Page 3 of 5 < 1 2 3 4 5 >
#2381551 - 10/03/17 10:44 PM New BB JE pistons,pins and rings [Re: fbs63]
fbs63 Offline
Loc: NW Indiana
New BB RB JE pistons. 4.440 bore,1.850 compression height. Trend tool steel .990x2.930 pins. Total Seal AP 4.440 bore ring set. All New. $350.00 shipped in the lower 48. PM here, text or call 708-two07-five374
Edited by fbs63 (10/03/17 10:44 PM)
#2381606 - 10/04/17 01:43 AM Re: New BB JE pistons,pins and rings [Re: fbs63]
493_john Offline
Loc: Chesterfield Twp. Mi.
Indy cast Predator tunnel ram, new..not used...not milled...not ported, comes with 2x4500 top, 1/2 plenum spacer, A.R.T. bellcrank linkage, magnafuel 4 port regulator with lines to carb and 2 Holley 1050 8896-1 carbs with tr floats and Quick Fuel float bowls with sight glass.
$1950 text for pics john 586-222-2728
1.27 60ft on Radials 9.11 @ 147 3410 lbs.
#2382065 - 10/04/17 07:39 PM used nrc offset distributor [Re: moparts]
julian2007 Offline
Loc: oh
good shape 500.00 plus the ride
937-489-9397
I'll add photos tomorrow
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
#2382068 - 10/04/17 07:43 PM mega 500 delay box like new [Re: julian2007]
julian2007 Offline
Loc: oh
Only used 1 season mega 500 delay box
400.00 plus the ride
937-489-9397
Edited by julian2007 (10/05/17 08:45 AM)
#2382136 - 10/04/17 09:20 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
rbkt65 Offline
Loc: illinois
ptc 8 inch converter. 4 passes on it. 5400 stall. not enough for my car. don't check pm's here very often. 500/obo plus ride. text is best as not allowed phone at work. no scammers. located near stl,mo. postal m/o or cash.might trade for bb .030/.040 pistons with 2.05 comp height, h beam rods or ????. want to build street 440 with bout 10.0/10.5 to 1 compression. contact info is 618-946-4241
#2382402 - 10/05/17 11:54 AM Complete 3 inch A body exhaust [Re: moparts]
B3422W5 Online   content
Loc: Portage,michigan
Includes flowmaster mufflers, chrome tips, under a year old. Was hooked up to Dougs headers.
Had to cut in a couple places when i removed it, easy to weld back up.
150.00 takes it. Must pickup, wont ship. Southwest Mi( Kalamazoo area)
PM me on the board
69 Dart GTS, performance upgrades in progress
11.26@ 118.40 best so far. Stock 360 shortblock with eddie heads.
#2382906 - 10/06/17 09:53 AM RHS MA-X Heads [Re: an8sec70cuda]
TheOtherDodge Offline
Loc: Houston, Texas
These are used but have been cleaned and inspected.
Will need new guides/seals and a valve job (required when replacing guides). Other than that, they are ready.
2.02/1.625, springs are new set at 125 seat, 355 open.
Brand new these are $1,350 shipped. I am asking $650 shipped.
Please email me at jsintexas2@ yahoo. com
- 94 Dakota, sb, 76mm turbo AC, PS, PB, full interior! 9.97 @ 133.33
- 00 Dakota QC, 5.9, stock, 6 lb Powerdyne, 13.9 @ 98.38
- 05 E55 AMG, 11.80 @ 117.9
#2383008 - 10/06/17 01:47 PM Hurst Ramrod Shifter [Re: TheOtherDodge]
sixpacksteve Offline
Loc: n.y.
Still works great!
Bracket and rods included!
came off an A-body!
SOLD! Thanks Moparts
Edited by sixpacksteve (10/09/17 12:15 PM)
#2383087 - 10/06/17 05:19 PM Re: Hurst Ramrod Shifter [Re: moparts]
EV2Bird Offline
On Vacation
Loc: Kansas Roads Between 0 and 140...
SOLD... THANKS MOPARTS!
NEW Mopar Performance .557 Solid Camshaft 273 318 340 360
CAM ONLY!
Still has there protective coating and yellow paper wrap.
PM me here. THANKS!
I purchased it approx 7 months ago, used a comp cam I had and needed the lifters from the .557 kit.
#2383122 - 10/06/17 06:48 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
@#$%&*! Offline
New user name, Same old jerk!
Loc: 1940 North Victory Boulevard ...
Holley Street Dominator Intake Manifold RB 440-413
Blasted clean and washed with soap and water. All threads good and chased, never ported, no signs it was ever milled. Someone did shorten the front coil mount pedestal for some reason but it still has enough threads to hold a coil. Perhaps will work with a small-block coil bracket, I should try that.
