Page 1 of 9 1 2 3 4 5 6 7 8 9
37 Dodge PU - Change in Direction #945454
03/07/11 07:15 PM
03/07/11 07:15 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
The problem with letting a project sit too long after it goes thru mock-up is that plans can change.
When I did the initial setup on the 37 Dodge several years ago the plan was to build a Street Rod with most of the bells and whistles (AC/Cruise/Power Windows/mild engine/SB 727/highway gears etc).
I actually even got the engine built......but ended up with a bit more compression and a lot more cam than I originally planned on. It sounds especially good thru open headers ....just ask the neighbours
I’ve collected some more parts and have re-thought the whole Street Rod thing and decided to head in a more performance oriented build and lose a lot of the creature comforts like AC, cruise and Power Windows.
The first step in that direction is getting rid of the Nova 10 bolt with 3.08s (yeah I know .......but it was the right width and available when I mocked it up). The new rear end will be this 69 B Body Dana 60 with 4.56s and Powr-Loc.
I still want to actually cruise down the highway and after some research over the last few days I figured a 518 would be the ticket to do that. Ironically I end up with slightly better ratio with the OD and 4.56s than I would have with the 3.08s, plus the advantage of a lock up convertor (if I decide to go with that version). A friend of mine set me up with this empty case so I can modify the templates I made for the floor to make room for the larger OD section of the trans. I’m glad I only got to the cardboard template stage instead of actually bending and welding metal. I’m currently in the process of looking for a good or rebuildable 518, but have time for that.
With the Dana and Dual exhaust there is not a lot of room under the truck for a fuel tank. Rather than run a modern fuel cell in the bed I sure am considering cleaning this up and using it (with the proper modifications and suitable mounting brackets).
Anyway with some luck I should get the truck in the shop in the next couple of months and re-do some of the original mockup work and get it a bit closer to moving under its own power.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 37 Dodge PU - Change in Direction [Re: Mike P] #945455
03/07/11 09:49 PM
03/07/11 09:49 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Awesome project!
Re: 37 Dodge PU - Change in Direction [Re: B1arno] #945456
03/07/11 10:23 PM
03/07/11 10:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you want to see what tire sizes and gear ratios do to your set up play with this. Set your final drive at .65 for an OD trans. http://vexer.com/automotive-tools/speed-rpm-calculator
Re: 37 Dodge PU - Change in Direction [Re: Mike P] #945457
03/07/11 11:24 PM
03/07/11 11:24 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
Cool ride, heres mine that Im working on right now. The entire drive-train is all 69 Road Runner. It has the mustang II front end and drives super nice and is a 4 speed to boot! Lots of fun, I've been looking for small parts and weather strip and have had no luck finding much.
Anyways, just wanted to share~
Re: 37 Dodge PU - Change in Direction [Re: High Impact] #945458
03/07/11 11:25 PM
03/07/11 11:25 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
another~
Re: 37 Dodge PU - Change in Direction [Re: High Impact] #945459
03/07/11 11:28 PM
03/07/11 11:28 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
Last one. All these pic's were taken the day before I bought it. Lots of detail work has taken place since and money spent. I'll show current one's later when the snow melts!!
Re: 37 Dodge PU - Change in Direction [Re: High Impact] #945460
03/07/11 11:52 PM
03/07/11 11:52 PM
lisbon,ohio
beesting Offline
Still a member
beesting  Offline
Still a member
lisbon,ohio
your truck is looking good heres a pic of my 38 has a 81 dodge mirada drive tran 360/auto posi 3/55s
high impact try roberts motors for parts where i purchased mine
Re: 37 Dodge PU - Change in Direction [Re: beesting] #945461
03/07/11 11:56 PM
03/07/11 11:56 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, www.robertsmotorparts.com for weatherstripping. They are actually Mopar people that know these 30-late 50s Mopars. Gene
Re: 37 Dodge PU - Change in Direction [Re: Mike P] #945462
03/08/11 11:45 AM
03/08/11 11:45 AM
E
earlymopar Offline
earlymopar  Offline
E
Mike: I wasn't sure why you were considering the fuel tank in the bed. I mocked up a 20 gallon aluminum fuel cell on my frame (also 37 Dodge) and it fits fine under the bed.
FYI. Even though it doesn't look like you're needing any 37 Dodge pickup parts, I'll be selling a few pieces soon.
Best of luck.
- EM
Re: 37 Dodge PU - Change in Direction [Re: Mike P] #945463
03/08/11 11:18 PM
03/08/11 11:18 PM
Minnesota
PocketThunder Offline
Minnesota
Mike, what are you using for a frame? Post pics if you would please.
