#2379632 - 09/30/17 09:54 PM For Sale - Race Cars - 4th Quarter
moparts Offline
#2380316 - 10/01/17 09:39 PM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
70b1dart Offline
Loc: st.louis,mo.
1980 dodge mirada,499 ci,513 dana ladder bar,14x32 back halfed,really nice old bracket car,no rust,12 point funny car cage,removeable fiberglass frontend,all lexan glass,can be view at gatewayclassiccars.com,will pull this car out of there after 10-15,10tk or 6k roller or obo,has a vin tag but no title,contact me at hemiman4262003@yahoo.com or pm me here,PRICE CUT 10,000
Edited by 70b1dart (11/06/17 04:42 AM)
#2380365 - 10/01/17 11:07 PM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
Sburke Offline
Loc: utah
65 Coronet for sale with or with out engine and transmission.
Engine
Bored out .060
Weisco forged pistons
Forged rods
Crower Ultra Action Performance Level 5 Camshafts 32414
Summit Racing Part Number:CRO-32414
Cam Style: Mechanical roller tappet
Basic Operating RPM Range: 3,750-7,750
Intake Duration at 050 inch Lift: 262
Exhaust Duration at 050 inch Lift: 268
Duration at 050 inch Lift: 262 int./268 exh.
Advertised Intake Duration: 304
Advertised Exhaust Duration: 310
Advertised Duration: 304 int./310 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.650 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.624 in.
Valve Lift with Factory Rocker Arm Ratio: 0.650 int./0.624 exh.
Lobe Separation (degrees): 106
Intake Valve Lash: 0.026 in.
Exhaust Valve Lash: 0.028 in.
Harland Sharp roller rockers
Cloyes Hex-A-Just Timing Set
Crowder roller lifters
Team G manifold.
Rebuilt=zero miles
Trans New 727 w/Transbrake. Built by Rick Allison at A&A transmissions out of Indiana. Best of everything. Comes w/ new billet torque converter. Have receipt with everything that was done. One badazz trans
8 3/4 spool 456 gears
Aluminum radiator
Fuel cell.
Car 5500 obo
Engine 3800 obo
Trans 3800
Everything 10k
#2381310 - 10/03/17 03:00 PM Re: For Sale - Race Cars - 4th Quarter [Re: Sburke]
82ramIndy493 Offline
Loc: crisfield, maryland 21817
For sale is my 82 Pro Street/Race truck. It has a 493 stroker with Indy SR's, 727 with TransGo 2 kit, Dynamic 4500 converter and Dana 60 rear with spooled 4:30 gears. The rear is brand new never ran on a track as yet. The truck has done a best of 10:80 at 121 mph but has more available with some fine tuning. You can call for complete details on the drivetrain at 410-968-2010. There's to much to list here. I am selling the truck with or without trailer. The total asking price for all is 15,000 dollars. If you want the truck only I will invite offers but it would have to be very fair. I will not give the truck away. You could not build a truck or car setup like this for this amount especially when including the trailer. PM me here or contact me at samson1156@verizon.net or call number above. Thanks and have a great day. CLinton.
#2382761 - 10/05/17 09:46 PM 1969 Dart Swinger [Re: 1974 474 Duster]
Bigcube Offline
Loc: Upstate NY
This is SOLD! Thanks for the Ad Moparts!
