Page 1 of 6 1 2 3 4 5 6 >
#2379606 - 09/30/17 09:44 PM Mopar Transmission For Sale - 4th Quarter
moparts Online   crying
#2379877 - 10/01/17 10:35 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
moparjoe360.4 Offline
Loc: Ohio
64-65 Hemi STEEL bellhousing, casting #2463236, all treads look good. I'm listing for my dad, pm me here for his contact info or with questions. Asking $900 OBO but he's negotiable.
#2380234 - 10/01/17 07:51 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
JamiePasson Offline
Loc: Sugarloaf, PA. USA
PASSON PERFORMANCE INTRODUCES 18 SPLINE HEMI 4 SPEED OVERDRIVE A-833 TRANSMISSIONS!
AVAILABLE AS A COMPLETE BOLT IN UNIT OR JUST A GEARSET CONVERSION KIT.
INTRODUCING THE PASSON PERFORMANCE HEMI 4 SPEED OVERDRIVE
Tire Size RPM Speed Rear End Ratio
28 " 3248 65 m.p.h. 4.10 : 1 1:1 Gearset
28 " 2580 65 m.p.h. 4.10 : 1 Passon Performance Overdrive .80:1
21% DROP IN CRUISING RPM!!!
Stock--------------- Overdrive
1st 2.65 : 1---------- 2.66 : 1
2nd 1.93 : 1----------1.59 : 1
3rd 1.39 : 1---------- 1.00 : 1
4th 1.00 : 1--------- .80 : 1
Stock Rear Ratio 1:1 4th--------- Adjusted Rear Ratio with Overdrive
3.23:1 ------------------------- 2.58:1
3.54:1 ------------------------- 2.83:1
3.55:1 ------------------------- 2.84:1
3.91:1 ------------------------- 3.13:1
4.10:1 ------------------------- 3.28:1
4.56:1 ------------------------- 3.65:1
Shortcomings of the Original Chrysler Overdrive:
1. Inherently weak due to the undercut mainshaft in the 3rd gear and 3-4 synchronizer area.
2. Limited to a 23 spline input shaft which is another weak spot in a high horsepower car.
3. Floating countershaft in case.
4. Lack of evenly spread gear ratios.
5. Lack of a well matched 1st gear ratio.
Benefits of the Passon Performance Overdrive:
1. Uses a stock 1:1 large journal mainshaft for increased strength.
2. The strength of an 18 spline input shaft.
3. An excellent gear spread to limit excessive RPM drop between shifts.
4. Can be swapped into your factory 4 speed case with just a gasket set.
5. THE ONLY OVERDRIVE on the market that require NO modifications to the vehicle! If your 4 speed fits now (which it does), this will fit!
6. ABSOLUTELY NO:
-CUTTING OR MODIFYING YOUR FLOOR
-CHANGING YOUR DRIVESHAFT
-MODIFYING OR USING SPECIAL BELLHOUSINGS
-INCORRECT DRIVELINE ANGLES
-INCORRECT SHIFTER LOCATION
-HEADACHES or AGGRAVATION
-SPENDING $4500.00!!! BECAUSE IT FITS RIGHT INTO YOUR CASE!!!!
7. Stronger than a factory Hemi 4 Speed due to improved materials and increased root diameter of all gears.
Available as a gearset ($1995.00) or an entire ready to install unit!!! ($3195.00)
NEW 18 SPLINE INPUT SHAFTS, 2.65:1 RATIO
NEW 18 SPLINE 3RD GEARS, 2.65:1 RATIO
They feature back tapered synchronizer teeth, which builds considerable life into the gear. They are made of a 9310 forging which is much stronger than the OEM 8620 material. These are an exact bolt in with no modification necessary.
Our gears are 100% made in the USA.
DON'T SETTLE FOR KOREAN GEARS AND SYNCHRONIZER ASSEMBLIES IN YOUR AMERICAN MOPAR MUSCLECAR!!!
ACCEPT NO SUBSTITUTES! OUR GEARS ARE THE ONLY GEARS MADE IN THE USA!!!!!! OUR QUALITY GEARS HAVE BEEN PROVING THEMSELVES FOR OVER FOUR YEARS NOW.
NEW 9310 2.65:1 HEMI CLUSTER GEARS COMING SOON!!!!!
COMPLETE ALUMINUM A-833 FOUR SPEED CASES.
