Re: Swaybar strut bushings - Nylon for Less deflection?
[Re: BigBlockMopar]
#2380243
10/01/17 09:57 PM
10/01/17 09:57 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I think the green brick modded some spherical end links to work. I think they used ones off a Viper, rusty memory there.
[Re: BigBlockMopar]
#2380263
10/01/17 10:16 PM
10/01/17 10:16 PM
Posts: 200 Colorado
Bob J
Colorado
Drop links I know this is not Mopar but this is what I run on my Porsche. You can adjust out all the preload with you sitting in the car. The only down side is that you can hear them clank from time to time mainly in parking lots never driving. Love them just use plenty of anti seize.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: Supercuda]
#2380286
10/01/17 11:07 PM
10/01/17 11:07 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I used spherical end links on the front bar on my '71 Sebring back in the '70s. Addco bars and they came from Addco with those links. Worked great and no noise.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: BigBlockMopar]
#2380425
10/02/17 07:07 AM
10/02/17 07:07 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Trying googling for images but didn't find any yet. Did notice this type online, for GM cars; (This will only take just one set of bushings out of the link.) The amount of space is fairly tight between the mounting points of the LCA and swaybar.
[Re: BigBlockMopar]
#2380546
10/02/17 01:15 PM
10/02/17 01:15 PM
Supercuda
About to go away
About to go away
up yours
All you have to do is go to Rock Auto and look at the Viper end links.
They look to be easily shortened if need be as well.
[Re: BigBlockMopar]
#2381300
10/03/17 04:42 PM
10/03/17 04:42 PM
Posts: 1,440 NW Chicago suburban area
Mopar Mitch
Adjusting the sway bar end-link pre-load is important IF you want to get the best balance for the 4-corners. After I've set the 4-corner weight balance, WITH the sway bar end-links disconnected, then I re-attach the end links using extra as-needed same factory metal shims around the bushings so that each end link is near equal in its compression (load) to each other. In other words, you don't want any end-link to have more load than its opposing side... it will have some effect on the corner weight balance which you want to try to keep equal LH-RH (as well as the front and rear sway bears, respectively). IF I could figure adjustable end-links, I will (someday) install them and forget about the multiple shims. I need to look at the Viper setups and others. (Also... adjusting the 4-corner weight balance and the sway bar end links should be done with the car as-driven... driver's weight in driver's seat, if possible).
Reinforcing the LCA end-link tab is helpful... weld on an additional large washer to one side (top ok).
I've also varied (fine-tuned) the end link bushings from all rubber, partial rubber/poly, all poly... per my driving style (AX/HSAX/HPDE).
Over time, the poly bushing can self-destruct when driven very hard (i.e: competition AX/HSAX/HPDE), so, good idea to inspect and replace whenever needed (carry spares with you to the races). Also, carry spare end links... they can eventually break under hard driving/competition.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2381571
10/04/17 01:13 AM
10/04/17 01:13 AM
Posts: 200 Colorado
Bob J
Colorado
Viper Adjustable ends links I need to look at these to see if the length is the same range. If it's not I would think that get the center in a longer length and cut it to size.
[Re: Alchemi]
#2381677
10/04/17 11:26 AM
10/04/17 11:26 AM
Supercuda
About to go away
About to go away
up yours
find some cheap tie rod ends and the appropriate threaded sleeve and nuts at a hardware store - should cost all of $40ish Do you know how stock Mopar endlinks attach?
[Re: Bob J]
#2381678
10/04/17 11:30 AM
10/04/17 11:30 AM
Supercuda
About to go away
About to go away
up yours
Viper Adjustable ends links I need to look at these to see if the length is the same range. If it's not I would think that get the center in a longer length and cut it to size. Yeah, stoopid money $200 EACH for stock replacements $260 for adjustable ones. Wee. Even the OEM MoPar ones are cheaper at RockAuto. The aftermarket replacements at RA are even less. Less than a tenth the price.
[Re: BigBlockMopar]
#2381682
10/04/17 11:39 AM
10/04/17 11:39 AM
Posts: 350 central IL
myduster360
central IL
Moog has some rock hard "problem solver" links, identical to stock Srt-4. several different lengths. They claim its polyurethane but they're very rigid and feel as hard as nylon. K700528 is for a 73 Darthttp://www.moog-suspension-parts.com/moog-k700525
1972 Swinger 3.6L Pentastar Diablo CMR tuner
[Re: moparx]
#2381742
10/04/17 12:59 PM
10/04/17 12:59 PM
Supercuda
About to go away
About to go away
up yours
throwing something out there. is there enough length on the sway bar arms to cut off the factory ends, then mill the remaining ends 90 degrees with corresponding holes to accommodate a "tie rod" style end ? i realize this small amount of shortening will affect the bar rate. the control arm mount could easily be fabbed to utilize this style of mount, and compensate for shortening of the bar. Yeah, you can do that. It gets well outside the realm of cheap though. I don't have a mill so I can buy one and learn how to use it or I can find a competent machine shop and pay them to do it. I can shorten stock Viper end links with my current tool and skill set and wallet contents.
[Re: BigBlockMopar]
#2381782
10/04/17 02:17 PM
10/04/17 02:17 PM
myduster360
central IL
Step 1 Search Ebay for "swaybar links" Step 2Find the design you like and note its application(year/make/model) Step 3 Order off RockAuto 10min later $10-$40 each 2007 Lincoln Navigator
[Re: myduster360]
#2381784
10/04/17 02:24 PM
10/04/17 02:24 PM
Supercuda
About to go away
About to go away
up yours
2004 Viper $15
[Re: Supercuda]
#2381792
10/04/17 02:30 PM
10/04/17 02:30 PM
myduster360
central IL
Perfect!! IF only it weren't 4" too long. Try for the bolt on before hack/weld option
[Re: BigBlockMopar]
#2381810
10/04/17 02:55 PM
10/04/17 02:55 PM
Supercuda
About to go away
About to go away
up yours
You got dimensions on either?
