My first TRACK RESULTS thread in 7 years
#2379967
10/01/17 03:18 PM
10/01/17 03:18 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
When I took a break from racing at the end of 2010 I ended up selling everything and about 4 years ago I built a big block Duster just for the street but the car runs so good I've been dying to take it to a track. A couple weeks ago I went to Quaker City in Salem Ohio, I will be driving the car to the track but Moparts member and good friend 'Butch' let me use his truck and trailer for my first outing, just in case. Butch also made some passes after a 6 year break and he had great results also, maybe he'll mention it on this thread or make a thread. This particular track is known for being a tenth slow and it was close to 90 degrees with a density altitude of over 2100 feet. First(and only) pass the car went 10.88 at 122.55mph!!!1.54 60 foot with the 275/60/15 drag radials that I bought used for $100. Track guys didn't say anything but I happily packed up and left until I get a bar in it. It's a 10to1 compression 500" low deck with Eddy heads but I'm running 3.23 gears in the 8.75 rearend, street converter, small 557 purpleshaft cam I bought used for $60, small B-body 1.75" headers with 100 dings in them I bought used for $75, mechanical water pump and mechanical fan, 4150 style 950cfm carb, full interior all steel body with all factory glass windows, full exhaust with H-pipe and tailpipes but I did use the electric cutouts that are located a few feet after the headers. No ignition box, just a Pertronix distributor with built-in ignition and rev limiter. Front and rear suspension are stock, I added one new leaf to the front segment of each leaf spring as they were wore out, no snubber. No tuning yet with jetting or timing. I've owned a couple different 9 second street cars but they weren't anywhere near as streetable as this one, my wife and I drive this car almost every day. I launched 1800-2000, shifted at 5800. Once I raise those numbers a little, and go to a different track along with some better air will put me in the 10.68-10.70 area, then I'll start tuning, but that will be after my buddy puts an 8-point chromoly bar in it, even though I've said for 4 years this car will never get a roll bar. This car is not a purpose built over achiever, it is simply a ton of FUN for my family and I for the street, and an occasional day of driving to the track, run 10's and drive home.
Re: My first TRACK RESULTS thread in 7 years
[Re: ProSport]
#2379976
10/01/17 03:25 PM
10/01/17 03:25 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
AWESOME Bob!!!!!
I real torq monster.
Yep at Norwalk on a "good" night easily 10.60`s Congrats!! Long time coming
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Cab_Burge]
#2379986
10/01/17 03:34 PM
10/01/17 03:34 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Very nice and congratulations. I love those seats.
[Re: ProSport]
#2379987
10/01/17 03:36 PM
10/01/17 03:36 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
What a great run! You built yourself a real clean car, too. For a bunch of used parts, you put together a super combination. Congrats.
[image][/image]
[Re: ProSport]
#2379992
10/01/17 03:41 PM
10/01/17 03:41 PM
ProSport
Akron, Ohio
Thanks Dennis and Cab! Thanks Dave Hall, it is a blast to drive, never runs hot, usually around 178 degrees on a hot day in traffic. It does seem to make a ton of torque, my friends get a kick out of my 50mph rolling burnouts with street tires. I really am impressed with how the drag radials handle and hook. John, the seats are just Ebay specials(sport seats), $100 each new and that includes the slider brackets that I mounted directly to the floor since I'm 6'2". I wish the seats were an inch or so wider but they're fairly comfortable.
[Re: ProSport]
#2380042
10/01/17 04:56 PM
10/01/17 04:56 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Good to hear! I have liked your ride since you started puting pictures up of it.
"Just a Bracket car dressed up like a streetcar"
[Re: ProSport]
#2380043
10/01/17 04:57 PM
10/01/17 04:57 PM
ProSport
Akron, Ohio
Thanks guys, I will update this thread soon if I get the roll bar in and get to the track again before the snow falls.
[Re: ProSport]
#2380068
10/01/17 05:48 PM
10/01/17 05:48 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Glad you had some fun with it. ps:did you change the shock setting for the track?Tire psi?
[Re: ProSport]
#2380081
10/01/17 06:09 PM
10/01/17 06:09 PM
ProSport
Akron, Ohio
I have Rancho single adjustables on the back that my friend gave me, the knob only seems to move 5 clicks and it's in the middle setting. I didn't change it for the track, it hooked and booked. I tried 17 pounds in the drag radials, seemed to be perfect.
