MSD 6-Hemi wiring #2380795
10/02/17 08:01 PM
10/02/17 08:01 PM
cbusters Offline OP
cbusters  Offline OP
Started working on the harness hookup for my 08 5.7. Have everything except the crank sensor worked out. The plug is a different size and definitely won't slide on the sensor. MSD Tech says there is nothing wrong with their harness. The sensors I found online look just like mine for a few different years both ways. I am at the lower rear of the block on the passenger side, and the harness plug says "crank". Here is a photo of the plug and sensor, side by side and you can see the difference in sizes. Any ideas?
Re: MSD 6-Hemi wiring [Re: cbusters] #2381008
10/03/17 12:40 AM
10/03/17 12:40 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You'll need a crank sensor for 03-06 5.7 to work with their harness.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: MSD 6-Hemi wiring [Re: 71yelladustr] #2381030
10/03/17 01:08 AM
10/03/17 01:08 AM
cbusters Offline OP
cbusters  Offline OP
Thank-you!
