#2379970 - 10/01/17 01:21 PM 318 distributor swap help
ChallengerGary Offline
Loc: Boynton Beach, FL
OK - So, I have the new motor going into my son's 1989 Ramcharger. Bought a new distributor since the old one looked kind of beat. The new one is totally different than the old one.
It was the only one I could find locally. So, I am wondering if I should just drop the old one into the new motor just to get it running again until I can order the proper new one or is there a way to retro fit the new distributor.
#2380266 - 10/01/17 08:20 PM Re: 318 distributor swap help [Re: ChallengerGary]
poorboy Offline
Loc: Freeport IL USA
The old dist is computer controlled, the new one is the electronic ignition with vacuum advance (88 and older version). Though the new dist will drop in the hole, it will not function without changing the wiring harness and attached hardware to match the dist. Gene
#2380456 - 10/02/17 08:30 AM Re: 318 distributor swap help [Re: ChallengerGary]
Ditching the computer - decided we going old school with the electronic ignition & ECU. Thanks for the reply smile
#2381654 - 10/04/17 08:50 AM Re: 318 distributor swap help [Re: ChallengerGary]
scratchnfotraction Offline
Loc: Florida
Gary, look into a mech advance limiter plate from FBO. plate/spring kit 25$
makes it super ez to recurve the mech advance.
I got mine dropped on the 18* slots with the initial at 14* for a total of 32*
got the 440 with whiplash plate dropped on the 0* slots to lock it out for no mech advance.
I myself run a pertronix points conversion/flamethrower 40,000 volt coil in a point dist recurved with FBO plate. super simple,cheap with no BR or ECU.
I just tape/hide the unused plugs on the harness for a clean look under hood.
#2381656 - 10/04/17 08:51 AM Re: 318 distributor swap help [Re: scratchnfotraction]
Loc: Florida
OH! the FBO limiter plate will work in that new elect. dist you have already also.
25,248 Registered Members
188,862 Topics
Rear brake line bracket.
by NITROUSN
26 minutes 35 seconds ago
Question about '71 B Body A/C vacuum reservoir
by Fab64
34 minutes 35 seconds ago
Alternator bracket for Big Block + Meziere h20 pump
by bigdad
Today at 12:27 PM
70 Super Bee Jack
by jrp16
Today at 09:49 AM