[Re: AndyF]
#2380124
10/01/17 07:01 PM
10/01/17 07:01 PM
ProSport
Akron, Ohio
That is almost exactly what my Duster would run back when it was a street car. I think the best time was 10.90 @ 122 mph with street tires, full exhaust and complete interior. That was with a 400 low deck and a solid roller cam. The car got kicked off the track though after a guy who got beat complained to the track manager.
High 10's is really getting with the program for a street car, especially one that you can fire up and drive on a regular basis. Thanks Andy, with a few more runs and tuning I'm sure it will go 10.60's with the 3.23 gears so I'm stoked about it! I might try some 26" tires next time out since the 3.23's have me trapping at only about 5000 RPM's. Even though I'm used to cars that run 9.80's this one didn't feel slow or boring at all, I had a blast and wanted to make more runs.
[Re: ProSport]
#2380148
10/01/17 07:42 PM
10/01/17 07:42 PM
Clanton
northern,Ohio,USA
High 10's is really getting with the program for a street car, especially one that you can fire up and drive on a regular basis. Thanks Andy, with a few more runs and tuning I'm sure it will go 10.60's with the 3.23 gears so I'm stoked about it! I might try some 26" tires next time out since the 3.23's have me trapping at only about 5000 RPM's. Even though I'm used to cars that run 9.80's this one didn't feel slow or boring at all, I had a blast and wanted to make more runs. I put on the 275/55/r15 and have 3.73 so it is interesting what your rpm was.Your rpm must not drop much on the shift.
[Re: ProSport]
#2380176
10/01/17 08:37 PM
10/01/17 08:37 PM
Posts: 1,030 ohio
67mprfan
ohio
Good job Bob Glad you feel renegrized after that pass
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2380230
10/01/17 09:46 PM
10/01/17 09:46 PM
ProSport
Akron, Ohio
Good job Bob Glad you feel renegrized after that pass Thanks I am definitely hooked again! I even went to Dragway42 Friday night to help a friend with his car, it's nice to be hanging out at tracks again. Our son's sports took up our time for several years and that is perfectly fine, now he's headed towards college and has a job which free's up some car time for me unless I gotta sell it to pay for the college LOL! I will not turn this particular car into a racecar though, we drive it way too much for that. I run 93 octane in it.
[Re: ProSport]
#2380256
10/01/17 10:12 PM
10/01/17 10:12 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
That's great with some used slap together parts.Doing it with the car your cruze is is the best! I'm just redid my dual purpose heap also.Congratz!!
[Re: ProSport]
#2380273
10/01/17 10:27 PM
10/01/17 10:27 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
Runs great! I was hoping to see some results from your combo for a long time. Pretty hard to beat them 500 cube street motors when it comes to the fun factor. Is that a standard port window?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: ProSport]
#2380292
10/01/17 11:14 PM
10/01/17 11:14 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Very nice Bob! Glad you are out having fun again!
[Re: 68 HEMI GTS]
#2380293
10/01/17 11:15 PM
10/01/17 11:15 PM
ProSport
Akron, Ohio
Runs great! I was hoping to see some results from your combo for a long time. Pretty hard to beat them 500 cube street motors when it comes to the fun factor. Is that a standard port window? No it's a MW port, I bought the heads and intake used and got a great deal on them along with a stroker kit, which is what made my decision to go with a big block. I originally planned a stroked small block for easier maintenance and header fitment.
[Re: Chris2581]
#2380296
10/01/17 11:17 PM
10/01/17 11:17 PM
ProSport
Akron, Ohio
Very nice Bob! Glad you are out having fun again! Thanks Chris, and thanks for info you've helped me with.
[Re: ProSport]
#2380438
10/02/17 08:58 AM
10/02/17 08:58 AM
ProSport
Akron, Ohio
3275# with me in it, 28" tire, 275/60/15. There was 3 cars in my pit area island that were tubbed with lexan windows, huge hood scoops and no exhaust system running in the 10.90-11.20 area so they got a huge kick out of the Duster. The next day I drove it to a car show and relaxed all day with a big goofy smile.
[Re: ProSport]
#2380506
10/02/17 12:06 PM
10/02/17 12:06 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Very nice Bob!!! I wondered how long it was gonna take for you to get a timeslip on that car, lol. Runs REAL good and makes it even better that it's so streetable!
[Re: ProSport]
#2380564
10/02/17 01:42 PM
10/02/17 01:42 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
3275# with me in it, 28" tire, 275/60/15. There was 3 cars in my pit area island that were tubbed with lexan windows, huge hood scoops and no exhaust system running in the 10.90-11.20 area so they got a huge kick out of the Duster. The next day I drove it to a car show and relaxed all day with a big goofy smile. That, right there...doesn't get much better! Congrats Bob, on a great first outing. Very well done car!
