Page 1 of 2 1 2 >
#2380187 - 10/01/17 07:00 PM Woodworkers, I have a question about sanders
StrokerPost Offline
Loc: Missouri
Tell me about sanders, orbital versus finish sanders, for you guys that make stuff, which is best suited to which job. Thx.
Ken
67 Dart 2 dr post, 308 iron headed 414 SB. Perf 1/4 mi 10.45 @ 127
5 time Monster Mopar race winner...just sayin!!
#2380239 - 10/01/17 07:53 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
Supercuda Offline
I don't use orbital sanders on wood.
I do use a dual action sander, or a belt sander.
I use whatever is cheapest.
#2380247 - 10/01/17 08:03 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
Alaskan_TA Offline
Fluffy Balladeer
Loc: Still moving in.
It depends on the job.
For some you can use several different sanders & possibly even a cabinet scraper or two.
#2380254 - 10/01/17 08:08 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
Paul_B Offline
Loc: Tallmadge, Ohio
I use a 1/4 sheet palm sander for general stuff. Works good, but probably not as fast as an orbital if you’re needing to get things done quick. It was cheaper when I bough it and I’m not doing a bunch of sanding.
I also use a fein ultrasonic tool to sand small hard to reach areas. Don’t use it much, but it always surprises me how well it works.
I do highly recommend a sander that you can attach to vacuum to keep the dust down.
#2380287 - 10/01/17 09:09 PM Re: Woodworkers, I have a question about sanders [Re: Paul_B]
StrokerPost Offline
Loc: Missouri
I will be doing a variety of things, but I will not be doing any fine furniture. Mostly what I'm looking to do is making outdoor furniture out of reclaimed lumber. I don't want a really smooth surface, cause that's not the look I want, I just want to knock it down some knock off the corners and rough edges so there's no splinters and that kind of thing, then maybe hit it with some stain and sealer and chuck it out in the yard. Have kinda gotten into the rustic projects of all sorts, some i will want smoother than others, but no really slick stuff. Hope this helps.
#2380328 - 10/01/17 10:02 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
rowin4 Offline
Loc: gulfport, ms, west mi
Normally orbital sanders are not used in wood applications. Your suppose to sand with the grain of the wood. In your case it probably wouldn't matter . A belt sander would probably knock down the rough weathered wood the fastest.
#2380423 - 10/02/17 04:11 AM Re: Woodworkers, I have a question about sanders [Re: rowin4]
StrokerPost Offline
Loc: Missouri
Ok guys, thanks for the input, i believe i will stay with a sheet sander. thumbs
#2380446 - 10/02/17 08:09 AM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
therocks Offline
Loc: Niles , Ohio
My young
est son makes bows and items from lumber he cuts.For the rough stuff he runs it thru a planer.His bows he uses a draw knife and hand sanding.he does use a belt sander disc combo also.The planer/joiner makes it uniform and smooth.he just mad a picnic table for the wife from logs he cut.He also madkes cat trees and also made a donut tree for his cousins wedding.His bows come out like glass.Right now he probally has 400 or 500 board feet of wild cherry he slabbed.Plus he has at least the same in osage and pine. Rocky
Edited by therocks (10/02/17 02:45 PM)
Chrysler Firepower
#2380522 - 10/02/17 10:27 AM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
srt Offline
Loc: de'nile
I've done a lot of work using reclaimed wool. First I use a hand powered wire brush, if something is in bad shape I use a short belt sander using 80 or 100, then a 4" rubber block hand fired using 100 and 120.
It's pretty easy to make the finish of the sanded areas blend with the old by staining with super strong tea (10 bags to a cup) and when dry give it a wash of vinegar that has sat for a couple days with rusty metal (screws, nails, whatever).
#2380553 - 10/02/17 11:29 AM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
EV2Bird Online   penguin-006
On Vacation
Loc: Kansas Roads Between 0 and 140...
If I might interject, please use proper breathing protection... a little extra grief/cost/protection today might help you twenty years down the road. I know this first hand.