All Configurations!
A-833 4 speed transmissions, parts and service. Full rebuild service available for ’64-’74 A,B,C,E,F Bodies. I offer 23 spline and 18 spline parts and service and overdrive parts and service as well. We have or can get any A-833 4 speed transmission parts that you may need. Custom transmission configurations built to fit your application. Race or Restoration. Many NOS, new and good used parts available. All cast iron units finished in show quality cast iron finish. We will respond to your messages ASAP .
REBUILT FACTORY HURST SHIFTERS IN STOCK. FROM $149.00
NEW HURST SHIFTERS IN STOCK $289.00
ALL NEW HURST SHIFTER SERVICE PARTS FROM 6.00
SHIFTER LINKAGE RODS FROM $119.00
Z BAR SERVICE KITS FROM $59.00
STEEL REPRODUCTION FLOOR HUMPS FROM $159.00
PEDAL ASSEMBLIES AND PARTS ALL BODYS INQUIRE
STOCK RECONDITIONED FLYWHEELS FROM $199.00
MCLEOD CLUTCH PACKAGES FROM $359.00
RECONDITIONED FACTORY BELLHOUSINGS FROM $259.00
BIG BLOCK STEEL INSPECTION COVERS 10.5” / 11” $89.00
SMALL BLOCK STEEL INSPECTION COVERS 10.5” $79.00
SMALL BLOCK STARTER SHIELDS $39.00
BILLET ALUMINUM HURST SHIFTER MOUNT PADS
WITH THE 3 CORRECT ALLEN HEAD BOLTS $59.00
RESTORED SHIFTER HANDLES FROM $249.00
REPRODUCTION PISTOL GRIP HANDLES FROM $204.00
’67 – 76 A BODY BALLSTUD FRAME BRACKETS $35.00
’66 – ’74 B / E BODY BALLSTUD FRAME BRACKETS $35.00
REPRODUCTION AND NOS SHIFTER BOOTS FROM $49.00
DASH REVERSE INDICATORS $89.00
4 SPD REVERSE LIGHT WIRE HARNESS ’67 UP A BODY $29.00
4 SPD REVERSE LIGHT WIRE HARNESS ’66 UP B / E $36.00
REPRODUCTION WOODGRAIN BALLS $40.00
REBUILT A-833 4 SPEEDS 23 SPLINE FROM $895.00
18 SPLINE FROM $2095.00
TOO MANY PARTS TO LIST!! CALL OR E-MAIL FOR MORE INFO!!
PRODUCTION HAS FINALLY STARTED ON OUR NEW A-855 5 SPEED TRANSMISSION. THE ONLY 5 SPEED TRANSMISSION ON THE MARKET THAT REQUIRES NO CUTTING OF THE VEHICLE. CALL OR EMAIL NOW TO GET ON THE WAITING LIST!!!!
COMPLETE CONVERSION PACKAGES AVAILABLE!
IF YOU DON’T SEE IT, ASK!!!!
WE TAKE VISA, MC AND DISCOVER CARDS FOR YOUR CONVENIENCE
PASSON PERFORMANCE
(570) 401 8949
309 TURKEY PATH
SUGARLOAF, PA 18249
YOUR A-833 SPECIALIST! All we do are A-833 manual transmissions!!!!!! “WE PURCHASE CORES”
www.PASSONPERFORMANCE.COM
OR E-MAIL US AT JAMIE@PASSONPERFORMANCE.COM
Edited by JamiePasson (10/30/17 09:30 AM)
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
#2380255 - 10/01/17 08:09 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
A-body big block 4-speed parts: Included are a 4-speed bell housing #2468372, bell housing inspection cover, big block clutch fork, big block A-body z-bar, new big block A-body z-bar bell housing and frame ball pivots, new ball stud seal, 2 new clutch linkage washers and a new throw-out bearing as shown in the picture. I have had the bell housing, inspection cover and clutch fork media blasted. The bell housing and clutch fork are primed. The inspection cover has been painted gloss black. I have also blasted and primed the z-bar since the photo was taken. $750 for everything. Selling only as a package. I would prefer not to ship but can deliver to the Mopar Nats with a $100 non-refundable deposit. gt340 at yahoo.com
#2380323 - 10/01/17 09:55 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
mrrandyj Offline
Loc: CT
727, 518 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 727, 518, 46RH, and 46RE transmission. The rear servo piston is a 1-piece design that replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. The piston is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. It comes in a kit with a heavy duty stainless steel return spring that will eliminate 1-2 shift overlap, a new seal, and a .075 extra thick retainer made from stainless steel that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This kit fits 67 and newer 727, 518, 618, 46RH, and 46RE transmissions. I also have a kit that fits the early 62-66 727’s. The price for either rear kit is $75.00.