[Re: ProSport]
#2380571
10/02/17 01:48 PM
10/02/17 01:48 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Way to go Bob!! That car rocks, love that it's drivable, can turn ten's with ease, AND looks bad ass as well!
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: ProSport]
#2380716
10/02/17 05:56 PM
10/02/17 05:56 PM
ProSport
Akron, Ohio
Thanks for the positive compliments everyone, you guys have awesome rides so It's good to hear from you! Hopefully I can do some upgrades here and there to make it better but in the mean time I feel content and we're really enjoying the car. An overdrive with more gear would be nice for the street and the strip, along with some much better headers although I do want to stick with the budget build. Our son is not really into cars and he asked if he could do one of his senior photos with the car last week, I was blown away. I drove it an hour away in traffic in 90 degree heat with no problems and we had a blast.
[Re: ProSport]
#2380735
10/02/17 06:37 PM
10/02/17 06:37 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Well done Bob, it definitely performs well for the package. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: ProSport]
#2380814
10/02/17 08:27 PM
10/02/17 08:27 PM
Posts: 11,706 Portage,michigan
B3422W5
Portage,michigan
Nice car Bob, and it runs super. You did a great job building it. Congrats!!!
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: 65Dodge440]
#2380866
10/02/17 09:50 PM
10/02/17 09:50 PM
cudadoug
Wow that is fast! 3.23 gears and the battery isn't even in the trunk. I hear Dragway 42 is awesome, we should all get together there in the spring. Yea, Bob...you're doing it all wrong... Battery up front 3.23's Small beat up headers MP .557 (No way, will that cam go 10's we have all heard before) And I love it!!! Awesome combo.
[Re: ProSport]
#2381103
10/03/17 06:32 AM
10/03/17 06:32 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
3275# with me in it, 28" tire, 275/60/15. There was 3 cars in my pit area island that were tubbed with lexan windows, huge hood scoops and no exhaust system running in the 10.90-11.20 area so they got a huge kick out of the Duster. The next day I drove it to a car show and relaxed all day with a big goofy smile. Wow I did not think it was that light because it dont look like you have taken much weight out of it. I thought it was at least that much with out you in the car as I figured it would be 3500 or so with you in it. So thats great and all your cars always seem to run great. And this one is right there as it runs awesome for that combo. It is fun to sometimes run faster then some cars that are tubbed with open headers and all when you run a full exh and are not tubbed isn't it. Ron
[Re: 65Dodge440]
#2381483
10/03/17 11:06 PM
10/03/17 11:06 PM
ProSport
Akron, Ohio
Wow that is fast! 3.23 gears and the battery isn't even in the trunk. I hear Dragway 42 is awesome, we should all get together there in the spring. Brad we will definitely plan on it! Thanks again everyone, I love all the nice comments! It's not hard to make a fairly light weight A-body run good with a big motor but I've never had one this drivable, could easily be used as a daily driver and it is very quiet with an H-pipe, Jones stainless mufflers, and full tailpipes out the back. I think I'm gonna make it a goal for next summer to drive 90 minutes each way to Thompson Raceway and run the 10.50 Renegade class at least once.
[Re: ProSport]
#2382165
10/04/17 11:52 PM
10/04/17 11:52 PM
Posts: 5,160 Texas
dannysbee
Texas
Bob I was really courious about your converter. Who is the manufacturer and what size. How's the drivability?
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#2382737
10/05/17 11:04 PM
10/05/17 11:04 PM
ProSport
Akron, Ohio
Bob I was really courious about your converter. Who is the manufacturer and what size. How's the drivability? It is a 9.5" Dynamic that I bought used here on Moparts and it has been perfect! Great street manners even with the 3.23's and 28" tires, and flashes real nice at the track.
[Re: dustergirl340]
#2382738
10/05/17 11:05 PM
10/05/17 11:05 PM
ProSport
Akron, Ohio
I know I was happy to run my husband's street car (Challenger) into the 11's with 3.23 gears. Congrats Bob! That Duster of yours is one of my favorite cars on here. Thank you, much appreciated!