#2380749 - 10/02/17 05:00 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
5carguy Online   content
Loc: Lee Co. Fla.
iagree Good advice.
#2380838 - 10/02/17 07:01 PM Re: Woodworkers, I have a question about sanders [Re: EV2Bird]
Supercuda Offline
Amen and hearing protection.
Eye protection too.
#2380850 - 10/02/17 07:27 PM Re: Woodworkers, I have a question about sanders [Re: Supercuda]
Challenger 1 Offline
Loc: Cincinnati, Ohio
Eye protection too.
OMG! Maybe we should not even do it?!? Too dangerous!! Get back on the couch!
#2380855 - 10/02/17 07:34 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
Supercuda Offline
Maybe someone grew up an idiot too
#2382433 - 10/05/17 12:47 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
belv2vert66 Offline
Loc: Back In Iowa
A nice orbital will work great for what you want to do. Be forewarned the larger the grit (lower number) the more risk you have of getting swirl marks in your stain. I would think 150 or 180 grit would be a good place to start.
#2382444 - 10/05/17 12:52 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
Supercuda Offline
I think I would go nowhere near an orbital sander when working with wood.
The belt sander will do the job faster and better in this case, just use some scrap wood to practice with first cause a belt sander will eat wood fast.
For the record, I use a cheapo HF belt sander and their cheapo belts. Just make sure you understand belt tracking on any belt sander you go with.
#2382479 - 10/05/17 01:33 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
Orange_Crush Offline
Belieber!
Loc: Charlotte, NC
Ken
I disagree with a lot of the responses in this thread. R.O. sanders do have a place in woodworking. They are great when you want to knock off a particularly rough surface so you can do your finish sanding and/or scraping.
Again, if you want the best, Festool is the way to go...but they are very expensive.
Personally, I get the cheapest one I can find because I only use it for rough sanding purposes. I've had the same Black and Decker one for a while now.
My brother has a Bosch ROS65VC-5 he is very happy with. Nice thing about that one is that its a variable-speed setup so you can be a little more "careless" with it.
Like others said, use some sort of respirator and extractor. A shop vac works well. These things will put out a very fine dust that stays airborne for a while and it's not good getting that stuff in your lungs. Some woods are also toxic if you breathe them in (cedar, walnut, and rosewood, for example).
1970 Dodge Charger R/T Hemi Orange U-code 4-speed
1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
#2382481 - 10/05/17 01:38 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
cudaman1969 Offline
Loc: fredericksburg,va
Well I've used orbitals for 40 years in my business, millwork and cabinets. Also have belt sanders and a 37 inch wide belt sander. A belt sander will leave little depressions at the end of each stroke where as the orbital will make the surface flat, I have three air Dynablades 5 inch, 80 grit to 220 grit, hook and loop. Never have problems with stain or clear top coat finish, the swirls are caused by to course of grit paper. It's all in knowing how to use each tool for the application. With what you're planning to make i would think about an angle grinder with different grits to achieve the finish you want, fast, you will take all day with that 1/4 sheet sander. Any other questions just ask.
#2382651 - 10/05/17 06:53 PM Re: Woodworkers, I have a question about sanders [Re: StrokerPost]
BIGGERED Offline
Internet Tough Guy
Loc: North East USA
Palm 1/4 sheet and 1/2 sheet sanders are ORBITAL though they do not spin
I earned my title by questioning a members declaration that he was dating a 17 year old when he was 28. Yes he would not like the outcome of his visit to my house to pick up my 17 year old daughter!
#2382715 - 10/05/17 08:34 PM Re: Woodworkers, I have a question about sanders [Re: BIGGERED]
Supercuda Offline
Don't use either and they are RANDOM orbital sanders, not orbital sanders. Yes, there is a difference.
Page 1 of 2 1 2 >
25,145 Registered Members
186,700 Topics
‘74 Charger
by nuthinbutmopar
19 seconds ago
Brake booster help needed
by 70runner
Today at 01:05 AM
Slant 6 cross ram
by theraif
Today at 12:35 AM
'71 Roadrunner Air Grabber
by intruder71
Yesterday at 11:43 PM
