Page 26 of 48 1 2 24 25 26 27 28 47 48
Re: Modern Bullitt build [Re: Keepat] #2418273
12/14/17 12:59 AM
12/14/17 12:59 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Painted 26 small parts with single stage black. Saturday planning on painting the inside of the doors and fenders with basecoat / clearcoat.
Pat
Re: Modern Bullitt build [Re: Keepat] #2419565
12/16/17 06:55 PM
12/16/17 06:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Painted the inside of the doors and fenders today.
Pat
Sealer
Base
Clear
Re: Modern Bullitt build [Re: Keepat] #2422779
12/23/17 08:27 PM
12/23/17 08:27 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Painted the 1st outside part of the car ;-)
Thanks & Merry Christmas!
Pat
Re: Modern Bullitt build [Re: Keepat] #2422790
12/23/17 08:36 PM
12/23/17 08:36 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
So excited to see this project come together!!
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Modern Bullitt build [Re: Keepat] #2422846
12/23/17 10:13 PM
12/23/17 10:13 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I think I see light at the end of the tunnel, hopefully it’s not a train wreck ;-)
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2423123
12/24/17 03:40 PM
12/24/17 03:40 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Got a little Christmas eve paining in before the family shows up this afternoon.
Pat
Re: Modern Bullitt build [Re: Keepat] #2423306
12/24/17 09:56 PM
12/24/17 09:56 PM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Pat - quite impressive!
Thanks for showing and wish you and your family the best of the holidays!
Re: Modern Bullitt build [Re: Keepat] #2424498
12/27/17 05:15 PM
12/27/17 05:15 PM
crlush Offline
crlush  Offline
Lookin sweet! drool
Re: Modern Bullitt build [Re: Keepat] #2425543
12/29/17 09:40 PM
12/29/17 09:40 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Painted both doors today with my new SATA 4000 spray-gun, awesome spray gun!!
Pat
Primed
1 coat of Sealer
3 coats of base coat
3 coats of clear coat
Re: Modern Bullitt build [Re: Keepat] #2426119
12/31/17 12:02 AM
12/31/17 12:02 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Painted the fenders today, and as with the rest of the body panels everything will be wet sanded with 1000 grit and two more coats of clear will be applied.
Pat
Re: Modern Bullitt build [Re: Keepat] #2430896
01/08/18 02:45 AM
01/08/18 02:45 AM
Superfreak
Superfreak
Looking good.
Re: Modern Bullitt build [Re: ] #2432095
01/10/18 10:05 AM
01/10/18 10:05 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By Superfreak
Looking good.
Thank you sir
Re: Modern Bullitt build [Re: Keepat] #2432096
01/10/18 10:05 AM
01/10/18 10:05 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Painted the trunk lid and a few small parts last night. Last big part to do is the hood and then I will pull the body in the booth.
Pat
Re: Modern Bullitt build [Re: Keepat] #2432727
01/11/18 10:05 AM
01/11/18 10:05 AM
Virginia
Virginia
Pat - the mirror finish you are achieving is astonishing!
Re: Modern Bullitt build [Re: larry4406] #2433158
01/12/18 12:58 AM
01/12/18 12:58 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thanks Larry!
Paint the bottom of the hood. I think the light at the end of the tunnel is getting brighter after I cleaned the overspray on my glasses ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2438710
01/21/18 10:41 PM
01/21/18 10:41 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
After block/wet sanding the 1st coats of clear with 800 grit I sprayed the final 2 coats of clear on the doors this weekend.
Pat
Re: Modern Bullitt build [Re: Keepat] #2439263
01/22/18 11:37 PM
01/22/18 11:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wow! Very nice work!
'63 Dodge 330
11.19 @ 121 mph
Re: Modern Bullitt build [Re: GY3] #2440285
01/24/18 11:14 PM
01/24/18 11:14 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir!
Pat
Re: Modern Bullitt build [Re: Keepat] #2440468
01/25/18 11:28 AM
01/25/18 11:28 AM
crlush Offline
crlush  Offline
Looks awesome, will look like a black mirror when your done! Cant wait to see your car all assembled.
Re: Modern Bullitt build [Re: crlush] #2445124
02/02/18 11:50 AM
02/02/18 11:50 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I hope ;-)
Thank you!