MADE IN THE USA!!!
There is a $8.00 shipping charge per order. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
#2380325 - 10/01/17 09:57 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE DUAL RING FRONT BILLET SERVO KIT
Dual ring billet front servo kits for 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. The front servo is responsible for applying the front band during the 1-2 shift. This servo is based off of the highly desired 71 and earlier Chrysler “small pin” servo that is ideal for use in performance transmissions, only this one is much better. The piston and cover are CNC machined out of solid 6061 billet aluminum and the shaft is CNC machined from prehardened 4140 steel. There are 2 return springs custom made out of stainless steel that will help eliminate the 2-3 shift overlap that these transmissions are known for. There is a custom made metal gapless sealing ring that seals the cover to the case, and also a o-ring in the cover that seals it to the shaft. The o-ring and the gapless ring work together to eliminate internal leakage and allows more oil get to 3rd gear where it is needed most. The piston has 4 total sealing rings, doubling the sealing capacity of the original Chrysler servos. This is a ready to install kit, all the sealing rings and springs are included. The price for this kit is $125.00 plus $8.00 for shipping.
100% MADE IN THE USA
If you have any questions or to place an order my email address is mrrandyj@aol.com
#2380326 - 10/01/17 09:59 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
904 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 1967 and newer 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE Dodge Plymouth Chrysler Jeep or AMC transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1 piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the piston, a heavy duty return spring that will help eliminate the 1-2 shift overlap, a new seal, and a .075” extra thick stainless steel retainer that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This is a complete ready to install kit, no extra parts are needed and it is 100% Made in the USA. The price for this kit is $75.00. There is also a $8.00 per order shipping charge.
#2380329 - 10/01/17 10:02 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
BILLET DUAL RING ACCUMULATORS
These will fit just about any torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RE, and 48RE, almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These are a great upgrade for all the 727s and 904s and are also perfect for replacing the plastic accumulator that Chrysler switched to in the late 80s. The plastic accumulators are known for cracking and causing problems in performance transmissions. I have done these 2 different ways: First is an exact stock replacement, this one will accept all the stock springs whether they go between the case and the piston or the piston and the valve body. These are perfect for the turbo diesel guys that have tighter aftermarket torque converters, or for the person doing a stock type rebuild on a gas transmission. Second is with a built in blocker rod that will stop the accumulator from moving in the bore and firm up shifts. No need to cut down round stock and make a blocker rod anymore, I did it for you. Comes with all 4 sealing rings. The price on these are $45.00 each. There is also a $8.00 shipping and handling charge per order.
These are 100% Made in the USA. If you have any questions or want to place an order email mrrandyj@aol.com Thanks for looking!!!
#2380331 - 10/01/17 10:07 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE FRONT BAND STRUTS AND BILLET BAND ANCHORS
Heavy duty, double thick, billet steel front band strut and billet front band anchor for a Dodge, Plymouth, Chrysler, or AMC 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. This fits from the 1962 727 transmission, all the way up through the 2007 ½ Cummins Turbo Diesel 48RE, and everything in between. The OEM Chrysler front band struts are prone to bending, and the OEM band anchors are known for breaking in high performance and heavy duty applications. The band strut is CNC machined from 1/4” thick steel, which is twice as thick as the factory strut and it is black oxide coated for corrosion protection. The band anchor is also CNC machined from billet steel. Both are made in the USA. The price is $25.00 each, and includes shipping anywhere in the USA.
Email mrrandyj@aol.com
#2380334 - 10/01/17 10:14 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
47RH 47RE and 48RE Billet Rear Servo Kit
High performance, low/reverse billet rear servo kit for a 1994-2007 47RH, 47RE, and 48RE Dodge Cummins Turbo Diesel and SRT10 Ram truck automatic transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the aftermarket shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1-piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the billet aluminum piston, a heavy duty stainless steel return spring that will eliminate the manual 1-2 shift overlap, a new seal, and a extra thick CNC machined billet steel retainer that will not bend around the retaining ring and pop out of the case like the factory retainers do. This is a complete ready to install kit, no extra parts are needed. The price for this kit is $90.00 plus $8.00 for shipping.
