Page 23 of 48 1 2 21 22 23 24 25 47 48
Re: Modern Bullitt build [Re: Keepat] #2344602
07/28/17 12:14 AM
07/28/17 12:14 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The front bumper is now ready to head to the Paul's. Cut about 3/4 of an inch out of the front 3/8" from each side.
Pat
Before
After
Before
After
Re: Modern Bullitt build [Re: Keepat] #2345803
07/30/17 05:56 PM
07/30/17 05:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With moving the rear bumper tighter to the car I had to shave the bumper guards to fit the lower valance. Started by removing the lower mounting tab and grinding away approximately 3/16" on the bottom edge to clear the valance. Then welding the tab back on.
Pat
Here you can see how much I needed to grind off
Re: Modern Bullitt build [Re: Keepat] #2353180
08/13/17 12:59 PM
08/13/17 12:59 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Front valance required more work than the tail panel as there were a lot of factory imperfections. Someone also cut a couple of notches that required welding, just when I thought I was done with all the metalwork. Back to the block sanding :-(
Pat
Re: Modern Bullitt build [Re: Keepat] #2356885
08/20/17 12:12 AM
08/20/17 12:12 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I took a little break from the block sanding and bodywork and started making the aluminum front bumper brackets. Made a paper template of the driver side mounts and was very surprised when I flip the template inside out and it fit perfectly on the passenger side mounts. Need to do some welding and bend up the other 3 mounts.
Pat
Re: Modern Bullitt build [Re: Keepat] #2357017
08/20/17 10:47 AM
08/20/17 10:47 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Nice job Pat!
What made you decide to go with aluminum brackets? Yours seem to be in excellent shape. Just wanting to shave a little bit of weight?
Re: Modern Bullitt build [Re: larry4406] #2357079
08/20/17 01:24 PM
08/20/17 01:24 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By larry4406
Nice job Pat!
Larry,
Yes all of my original mounts are in very good condition but I was just trying to cut more weight off the front of the car.
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2357254
08/20/17 08:07 PM
08/20/17 08:07 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The right side mounts are bent, just need to be welded and then the welds ground down. I will test fit when the bumpers return from Paul's chrome before I paint the mounts, I'm sure they will need a little tweaking to fit.
Pat
Re: Modern Bullitt build [Re: Keepat] #2357454
08/21/17 09:25 AM
08/21/17 09:25 AM
STL
cdstl Offline
cdstl  Offline
STL
How are you bending the aluminum?
thx
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Modern Bullitt build [Re: cdstl] #2358335
08/22/17 10:27 PM
08/22/17 10:27 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
thx
I'm using everything from vice grips to C clamps to a large vice, block of wood and a hammer ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2358799
08/23/17 10:23 PM
08/23/17 10:23 PM
Virginia
Virginia
thx
Pat
I sometimes resort to choice words as well..
Re: Modern Bullitt build [Re: Keepat] #2359650
08/25/17 02:20 PM
08/25/17 02:20 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Love the fab work you're doing on bumpers. I drew the bumpers in on my 74 Challenger (Just another 74 Challenger thread) to make them more like earlier models. Rears were easy but fronts were a bit more of a challenge. (in-board ones hit frame rails when moved in) I hadn't considered just fabbing new ones so I chopped up stock ones wink Bumpers seem to fit well but after seeing your mods, I may revisit possible mods on mine before I finish. Blacking out mine (all black car)
Keep up good work. Would love to see earlier pics that are currently not viewable due to PhotoBucket issues. Cant wait to see final project!
Scott
Re: Modern Bullitt build [Re: Scott Carl] #2360609
08/27/17 03:04 PM
08/27/17 03:04 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Scott
Scott,
Photo Bucket screwed up a lot of Great threads on a lot of forums, very sore subject. I hope to follow up and replace the photos one day but it's just very time-consuming as you know. Thank you.
Pat
Re: Modern Bullitt build [Re: Keepat] #2360691
08/27/17 05:55 PM
08/27/17 05:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
More primer and block sanding ;-(
Pat
Re: Modern Bullitt build [Re: Keepat] #2360872
08/27/17 11:05 PM
08/27/17 11:05 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Finished welding up the right side bumper mounts and ground down all the welds. When painted black I think it would hard to tell that they're not original.
Pat
Re: Modern Bullitt build [Re: Keepat] #2362199
08/30/17 10:17 AM
08/30/17 10:17 AM
STL
cdstl Offline
cdstl  Offline
STL
How did you go about making the bends for your bumper mounts?
Re: Modern Bullitt build [Re: Keepat] #2364668
09/03/17 04:02 PM
09/03/17 04:02 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With a lot of brute force I managed to hit what I'm working on more often then my thumb ;-)
I hope these pictures help.
Pat
Re: Modern Bullitt build [Re: Keepat] #2364734
09/03/17 05:24 PM
09/03/17 05:24 PM
STL
cdstl Offline
cdstl  Offline
STL
Wow. Nice work
Re: Modern Bullitt build [Re: Keepat] #2365434
09/04/17 09:18 PM
09/04/17 09:18 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Finished the bumper mounts, time to get back to block sanding and bodywork :-(
Pat
Re: Modern Bullitt build [Re: Keepat] #2369582
09/12/17 06:56 PM
09/12/17 06:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Google chrome has a fix for the photobucket picture problem ;-)
https://chrome.google.com/webstore/d...fegnfnflicjjgj
Re: Modern Bullitt build [Re: Keepat] #2369948
09/13/17 11:31 AM
09/13/17 11:31 AM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Looking good Pat. Are you going back to black?
