Re: Aftermarket RB Block
[Re: 10sec440]
#2381039
10/03/17 01:37 AM
10/03/17 01:37 AM
Superfreak
Superfreak
It's going to take a lot of looking, plus with the Canadian peso you will pay dearly if can find one.
[Re: 10sec440]
#2381093
10/03/17 04:53 AM
10/03/17 04:53 AM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
Yeah a lot of us feel that pain Funny but a mate is working up to buy a new block/short motor. A 409W chev aluminium block . Huge demand for those 409s i guess Dang canadian peso - we have aussie peso's . Don't get me started on freight
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 10sec440]
#2381266
10/03/17 02:43 PM
10/03/17 02:43 PM
Posts: 11,483 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Tony is making it tough to try to do anything serious and remain loyal at the same time. Aftermarket is not picking up the slack.
[Re: fbs63]
#2381436
10/03/17 09:29 PM
10/03/17 09:29 PM
Posts: 43,095 Bend,OR USA
Cab_Burge
. You can call Chicago Connection for an iron block. They are a distributor of the block MM was selling. I ordered a compact graphite iron 4.500 bore wedge block from Billy Mitchells (SP?) company when they owned or where in partners with World Products, I waited a long time before they cancelled making them due to not having enough orders. I had placed a order with Dave Koffel for a Koleno high nickel cast grey iron block and ended up cancelling it when he called to say it was ready to ship, stupid me One in the hand is way better than one on order I placed another order with Dave later two years later and got it several years later Dave had said that casting iron Mopar race blocks was a black art according to what he had seen and heard while working at Chrysler and seen later on both the Koleno and World iron blocks I have talk to the guys at Chicago Connection for another iron block but I think I will wait until they have several bunches machined and in use before stepping forward on them
[Re: 10sec440]
#2381596
10/04/17 03:00 AM
10/04/17 03:00 AM
Posts: 4,269 Morrow, OH
markz528
Morrow, OH
I have a (The Block) that I bought from Muscle Motors. Although MM was involved in testing the blocks, they were not making them. The sourcing of these blocks has not changed. They are available from several vendors.
[Re: markz528]
#2381600
10/04/17 03:18 AM
10/04/17 03:18 AM
Cab_Burge
Have you used it yet? If so how was it and how much extra machine work was needed to make it useable for your deal? Last thing is it a RB or B wedge or a Hemi block and what size bore was it to start with? I'm still in the market for another good cast iron, not aluminum, race block Thanks in advance for your help on this
[Re: Cab_Burge]
#2381875
10/04/17 05:35 PM
10/04/17 05:35 PM
markz528
Morrow, OH
Have you used it yet? If so how was it and how much extra machine work was needed to make it useable for your deal? Last thing is it a RB or B wedge or a Hemi block and what size bore was it to start with? I'm still in the market for another good cast iron, not aluminum, race block Thanks in advance for your help on this Its a RB 505. I went 0.030 over as it will be a street engine. Can't comment on the machining as I bought it as an assembled shortblock. I hope to get the motor fully assembled and on the dyno by the end of the year or very early next year.
[Re: markz528]
#2381890
10/04/17 06:09 PM
10/04/17 06:09 PM
Cab_Burge
Thanks for the help I'm going to assume that it is bored to 4.350 with a 4.250 stroke, is that correct?
[Re: markz528]
#2382200
10/05/17 12:55 AM
10/05/17 12:55 AM
Posts: 1,278 Mission BC
10sec440
Mission BC
I have a (The Block) that I bought from Muscle Motors. Although MM was involved in testing the blocks, they were not making them. The sourcing of these blocks has not changed. They are available from several vendors. Which vendors? Thanks.
[Re: Cab_Burge]
#2382401
10/05/17 01:53 PM
10/05/17 01:53 PM
markz528
Morrow, OH
Thanks for the help I'm going to assume that it is bored to 4.350 with a 4.250 stroke, is that correct? I didn't put it in the post cause I didn't want to guess but quite sure that is correct. It is a 4.25 stroke - stock bore 0.030 over.
[Re: 10sec440]
#2382403
10/05/17 01:54 PM
10/05/17 01:54 PM
markz528
Morrow, OH
I have a (The Block) that I bought from Muscle Motors. Although MM was involved in testing the blocks, they were not making them. The sourcing of these blocks has not changed. They are available from several vendors. Which vendors? Thanks. Don't quite remember but if you search the subject here on Moparts they have been listed. I do believe Chicago Connection was one.
[Re: 10sec440]
#2382405
10/05/17 02:03 PM
10/05/17 02:03 PM
Posts: 10,019 MN
JERICOGTX
MN
Just curious, as to why bother with a iron block when aluminum blocks are available as a option? I can see if you are running a class that requires iron.
69 GTX
68 Road Runner
[Re: 10sec440]
#2382451
10/05/17 02:57 PM
10/05/17 02:57 PM
Posts: 10,019 MN
JERICOGTX
MN
You could always HardBlock the aluminum block to keep it from moving around. I know people that have done it.
69 GTX
68 Road Runner