Paul
69 Charger R/T. California car, 99 99 Special Order paint car, Omaha Orange. Original Paint, Interior, drivetrain, etc..
Re: 37 Dodge PU - Change in Direction [Re: PocketThunder] #945464
03/09/11 05:48 AM
03/09/11 05:48 AM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Paul it’s the original frame that has been partially box where the Mustang II front suspension was added. When I get to the point of pulling the body off I will go ahead and box the rest of it.
I’m looking at keeping the rear suspension leaf spring but redoing the cobbled hangers the PO had built. I’ll probably change out the original spring packs for something a little softer and build a set of Cal Tracs for it......I’d kind of considered ladder bars but don’t know if I want to give up the ground clearance for it.
EM I’m considering/planning on running a full exhaust to the rear bumper and was kind of considering bringing the tail pipes together in the center of the rear. Now that I have the keg it also makes a good excuse to use it. I remember back in the late 50s-early 60s when the keg gas tanks were popular in a lot of that era’s hot rods. It’s even period correct LOL.
Stumpy I’ve used that calculator before, it’s fun to play with but not really my favourite to do real calculations with.
Anyway I ordered the trans adaptor yesterday so when I get some time I'll bolt the 518 case to my spare Hemi and get start figuring out the Fire wall and floor (again).
Re: 37 Dodge PU - Change in Direction [Re: Mike P] #945465
03/09/11 11:29 AM
03/09/11 11:29 AM
Minnesota
Minnesota
Paul it’s the original frame that has been partially box where the Mustang II front suspension was added. When I get to the point of pulling the body off I will go ahead and box the rest of it. keg it also makes a good excuse to use it. I remember back in the late 50s-early 60s when the keg gas tanks were popular in a lot of that era
EM I’m considering/planning on running a full exhaust to the rear bumper and was kind of considering bringing the tail pipes together in the center of the rear. Now that I have the’s hot rods. It’s even period correct LOL.
What MustangII front suspension did you buy? I'm green in this dept and have no idea which one to buy.
I have the same truck and would like to do the same project someday. thanks!
Paul
Re: 37 Dodge PU - Change in Direction [Re: PocketThunder] #945466
03/09/11 02:55 PM
03/09/11 02:55 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Paul I really don't know who's front end is under it that part was done when I bought the project. By me buying it I did save it from having a Ford 2.8 V6/C3/4 bolt 8" Mustang II drive train. Here is a picture of the suspension as I was starting the Hemi swap.
EM the one part I am hunting for is an inner fender brace for the fron fender one was gone when I bought it.
Re: 37 Dodge PU - Change in Direction [Re: Mike P] #945467
03/10/11 12:16 PM
03/10/11 12:16 PM
E
earlymopar Offline
earlymopar  Offline
E
Is this the piece that attaches to the frame and then extends out to the front lower edge of the fender? Drivers side or passenger?
Re: 37 Dodge PU - Change in Direction [Re: earlymopar] #945468
03/10/11 02:20 PM
03/10/11 02:20 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Cool project! Heck, even on my car my plans waffled around 1000 times. Eventually you just gotta pick a direction and commit.
Re: 37 Dodge PU - Change in Direction [Re: DaytonaTurbo] #945469
03/10/11 04:30 PM
03/10/11 04:30 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
EM This is the part I'm looking for. It attaches to the grill/radiator support curves under the bottom of the fender, then attaches to the outer edge of the wheel well.
As far as I know they are the same for either side.
Re: 37 Dodge PU - Change in Direction [Re: Mike P] #945470
03/10/11 09:37 PM
03/10/11 09:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Just looking at that part, it has to be a left or right. The end that bolts to the rad support has an ear extending towards the rear. Past experience with these old Mopars tells me the other side will be a mirror image with the ear also extending towards the rear. If the one you have is for the right side, you need a left side one (or the other way around) or the brace will fit too far forward or too far backward to match up to the fender hole. Gene
Re: 37 Dodge PU - Change in Direction [Re: poorboy] #945471
03/10/11 10:53 PM
03/10/11 10:53 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
I angled it for the picture to give a better idea on what it looks like. When you look at it straight on it appears to be symmetrical i.e. no bends or twists in either direction. As near as I can tell in a dark shed and working around the tire it fits equally well on either side.
The ear you see is a bolt on part (and note there is a hole also drilled on the close side of the bracket). You may be correct but as far as I can tell I believe they are the same.
Re: 37 Dodge PU - Change in Direction [Re: Mike P] #945472
03/11/11 11:27 AM
03/11/11 11:27 AM
E
earlymopar Offline
earlymopar  Offline
E
I do have 2 of those (a pair) but was not planning on breaking up the set. PM me and we can talk about this further.
- em
Re: 37 Dodge PU - Change in Direction [Re: earlymopar] #945473
04/10/11 03:45 AM
04/10/11 03:45 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
all these trucks are kool
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