#2380352 - 10/01/17 10:49 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
pittsburghracer Offline
Slowride
Loc: PA.
small block 727 transmission for sale. Advertising as a core because it has been sitting inside my house garage for many years and I don't know its history. Located 35 miles NE of Pittsburgh PA. 16229. will not ship but if paid for I will deliver to the Halloween Classic in ohio the end of October. 125.00 PM or jacadamore@gmail.com
1970 Duster
Edelbrock headed 408
6.143@110.89 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
6.001@113.27mph
9.44@138.23
Untitled by John Cadamore, on Flickr
#2380619 - 10/02/17 12:59 PM TCI BBM to powerglide adapter plate [Re: moparts]
johnnyd Offline
Loc: Boston, MA
TCI BBM to powerglide adapter plate. Already trimmed for a dragster and glide. Small crack in between bolt holes- can be TIG'd for easy repair $100
more pics
https://boston.craigslist.org/sob/pts/d/tci-bbm-to-powerglide-adapter/6315013142.html
#2380645 - 10/02/17 01:31 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
64dodge572 Offline
Loc: Ohio
BREWER’S PERFORMANCE, INC, Chrysler 4-speed transmission and parts specialists.
THE MOST COMPREHENSIVE, UP-TO-DATE WEBSITE FOR ALL YOUR 4-SPEED RELATED NEEDS:
www.brewersperformance.com
NEW: Hurst licensed pistol grip shifter, fits 2009-up Dodge Challenger 6 speed, including the new Hellcat. Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. Shifter can be modified for shorter throw, by cutting off the bottom mounting screw/hole. $249.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG-CHALL-6
NEW: Cast iron bearing retainer for 1968-72 18 spline transmissions with 308 front bearing, 4.805" outside diameter, 4.16" bolt circle, replaces cast #C97621/2801892 original retainers, and Mopar Performance P4529697. Gasket and seal included.
http://www.brewersperformance.com/proddetail.asp?prod=BR-621C
NEW: Pistol grip shifter, fits new Dodge Challenger/Charger automatics (and all LX platform cars). Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. $149.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG112
VISIT OUR NEW RESTORATION PARTS SECTION, SAME GREAT SERVICE AS OUR 4-SPEED PARTS:
http://brewersperformance.com/store.asp
WE BUY 4-SPEED TRANMISSIONS & PARTS
NEW LOWER PRICE--Rebuilt OE factory Hurst shifter mechanisms from $149.95
NEW PARTS—We now stock all service parts for Hurst Shifters, see our website:
http://brewersperformance.com/products.asp?cat=132
We are the manufactures of the following parts:
Reproduction 1968-69 Console shift handles for A & B body cars from $240.55
1970 Column/reverse interlock linkage kits for B-body big block and E-body big/small block cars $279.95
Correct 1970 B-body console boot with rectangular opening for pistol grip shifter $89.95
New Big Block bellhousings, heat treated aluminum $329.95, steel dust covers $99.95
67-76 A-body and 66-74 B & E body ballstud frame brackets $39.95 ea
Torque shafts (Z-bars) for all popular A B & E body cars $89.95 ea
A-body big block clutch linkage kits, Hydraulic slave kits also.
