detroit area for pickup so as to avoid having to ship.
A new or good used Turbo Action or TCI ten inch torque converter for a 727 with a stall rating of 3300-3500 rpm.
Complete factory automatic kickdown linkage set-up for a 67-69 big block A-body.
gt340 at yahoo.com
#2380419 - 10/02/17 02:26 AM Re: Mopar Transmission Wanted - 4th Quarter [Re: moparts]
mosweethemi Offline
Loc: VA.
HELLO WE ARE LOOKING FOR A 1970 440 SIXPACK TRANSMISSION . PART NUMBER IS 3410672 PLEASE HELP .MAIL ME HERE OR AT MOSWEETHEMI@YAHOO.COM OR CALL 540-337-4310 OR CELL PHONE 540-480-1488 THANKS MOPARTS.COM FOR OUR ADD
#2380600 - 10/02/17 12:39 PM Re: Mopar Transmission Wanted - 4th Quarter [Re: moparts]
johnnyd Offline
Loc: Boston, MA
wanted: used JW ultra bell for glide to big block Mopar. prefer one without modifications to it. PM or email johnnyd@mit.edu
#2381225 - 10/03/17 10:57 AM Re: Mopar Transmission Wanted - 4th Quarter [Re: moparts]
RAH Offline
Loc: sw chicago
wanted 1968 727 automatic transmission 2801544 bob h 708 687 1187
RAH@wowway.com
#2381758 - 10/04/17 11:20 AM Re: Mopar Transmission Wanted - 4th Quarter [Re: RAH]
xs29j8 Offline
Loc: Fort Worth, Texas
Wanted to buy or trade for a 1968 Hemi Automatic transmission, part number 2801544 needed for my upcoming restoration of my triple black 1968 Hemi Charger R/T. Also looking for a clean "426 Charger" owner's manual for the same car.
I have a large amount of used & NOS Mopar parts for trade material, below is a partial list...
Allen Vasut
xs29j8@charter.net
From memory, here is a list of some of the neater parts that I am currently planning to offer for trade in the near future:
Hemi Parts
1) NOS Pair of 1969 Hemi Carbs, Carter 4619S & 4620S, complete with NOS Hemi Choke & NOS 4spd Dashpot
2) NOS Pair of Hemi Heat Tubes
3) Used Pair of Hemi Heat Tubes
4) Used Hemi Intakes (both styles, including one with "Vanke" mod)
5) NOS 1970 Hemi Carb Spring (22 coils, Green with light blue stripe)
6) NIB Standard Parts ES6 Idle Solenoid (Identical to the GM Delco Remy part number used by Chrysler, except hex head which is replaceable)
7) NOS 1968 & 1969 Hemi Distributor Control Valve (aka Emissions Control Valve, "Green Can", Etc) with bracket
8) NOS Distributor Control Valve from kits for California cars (exterior same as Hemi valve, bracket available from HARMS Automotive)
9) Used (lightly) 1970/71 style oval Hemi Air Cleaner base & lid, base has vacuum nipple, breather connection on passenger side)
10) NOS Hemi Exhaust Manifold Rebuild kit for "flapper" valve used to divert heated exhaust to heat tubes
11) NOS Hemi Auto Transmission Kickdown linkage lower bellcrank
12) NOS Hemi Carb Rebuild Kits - One pair of Carter AFB kits from the 1990s (unopened)
13) NOS Hemi Carb Rebuild Kits - Six pair of AFB kits from about 1970 (older, but unopened)
14) NOS Hemicuda Hockey Stick Quarter Panel Decals with door decals included (pair, R & L)
15) NOS Hemi Throttle Cable Bracket for Auto cars, kickdown pivot pin can be removed to use the bracket on a 4 Speed car)
Various B-Body & E-Body Parts
16) NOS / NIB / NEW Various new oval air filters including Mopar L406, Fram CA332, Etc
17) NOS 1969 Road Runner / GTX Front Turn Signal Lenses (Pair, L & R)