[Re: ProSport]
#2382874
10/06/17 10:30 AM
10/06/17 10:30 AM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
Bob congrats on your great first track outing with the Duster. The 557 cam works pretty Damn good say. I ran a bunch of 10.55 in the 1/4 with it in my old 3500 pound 65 Plymouth B Body. Keep up the great work and can't wait to hear your next new best et.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: ProSport]
#2383284
10/07/17 02:57 AM
10/07/17 02:57 AM
Posts: 5,160 Texas
dannysbee
Texas
Thanks Bob. Awesome package.
[Re: mopar65]
#2383462
10/07/17 04:06 PM
10/07/17 04:06 PM
ProSport
Akron, Ohio
Bob congrats on your great first track outing with the Duster. The 557 cam works pretty Damn good say. I ran a bunch of 10.55 in the 1/4 with it in my old 3500 pound 65 Plymouth B Body. Keep up the great work and can't wait to hear your next new best et. Thanks Bobby, next year I might have to throw some gear in this thing just for one day
[Re: ProSport]
#2384418
10/09/17 01:12 PM
10/09/17 01:12 PM
mopar65
Bob congrats on your great first track outing with the Duster. The 557 cam works pretty Damn good say. I ran a bunch of 10.55 in the 1/4 with it in my old 3500 pound 65 Plymouth B Body. Keep up the great work and can't wait to hear your next new best et. Thanks Bobby, next year I might have to throw some gear in this thing just for one day Best of luck Bob and better get a Dana 60 ready.lol I can't wait till I can get my car to wear I can make a pass down the track.lol
support our troops
[Re: ProSport]
#2385655
10/11/17 03:08 PM
10/11/17 03:08 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Congrats on your very impressive first outing ! Fast, good looking, and street driven! Mark
[Re: ProSport]
#2416162
12/10/17 01:51 PM
12/10/17 01:51 PM
ProSport
Akron, Ohio
Well the season is over now, time for a long boring winter. I now have a grand total of 5 passes on the car with 3 trips to the track, added some weight with a mild steel 6point roll bar and harnesses. Still haven't had time or energy to do any real tuning but better air and dropping the jets down 2 numbers netted a nice time slip: 1.51 60 foot 6.78 at 100.99mph 10.69 at 124.65mph Drove it to and from the track 50 min away, and yes I'm having a blast with it! Still need to do more jetting, haven't touched the timing, and I have several things to do such as sealing the hood scoop, slightly tighten the converter that has 17.5% slip, and might try a good electric water pump. The 3.23 gears will stay forever.
[Re: ProSport]
#2416175
12/10/17 02:10 PM
12/10/17 02:10 PM
Posts: 5,160 Texas
dannysbee
Texas
If the street manors are good might leave the converter be. It is going to be hard to get the slip race car efficient with that big ole lever you got on the end of it. Just a thought. The tighter converter would widen the shift extencion and lower your trap rpm.
[Re: dannysbee]
#2416247
12/10/17 03:37 PM
12/10/17 03:37 PM
ProSport
Akron, Ohio
If the street manors are good might leave the converter be. It is going to be hard to get the slip race car efficient with that big ole lever you got on the end of it. Just a thought. The tighter converter would widen the shift extencion and lower your trap rpm. That's exactly what I'm debating over the winter. Normally with an 8" converter and 4.30 gears I expect about 3% slip out of my converter, but with this car having 3.23 gears and a 9.5" converter, I'm wondering if a little slip is helping it..? It drives great on the street and strip and the trans fluid is always red in color like new. I would not be very happy if I did all the work to remove the converter, pay to have it tightened up, and then the car slows down a tenth or two. Then again it might drive better on the street and it is 80% street driven.
[Re: ProSport]
#2416266
12/10/17 04:10 PM
12/10/17 04:10 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
That's awesome! Great running car.
I have not seen Butch in quite a few years now. Was thinking of him the other day - hope he is doing ok!
[Re: markz528]
#2416556
12/11/17 12:19 AM
12/11/17 12:19 AM
ProSport
Akron, Ohio
I have not seen Butch in quite a few years now. Was thinking of him the other day - hope he is doing ok! Thanks, and Butch is doing great! He even made some passes this year in his Duster, it's hard to pull him away from his RC airplanes though lol.
[Re: ProSport]
#2416701
12/11/17 11:59 AM
12/11/17 11:59 AM
Posts: 5,160 Texas
dannysbee
Texas
I agree Doug. I was not aware of this till I started modifying later model cars with 2.79-3.23. A lot of the time the 2.79 geared cars were nearly or as fast as the higher geared cars. That low numerical gear really makes the converter work. The shift rpm will tighten up and you get more flash out of a tighter converter.
