trying to pin point a front end clunck #2381330
10/03/17 05:44 PM
10/03/17 05:44 PM
bethlehem pa
mikemee1331 Offline OP
bethlehem pa
69 B-body with 440.
i recently re-bushinged (is that a word?) the front end of my Road Runner. everything was pretty much shot. i also replace the original torsion bars with the next heavier (GTX) ones. all the bushings were replaced with poly except the lower control arms and there i used rubber(to avoid the dreaded squeek)and at the suggestion of the machine shop that replaced them. all the 'hard' parts have less than 3000 miles on them and all seemed good.
now heres the issue. when i got everything back together i didn't have to mess with ride height too much as i re-installed the adjusters to the same location they were in when i pulled it apart.
the back end of the car sits high (re-sprung spring) to clear my tires, 29x15x15 fatties, and i wanted to level out the front some so i wasn't going down the road like this - \. i raised up the front via the torsion bars but now i have a clunk i didn't have when it was lower. i have searched and searched and retightened everything but i can't isolate it. everything is nice and tight. the noise has nothing to do with cornering or hitting bumps. it's like a popping/flexing noise like the shocks are loose in the front.
ANY suggestions would be helpful as i'm at a loss. just please no negatives about the ride height as i like the way it looks.
thanks guys!
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381333
10/03/17 06:10 PM
10/03/17 06:10 PM
Andrewh Offline
Andrewh  Offline
but can you consistently reproduce the clunk, and if so when do you get it.
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381334
10/03/17 06:12 PM
10/03/17 06:12 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
The first thing I would do is to look for any shiny spots that would indicate a point of contact. You can also try putting a small amount of grease on anything that looks like it might be close clearance as the suspension moves through it's full range of motion and see if you get a grease smear. As for ride height all I am going to say is that any new spring or re-arched leaf spring will tend to settle or take a set over the next few months. This is true for coils, torsion bars or leaf springs so don't be surprised if the car sits a little lower in time. In so far as squeaks are concerned I've found that you're much more likely to get squeaking from polys in the UCA's than you are in the lowers. I still use rubber in the lowers myself, but I have used poly on the lowers before and didn't have any problems with them.
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381348
10/03/17 06:37 PM
10/03/17 06:37 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Have a helper grab the roof and rock the car left to right. Grab each suspension point while it is being rocked. You will feel any point that is loose.
Doug
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381353
10/03/17 06:43 PM
10/03/17 06:43 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
K frame bolts tight? Don't ask me how long I chased that little annoying sound!!!! Put the wife in the car and had her steer left then right. The k frame was moving just the slightest bit. Clunk! You could barely see it! Cinched them down alls quiet!!
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381362
10/03/17 06:59 PM
10/03/17 06:59 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Sounds like you installed poly strut bushings. The lip that fits into the k-member can make a snapping sound when the front suspension articulates up and down a bunch like into and out of driveways.
Try loosening them, put grease around that area and bushing and re-tighten up with suspension at ride height.
Re: trying to pin point a front end clunck [Re: autoxcuda] #2381386
10/03/17 08:14 PM
10/03/17 08:14 PM
you rebushinged it & it was good then you right away lowered it & it clunked OR you rebushinged it/lowered the ride height at the same time & now it clunks? As said I would loosen everything (as needed) & lube the needed areas then retighten.
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381398
10/03/17 08:30 PM
10/03/17 08:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Got a Go Pro camera?
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381401
10/03/17 08:35 PM
10/03/17 08:35 PM
bethlehem pa
bethlehem pa
all good stuff!
1)"can you consistently reproduce the clunk, and if so when do you get it." it seems to be on area of the road that make no sense what so ever. stepping on or letting off the gas does make it happen though.
2)"The first thing I would do is to look for any shiny spots that would indicate a point of contact" tried this and couldn't readily find any.
3)"any new spring or re-arched leaf spring will tend to settle or take a set over the next few months. This is true for coils, torsion bars or leaf springs so don't be surprised if the car sits a little lower in time." it's been 1 1/2 years since the springs and front were redone.
4)"Have a helper grab the roof and rock the car left to right" yep, hopefully this weekend if my son doesn't have to work.
5)"K frame bolts tight" never thought of that as i didn't have it off but it is certainly worth looking at.
6)"Try loosening them, put grease around that area and bushing and re-tighten up with suspension at ride height." i really like the sound of this. i was never really happy with the fitment and it seems like the noise is when the rode is unevenish and not really when it's bumpy. not related to bumps at all actually.
Robert - all was well until i raised the car up a few inches in the front. i never lowered it. the issue started this summer (a year after the rebuild) when i raised the front to try and level it some.
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381404
10/03/17 08:41 PM
10/03/17 08:41 PM
I don't know where I go the "lowering" from. I would do #6
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381407
10/03/17 08:48 PM
10/03/17 08:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it happens when you get off and on the gas I would look at the motor mounts and trans mount. Just because it happened after you redid the front end doesn't necessarily mean it's front suspension related.
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381420
10/03/17 09:03 PM
10/03/17 09:03 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Once you decide where you want your ride height loosen the upper & lower control arm bushings preferably on a drive on lift,jounce the front end up n down & retorque the bushings at that static ride height & reevaluate it.Also retorque the K-frame bolts.
Re: trying to pin point a front end clunck [Re: 71GTX471] #2381425
10/03/17 09:13 PM
10/03/17 09:13 PM
IN
ahy Offline
ahy  Offline
IN
As mentioned, it is important to loosen everything up when significantly changing ride height. Otherwise the bushings can be pre-loaded and overload on bumps.
I would add to the suggestions, careful inspection of all bushings for any tears.
Re: trying to pin point a front end clunck [Re: 71GTX471] #2381429
10/03/17 09:15 PM
10/03/17 09:15 PM
bethlehem pa
bethlehem pa
i like this too. it has to be realigned anyway.
stumpy, all 3 are newish but i did check them any way up
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381477
10/03/17 10:45 PM
10/03/17 10:45 PM
Andrewh Offline
Andrewh  Offline
other thing that it might be sounds like u joints.
giving it gas and letting off makes me wonder about that too.
Re: trying to pin point a front end clunck [Re: stumpy] #2381561
10/04/17 12:55 AM
10/04/17 12:55 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Boy, aint THIS the truth...
Many times in the past I have had something conk out moments after doing something else unrelated.
I rotated the tires, now I have bad breath. I should have left the tires where they were.
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381563
10/04/17 12:57 AM
10/04/17 12:57 AM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Did you grease the Torsion bar sockets, they can clunk if they are dry.
11B40
Re: trying to pin point a front end clunck [Re: JonC] #2381579
10/04/17 01:39 AM
10/04/17 01:39 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
This right here is your noise. Factory packed them with grease. They need that to be quiet.
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381829
10/04/17 03:26 PM
10/04/17 03:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Did you grease the hex ends of the T-bars?
Re: trying to pin point a front end clunck [Re: mikemee1331] #2381885
10/04/17 06:00 PM
10/04/17 06:00 PM
bethlehem pa
bethlehem pa
Hmmm... i can not say with 100% certainty that i greased the front t-bars. i know i did the back but i'll have to double check the front.
U-joints i did think about and will check but they too are newish and the clunk is most definitely in the front. i can feel it in the steering wheel.