Clutch pedal to torque shaft rods A, B & E bodies $59.95
Clutch pedal over center spings $49.95
Clutch pedal over center spring retention pins $19.95
Small block 10.5” bellhousing starter seal $39.95
Big block 10.5” & 11.0” starter shims/seals $12.95
Clutch pedal support firewall stud brackets for 66-74 B & E bodies $19.95 ea
Shifter linkage rod sets for A B & E body cars $124.95-$149.95 set
Transmission linkage operating levers for A B & E bodies $49.95-$56.95 set
Billet steel bearing retainers for 18 spline 4-speeds $129.95
Billet aluminum shifter mounting plates for A, B & E bodies, with all hardware $59.95
Clutch fork pivot brackets $19.95-$29.95
Synchronizer strut keys for 68-9 4-speeds $10.95 ea
Hurst shifter mechanisms to retain your stock Inland shift lever $299.95
Transmission side cover wiring clips, retains backup light wiring $8.95 pair
Conversion torque shaft kits for 10.5” small block bellhousings into 1963-66 A-body cars
We also stock:
New Hurst shifter mechanisms from $219.95
Bearing and seal kits from $99.95
Synchro rings $49.95 set/4
Restored factory Hurst shifter levers from $249.95
New pistol grips from $219.95, lenses, grips & bezels available
Shifter boots from $59.95
Shifter boot bezels from $29.95
Reverse indicator lamps $89.95, wiring harnesses from $29.95
Woodgrain shifter ball $39.95
Rebuilt transmissions from $1099.95
Polyurethane transmission mounts from $59.95
Speedometer cables from $39.95, speedometer pinion gears from $19.95
Torque shaft service kits from $59.95
New flywheels from $199.95, cast crank applications available
Bellhousings for all applications
Centerforce and McLeod clutch packages from $332.07
From one part to complete 4-speed conversion packages, we stock it all! Same day shipping on orders received by 2PM.
We accept Visa/MasterCard/Discover.
BREWER’S PERFORMANCE, INC.
10510 State Route 571
Laura, Ohio 45337
Phone:937-947-4416 or 937-698-4259 9am-5pm Monday-Friday
Fax:937-947-4419 24-7
#2380843 - 10/02/17 07:07 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Goat330 Offline
Loc: Randolph, Ohio--N.E. Ohio
65 big block 727 torqueflite,the one with the rear slip spline.It was rebuilt about 5 years ago and has not been used since then.New solid bands,clutches,all seals and paper are new,also has the later model input splines for the converter.IT wouldn't hurt to freshin the bands and clutchs in some tranny fluid before use.Also has a stock 65 valvebody with the correct rooster comb.I can supply a different VB if that wont work in your car.$700 and local pick-up only.Bill at wmemore@aol.com or PM,Thanks for the free ads Moparts.
#2380844 - 10/02/17 07:08 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Goat330 Offline
I have several slant 6 904s from early 70s darts laying around $20 each.Also have a couple of small block 727s for cores $30 each.Local pick-up only,Bill at wmemore@aol.com or PM,Thanks for the ads Moparts!
#2380845 - 10/02/17 07:13 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Goat330 Offline
Big block pushbutton T-flite with 62-64 trunnion type output shaft. have the parts to put together or a bare case, $50. Local pick-up only,Bill at330-947-3362 or wmemore@aol.com Thanks for the free ads Moparts!
#2380848 - 10/02/17 07:19 PM NEW RAM 10.5 x 23 Spline Clutch [Re: moparts]
GOT6PAK Offline
Loc: Southern California
I bought this clutch for a project and have since sold the project. It is NEW in the box only showing shelf wear. Comes with throw out bearing and alignment tool. Part# is 98776.
Asking SOLD
Located in So. Calif.
PM for any questions.
[img:center][img]https://i.imgur.com/4CIt94e.jpg?1[/img][/img]
Edited by GOT6PAK (10/22/17 01:52 PM)
#2382217 - 10/04/17 11:18 PM Mr. Gasket V gate shifter [Re: GOT6PAK]
Genuinejed Offline
Loc: Spokane,WA
Mr. Gasket V gate inline shifter. Looks to be in good shape. Shifter only, no rods or bracket. Chrome is decent.
Sold! Thanks Moparts
Genuinejed2@aol.com
Edited by Genuinejed (10/22/17 11:43 AM)
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
#2382983 - 10/06/17 01:03 PM 64-65 4 Speed Shifter [Re: Genuinejed]
sixpacksteve Offline
Loc: n.y.
64-65 b body bench seat shifter and handle
real nice shape!
$150+shipping
pm me
the shifter itself can be used for other applications!
SOLD! Thanks Moparts
Edited by sixpacksteve (10/09/17 08:40 AM)
#2382984 - 10/06/17 01:04 PM Re: 64-65 4 Speed Shifter [Re: sixpacksteve]
Loc: n.y.
another pic
25,078 Registered Members
185,716 Topics
What 30 yr old gas in a tank looks like
by AARCONV
Today at 06:26 PM
Honda Brakes Update
by 340SIX
Today at 06:13 PM
carb clean up without disassembly.
by viperakron
Today at 06:13 PM
Go Pats
by JonC
Today at 06:09 PM