[Re: dannysbee]
#2416754
12/11/17 02:02 PM
12/11/17 02:02 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Congratulations it's always nice when hard work pays off.. oh and by the way great looking car
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: ProSport]
#2416913
12/11/17 07:19 PM
12/11/17 07:19 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Well the season is over now, time for a long boring winter. I now have a grand total of 5 passes on the car with 3 trips to the track, added some weight with a mild steel 6point roll bar and harnesses. Still haven't had time or energy to do any real tuning but better air and dropping the jets down 2 numbers netted a nice time slip: 1.51 60 foot 6.78 at 100.99mph 10.69 at 124.65mph Drove it to and from the track 50 min away, and yes I'm having a blast with it! Still need to do more jetting, haven't touched the timing, and I have several things to do such as sealing the hood scoop, slightly tighten the converter that has 17.5% slip, and might try a good electric water pump. The 3.23 gears will stay forever. Hey I thought you were going to come try my 26"s next time out after the cage install. Glad you got her out one last time. Are you sure on the slip numbers?? Heres my math for your latest mph outing with the 28" tires and if you would of used my 26's. 124.65 x 3.23 x 336/28 = 4831 RPM. 124.65 x 3.23 x 336/26 = 5203 RPM Not really that much different really but in the right direction. My combo at that MPH would be at 5998 RPM. You stated you were crossing the stripe near 5000 RPM, I don't see any room for 17.5% slip.??
[Re: 383man]
#2416924
12/11/17 07:44 PM
12/11/17 07:44 PM
ProSport
Akron, Ohio
Wow you have that basic combo running great. We would be a good race of two street cars driven to the track. Its fun for me when I am done racing and all I have to do is put some air in my rear tires and drive home. And that while I watch most loading their cars on trailers. Its great as long as nothing breaks. Ron Yes we would be a fun race for sure Ron! I'm currently running cheapo radials on the street and changing to a different set of rear wheels at the track with M/T 275 Pro drag radials mounted on them. Next summer I may try some regular M/T drag radials so I can just leave them on the car for street and strip. My concern is that I drive this car so much, I might go through a set of drag radials too quickly on the street.
[Re: dvw]
#2416926
12/11/17 07:47 PM
12/11/17 07:47 PM
ProSport
Akron, Ohio
The converter shows slip because of the 3.23 gear. The car is still acelerating at the stripe. Tightening it won't help in my opinion. Slip just means you don't have enough distance to allow it to couple up, not that it's too loose. Doug Ok thanks Doug, that's exactly the kind of info I needed. Also saves me from pulling the trans and converter and spending money. Thank you also Dannysbee.
[Re: WHITEDART]
#2416927
12/11/17 07:49 PM
12/11/17 07:49 PM
ProSport
Akron, Ohio
Congratulations it's always nice when hard work pays off.. oh and by the way great looking car Thank you, it's not the fastest car around but it sure is fun.
[Re: Sport440]
#2416930
12/11/17 07:53 PM
12/11/17 07:53 PM
ProSport
Akron, Ohio
Well the season is over now, time for a long boring winter. I now have a grand total of 5 passes on the car with 3 trips to the track, added some weight with a mild steel 6point roll bar and harnesses. Still haven't had time or energy to do any real tuning but better air and dropping the jets down 2 numbers netted a nice time slip: 1.51 60 foot 6.78 at 100.99mph 10.69 at 124.65mph Drove it to and from the track 50 min away, and yes I'm having a blast with it! Still need to do more jetting, haven't touched the timing, and I have several things to do such as sealing the hood scoop, slightly tighten the converter that has 17.5% slip, and might try a good electric water pump. The 3.23 gears will stay forever. Hey I thought you were going to come try my 26"s next time out after the cage install. Glad you got her out one last time. Are you sure on the slip numbers?? Heres my math for your latest mph outing with the 28" tires and if you would of used my 26's. 124.65 x 3.23 x 336/28 = 4831 RPM. 124.65 x 3.23 x 336/26 = 5203 RPM Not really that much different really but in the right direction. My combo at that MPH would be at 5998 RPM. You stated you were crossing the stripe near 5000 RPM, I don't see any room for 17.5% slip.?? Mike I should have text you, I replied to a thread on Moparts that you were on, and I mentioned that I want to just stick with the drag radials but you may not have seen it. On my 3rd trip to the track I finally remembered to look down at the tach and to my surprise it's crossing at exactly 5800. I looked at it 3 passes in a row.