$200 plus shipping
not offended by offers
PM through board
#2383142 - 10/06/17 07:47 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
EV2Bird Offline
On Vacation
Comp Cams 273 318 340 360
Comp Cams 305AH-8 Camshaft
Comp Cams 822-16 Lifters
$250 Shipped Lower 48 only
PM me here.
Thanks.
#2383144 - 10/06/17 07:48 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
EV2Bird Offline
On Vacation
New Mopar Performance Cam Kit P4120231 284/284 lift 484/484 Dur 239@50 108 68 Overlap
Cam and Lifters $235 shipped usa lower 48 only
PM me here. Thanks.
#2383149 - 10/06/17 07:51 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
KOS Offline
588 B1 motor
Brand new build only few dyno pulls and couple street miles...around 1000hp 800ft lbs.
orig B1 heads done by FHOs Tim Banning with Jessel paired rockers and spray bar oiling.
Indy Maxx new gen big sleeve tall deck block 4.500 bore
Callies gun drilled ultralite billet 4.625crank
GRP 7.150 rods
JE Coated dome pistons
comp 4/7swap custom roller ground for longevity and streetability
comp offset lifters,Manley Nextex springs
Jesel belt drive,milodon dual line oiling with custom alum pan that will work with tubular K-member
New NOS fogger plumbed
worked 1150dom with BLP wide metering blocks etc
also will come with NEW glide converter built for this combo billet flywheel and
adapter.still in car running. 20K.pm me
#2383988 - 10/08/17 03:17 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
humpty Offline
Loc: Minnesota, USA
BG400 fuel pump. Rebuilt by Barry Grant as a spare but never used since rebuild.
$175/B.O. PayPal preferred.
PM me here.
Thanks for the ad Moparts!
72 Duster - 408ci W2 iron headed SB, 1.41 60', 6.43@105, 10.18@131.
#2384284 - 10/09/17 04:03 AM New valve covers Direct Connection [Re: fbs63]
mosweethemi Offline
Loc: VA.
Hello I have three new sets of Direct Connection Tall chrome valve covers. 383-440- 318-360- 3.9 V6 $300.00 per set + shipping .I also have about 10 sets of big block and about 7 sets of small block .They sell from $275.00 down to $175.00 .All come with chrome bolts and caps and push in breathers . more infor call 540-337-4310 e-mail mosweethemi@yahoo.com
#2384493 - 10/09/17 01:27 PM HURST B Body Ramrod and Super shifter 4 Speed Rods [Re: mosweethemi]
davesmopars Offline
Loc: cheshire, ct
In nice shape
100.00 plus shipping
#2384643 - 10/09/17 05:24 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
Plumb Wired Offline
Loc: Blue Ridge, VA
Koni 8212 1123 SPA1 double adjustable shocks
Stroke: 7.00" Max Length: 19.50" Min Length: 12.50" Ride Height: 16.00"
w/ Eibach 14" 130lb. springs, very good condition, $650 shipped
PayPal (+3%) & USPS Money Orders accepted
email: mgray0918@verizon.net or pm me thru Moparts
Thanks,
Mike Gray
Edited by Plumb Wired (10/11/17 08:33 AM)
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
#2384645 - 10/09/17 05:25 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
Moroso #65000 4150-4500 2" carb adapter w/ Mr. Gasket #6004 Dominator safety plate and usable gaskets, used, very good condition, $50 shipped
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
#2384646 - 10/09/17 05:25 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
Aeromotive Fuel Filter #12612 -10AN bulkhead w/ 100 micron filter, brand new, only opened for pic, mounts inside your tank or cell, $70 shipped
Thanks,
Mike Gray
Edited by Plumb Wired (10/11/17 08:35 AM)
RIP Monte Smith
aka: OutlawFish
#2384647 - 10/09/17 05:26 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
9.00" - 9.56" Deck R3/Weber Belt Drive Motorplates, water jet cut from 1/4" T6061 aluminum. 36" wide centered for tube chassis application or marked for A-Body offset. Can be trimmed to fit any application. Use this plate along with Brian Smith (Smith Innovation) water pump spacers to complete the set up. Only 1 remaining in stock $175.00 shipped
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
24,897 Registered Members
184,175 Topics
Battery Cap Color
by 340wedge
37 minutes 47 seconds ago
Arrington Performance
by Michael
Today at 10:24 PM
some mighty expensive rust
by flypaper
Today at 10:05 PM
numero uno hemi cuda 3 mill
by flypaper
Today at 10:01 PM