18) NOS partial rolls of about 5-6 original vinyl upholstery materials, most are black but Blue & Green seat insert materials are included
19) NOS 1969 Road Runner Taillight Lenses (Pair, R &
20) NOS 1970 thru 1974 E-Body Replacement Dash Pad, Black with Single Speaker Hole, no provision for model name (as serviced by Chrysler from mid 1970s -On)
21) NOS Challenger Hood front edge "chrome" moulding
22) NOS Challenger Trunk Lid
23) NOS 1968/69 Headlight Door Actuator (Only one for sale)
24) NOS 1970 B-Body Rallye Dash Clock Assy
25) A few miscellaneous NOS dash cluster guages, switches, etc for both B-Body & E-Body Rallye Clusters
26) NOS Front Valance for 1970 `Cuda
27) NOS Rear Valance for 1970 `Cuda
28) Two of the four `Cuda wheel opening mouldings in NOS (have to verify which two I still have)
29) Used B-Body Woodgrain Steering Wheel from one of the trainer units (Production wheels used)
30) Used set of "Hemi" finned 15 inch wheel covers that were the only factory alternative to hubcaps after W23s recalled
Six Pack Parts & Misc Other
31) NOS Six Pack Air Cleaner Assy with a splash shield for non-fresh air cars, base & lid included
32) NOS "440 Six Pack" Hood Emblems (Pair in unopened packages)
33) Used Aluminum 440 Six Pack Intake with Factory Part Number
34) NOS 440 Six Pack Coil Mount Bracket to relocate coil on 440 six packs
35) NOS 440 Six Pack kickdown linkage lower bellcrank
36) NOS SuperBee / Coronet R/T Longer Exhaust Tips (IIRC, will need to verify).... Pair
37) NOS 1971 thru 1974 B-Body Door Opening Sill Plates - Pair
38) Used 1970 Hurst Pistol Grip Console Shifter (Box Mechanism & Chrome Arm w/Grips)
39) Used 1969 Hurst Round Bar Console Shifter (Box Mechansim& Chrome Arm, no Ball)
40) NOS Superbird Decal Set, Quarter Panel "Plymouth" & Wing Decals (Pair with Black OR White lettering)
Thanks,
Allen Vasut
#2386449 - 10/12/17 05:24 PM Re: Mopar Transmission Wanted - 4th Quarter [Re: xs29j8]
5.7bob Offline
Loc: Auburn Mich.
Looking for A518 core in the Michigan area. email bp6468@charter.net
#2387032 - 10/13/17 06:00 PM Re: Mopar Transmission Wanted - 4th Quarter [Re: moparts]
torredcuda Offline
Loc: NH
4 speed set up for `73 road runner 400 bench seat car, need bell, fork, shifter, bracket, linkage etc., basically everything except I have the z-bar. Let me know what you have, in Epping Nh so local or will need shipping.
https://www.facebook.com/pages/Northeast-Mighty-Mopar-Club/365435766974452?ref=aymt_homepage_panel
`72 Barracuda 340/4spd
`70 road runner 383/auto
`70 Duster 360/auto drag car
`71 Duster project
`76 W100 clubcab project
`83 W350 plow truck
#2388296 - 10/16/17 04:50 PM Re: Mopar Transmission Wanted - 4th Quarter [Re: moparts]
lordhelmet Offline
Loc: CA USA
Looking for a good used working Forward cheetah valve body. PRN321.
Thanks,
Moparts
#2388722 - 10/17/17 11:36 AM Re: Mopar Transmission Wanted - 4th Quarter [Re: moparts]
B1Frank Offline
Loc: West Virginia
****WANTED **** 72-80 Dodge truck 4x4 big block #11/12 inch clutch/bell cover,..that is not over priced,..please email with price,..Thanks
24,900 Registered Members
184,279 Topics
Revisiting the 57 Plymouth
by Mike P
Today at 06:25 AM
RIP Gord
by ChryCoGuy
Today at 02:16 AM
Thanks to Mopar Muscle and Moparts.
by 383man
Today at 01:33 AM
340 Re-Rebuild or take my chances
by hyefatman
Today at 12:04 AM
