Page 2 of 5 < 1 2 3 4 5 >
#2380607 - 10/02/17 12:51 PM New Cloyes double roller adjustable timing chain for Mopar [Re: moparts]
johnnyd Offline
Loc: Boston, MA
New Cloyes double roller adjustable timing chain for big block B/RB Mopar $150
more pics:
https://boston.craigslist.org/sob/pts/d/new-cloyes-double-roller/6315023110.html
#2380609 - 10/02/17 12:52 PM Fire Core angled boot spark plug wires B/RB big block [Re: moparts]
johnnyd Offline
Loc: Boston, MA
Fire Core angled boot spark plug wires for BBM with aluminum holders. HEI cap style. Slightly used but great condition 440 400 451 383 SOLD!
more pics:
https://boston.craigslist.org/sob/pts/d/fire-core-angled-boot-spark/6315020699.html
Edited by johnnyd (10/08/17 10:58 PM)
#2380610 - 10/02/17 12:53 PM ARP big block main studs [Re: moparts]
johnnyd Offline
Loc: Boston, MA
ARP big block main studs. Mock up use only ****SOLD***
Thanks Moparts!
Edited by johnnyd (10/17/17 07:40 AM)
#2380611 - 10/02/17 12:54 PM New Indy 440-1 intake valves set of four. 2.19 $40 [Re: moparts]
johnnyd Offline
Loc: Boston, MA
#2380613 - 10/02/17 12:55 PM ATI Performance Products 917120 7" Harmonic Damper [Re: moparts]
johnnyd Offline
Loc: Boston, MA
ATI Performance Products 917120 7" Harmonic Damper For Big Block Mopar new condition. Possibly mas used as mock up before I got it. In original box. SOLD!
more pics
https://boston.craigslist.org/sob/pts/d/ati-performance/6315081944.html
Edited by johnnyd (10/08/17 10:59 PM)
#2380614 - 10/02/17 12:56 PM MSD big block Mopar distributor 8536 [Re: moparts]
johnnyd Offline
Loc: Boston, MA
MSD big block Mopar distributor 8536 440 B/RB with cap and rotor
$250
more pics:
https://boston.craigslist.org/sob/pts/d/msd-big-block-mopar/6315089341.html
#2380622 - 10/02/17 01:04 PM Indy 440-1 rocker arms [Re: moparts]
johnnyd Offline
Loc: Boston, MA
Used set of four rockers covering each style Indy 440-1 Rockers. These are the Indy roller tip rocker arms for the 440-1 head. Perfect for spares! Two exhaust rockers and two intake rockers for each side. $65 shipped for all 4 rockers. Don't get caught at a race with a broken rocker and no spare.
#2380628 - 10/02/17 01:09 PM Re: MSD big block Mopar distributor 8536 [Re: johnnyd]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
nos direct connection v8 blue ignition wire set$SOLD
cowgerwilliam035@gmail.com
Edited by Joesixpack (10/04/17 09:25 AM)
#2381015 - 10/02/17 10:53 PM Small Block Crow Solid Roller Cam - Used [Re: wupracing]
Rocket Offline
Loc: CT
I have a Crower solid roller in great condition. This was used in a street strip engine for a couple of summers. Excellent street roller. Strong midrange power. Part number is 31406Specs from Crower are as follows:
Lobe center 112
Advertised Duration: Intake / Exhaust 270 / 280
Duration @ .050" Lift: Intake / Exhaust 236 / 246
Lobe Lift: Intake / Exhaust .367 / .365
Rocker Ratio: Intake / Exhaust 1.5 / 1.5
Gross Valve Lift: Intake / Exhaust .550 / .548
Low RPM 2500
Peak HP 6000
Redline 6500
Level 4 camshafts are designed for heavily modified engines. They have a definate lope at idle and are best suited for dual purpose hot street/drag strip, hot marine and oval track applications.
Recommended Modifications
Headers, dual exhaust, large cfm carburetor, performance ignition and increased compression of 10.25:1 and above is required. Cylinder head modifications would be beneficial. Use with automatic transmission with high stall torque converter or manual transmission. Close attention to proper ring and pinion gear set and tire diameter is imperative.
Product Characteristics
Definate lope at idle. These grinds exhibit strong mid-range to top end toque and horsepower.
Price is $200 shipped in the lower 48 states.
#2381062 - 10/03/17 12:16 AM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
Sburke Offline
Loc: utah
BB 727 W/ BRAKE New. Zero runs built by A&A. Have spec sheet of everything done.
8 inch billet convrter.
Winters race shifter
Paid over 5800 for all.
Would like to get 3800.
Consider offer.
#2381065 - 10/03/17 12:22 AM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
Sburke Offline
Loc: utah
440
Bored out .060
Weisco forged pistons
Forged rods
Crower Ultra Action Performance Level 5 Camshafts 32414
Summit Racing Part Number:CRO-32414
Cam Style: Mechanical roller tappet
Basic Operating RPM Range: 3,750-7,750
Intake Duration at 050 inch Lift: 262
Exhaust Duration at 050 inch Lift: 268
Duration at 050 inch Lift: 262 int./268 exh.
Advertised Intake Duration: 304
Advertised Exhaust Duration: 310
Advertised Duration: 304 int./310 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.650 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.624 in.
Valve Lift with Factory Rocker Arm Ratio: 0.650 int./0.624 exh.
Lobe Separation (degrees): 106
Intake Valve Lash: 0.026 in.
Exhaust Valve Lash: 0.028 in.
Harland Sharp roller rockers
Cloyes Hex-A-Just Timing Set
Crowder roller lifters
Team G manifold.
Ported and polished 452 cylinder heads Crowder valve springs
Balanced and blueprinted
Asking 2900
Ran 11.80 in 3800 lbs 65 coronet
#2381066 - 10/03/17 12:23 AM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
Sburke Offline
Loc: utah
Rebuilt manual valve body. Has deep pan. Red line clothes and band.
Also have Hughes 4500 stahl convertor.
Asking 700 for transmission
Asking 400 for torque converter.
Need to let go
#2381067 - 10/03/17 12:27 AM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
Sburke Offline
Loc: utah
New 850 alcohol carb built by Ken Jones Performance.
Asking 600
#2381290 - 10/03/17 02:03 PM 64-65 Plymouth Hood AFX Scoop [Re: Sburke]
sixpacksteve Offline
Loc: n.y.
selling hood.
real Nice shape! had a fab air cleaner setup.
can cutout aluminum for you needs.
pm me! $500. prefer local pickup or will be at Mopars at the Valley!
its a Glasstek!
#2381458 - 10/03/17 08:05 PM CSI Carbon Fiber Shield 727 [Re: moparts]
Vincenzo Offline
Loc: Calcutta, Ohio
Like new condtion, missing one bolt and bushing. Out of date for NHRA. $300 plus the ride. Please feel free to ask any ???'s I'm at 43920 thanks
If you're not livin on the edge, you're taking up too much space.
#2381509 - 10/03/17 09:49 PM 493 RB Rotating assembly [Re: Vincenzo]
fbs63 Offline
Loc: NW Indiana
493 RB rotating assembly. Eagle crank, Crower billet I beam rods,Ross 4.350 bore flat top pistons and pins,King bearings. Very low use.
$1650 shipped in the lower 48. PM here,text or call 7zero8-207-five374
Edited by fbs63 (10/18/17 08:35 AM)
#2381519 - 10/03/17 10:03 PM New Edelbrock MW Victor CNC ported heads [Re: fbs63]
fbs63 Offline
Loc: NW Indiana
New Edelbrock MW Victor CNC ported heads. New castings CNC ported. New 2.20 Intake and 1.81 Exhaust valves. All new Comp Ti retainers,10 deg keepers,Roller springs good to .750 lift and seals. Includes RB valley cover. 73cc chamber. Will be assembled for buyer. Have flow sheets. Flow 312@.500 lift,359@.700 Intake. Real,not inflated flow numbers. $2500.00 shipped in the lower 48.PM here,text or call 7zero8-207-five374 SOLD
Edited by fbs63 (10/06/17 08:28 PM)
#2381524 - 10/03/17 10:09 PM Edelbrock RB Super Victor intake [Re: fbs63]
fbs63 Offline
Loc: NW Indiana
Edelbrock RB Super Victor intake. Dominator flange, fully ported with blended spacers. Very nice piece. $400.00 shipped in the lower 48. PM here,text or call 70eight-two07-5374 SOLD
Edited by fbs63 (10/06/17 08:29 PM)
#2381551 - 10/03/17 10:44 PM New BB JE pistons,pins and rings [Re: fbs63]
fbs63 Offline
Loc: NW Indiana
New BB RB JE pistons. 4.440 bore,1.850 compression height. Trend tool steel .990x2.930 pins. Total Seal AP 4.440 bore ring set. All New. $350.00 shipped in the lower 48. PM here, text or call 708-two07-five374
Edited by fbs63 (10/03/17 10:44 PM)
#2381606 - 10/04/17 01:43 AM Re: New BB JE pistons,pins and rings [Re: fbs63]
493_john Offline
Loc: Chesterfield Twp. Mi.
Indy cast Predator tunnel ram, new..not used...not milled...not ported, comes with 2x4500 top, 1/2 plenum spacer, A.R.T. bellcrank linkage, magnafuel 4 port regulator with lines to carb and 2 Holley 1050 8896-1 carbs with tr floats and Quick Fuel float bowls with sight glass.
$1950 text for pics john 586-222-2728
1.27 60ft on Radials 9.11 @ 147 3410 lbs.
24,900 Registered Members
184,278 Topics
RIP Gord
by ChryCoGuy
Today at 02:16 AM
Thanks to Mopar Muscle and Moparts.
by 383man
Today at 01:33 AM
340 Re-Rebuild or take my chances
by hyefatman
Today at 12:04 AM
Carburetor spacers for heat
by RAY1969CARS
Yesterday at 10:35 PM