This is still available. Asking $35k turn key or $20k as a roller. It drives straight, hooks hard and has been in the 8's on motor with race gas. The current pump gas combo is about 50 HP shy of the race fuel combo. Best ET is 8.94@151. Description below:
Chassis
- Clean title and has vin tag, currently registered and plated
- Chassis professionally built by "Pro Start Race Cars" in NJ
- Full chrome moly round tube frame, will certify to 8.50, currently expired
- 4-link rear suspension, has 17x33 tire on a 15x14 rim
- Wishbone locator
- Dana 60 rear, Strange 4.10 race gears, Strange race 35 spline, Strange spool
- Wilwood brakes all the way around
- Strange double adjustable rear shocks, Koni front shocks
- Rear A-R bar
- Wheelie bars, chute
- Dual batteries, custom large aluminum fuel cell
- A-arm front suspension
- Aluminum front and mid plates
- Stiletto rack & pinion
- Body is all steel except for hood and bumpers, under 50k original miles
- Real window glass that rolls up and down
- Stock dash, modified stock column, all lights work
- Weighs 3000 Lbs. race ready
Engine, 557" Big block
- Keith Black block, 4.440" bore, purchased new, never windowed
- Bryant billet crank, fully counter weighted, 4.5" stroke
- GRP aluminum rods
- Two sets of pistons, Diamond 11:1 for pump gas, Ross 15:1 for race fuel
- Hellfire rings
- Indy -1 heads, hand ported by Barton
- Jesel Rockers, Jesel belt drive
- Single Holley 1150 3-circuit dominator
- Two rollers cams, Isky "Red zone" solid rollers
- Custom aluminum oil pan
- Titan wet sump oil pump
- MSD Digital 7 ignition
- NRC offset distributor
- Moroso 4-vane vacuum pump
- 90 amp alternator
- Has a NOS Fogger nitrous system plumbed but never tried
- Spare intake (not plumbed)
- Custom stainless steel step headers, stainless 4" merge collectors
Transmission
- CRT TF-727 full race trans
- Steel drum
- Reverse manual valve body with trans brake
- All good parts, no more than 100 runs on trans
- PTC 9" nitrous converter
Miscellaneous
- Custom Ron Davis radiator, Dual Spal fans, stays under 185 deg in traffic
- Car still has factory radiator support, this is not a typical "panel" chassis car
- On board fire system
- Factory headliner, door panels Dome light (works)
- Factory Speedometer works
- Removable tunnel
- Carpeted
- Product Engineering fuel system
- Carbon fiber drive shaft
As a roller the car will not include engine, radiator, trans or ignition box.
I have lot's of pictures on-line and many more available. PM me here on the board or email bigcube"at"stny.rr.com, No tire kickers, no low ballers. If you are serious and have the means to buy, I will consider reasonable offers.
Thanks for the ad!
Edited by Bigcube (11/25/17 08:05 AM)
#2384856 - 10/09/17 10:58 PM Re: 1969 Dart Swinger [Re: Bigcube]
joez Offline
Loc: PA
1972 Dodge Challenger race car roller. SFI 25.5 mild steel chassis with stock front and rear frame rails. Fiberglass front end and deck lid. Has factory 1970 grill, headlights and tail lights for street appearance. Steel doors with working glass. Cowl hood with carbon pro stock style scoop.
Custom tubular k-member with flaming river mustang II rack and spindles. AVO double adjustable front coilovers, Qa1 adjustable rear coil overs, S&W ladder bars, diagonal link and splined anti roll. Chassis engineering wheelie bars. Wilwood disc brakes front and rear. Dana 60 with moser 35 spline spool and axles. Dewco pro-fin 3.73 pro gear. 15x11 holeshot rear wheels, Weld magnum front wheels.
Motor plate for BB Mopar. 2 3/8” custom headers with collector mufflers. ATI powerglide adapter midplate, flywheel.
Fiberglass stock appearing dash with autometer gauges, Stock door panels, Kirkey seat, firefox fire system, stroud chute, jaz 3 gallon fuel cell, dual nitrous bottle mount, laptop mount, quarter stick shifter MSD digital 7 programmable, hvc2 coil, strange low mounted master cylinder, afco radiator,
Last run with 528 B1MC low deck nitrous. Best ¼ mile 1.308/5.34@135.88mph/8.21@171.29mph. Best 1/8 mile 1.19/5.29@132.7mph @ 3,050lb Joe – nitrojoez@yahoo.com – 570-401-2596 $18,000 obo or trade for srt8 challenger.
#2385231 - 10/10/17 05:18 PM 1968 Plymouth Road Runner [Re: joez]
Morris'Mopars Offline
Loc: Illinois
Selling my 1968 Plymouth Road Runner SST car. Top notch NHRA race car that is only 2700lbs. Has glass fenders,bumpers,doors, hood and deck lid by Glasstek. Back half ladder bar car with QA1 coil overs on all four corners. Dana 60 Strange rear end 4.56 gear and 35 spline axles,Strange brakes. Currently has big block mopar engine and 2 speed pg trans with shield straight cut gears and Ultra Bell. Selling this car less engine everything else goes with it from the transmission back. Over 30k invested in this car. Just way to many good name brand parts to list. $13k less engine or $12000 rolling chassis.
Have clear title extra drive shaft
Located in illinois
Edited by Morris'Mopars (12/12/17 02:50 PM)
www.morrismopars.com
#2388646 - 10/17/17 09:14 AM Re: 1970 Plymouth Road Runner [Re: moparts]
Eric Offline
Loc: Pittsburgh PA
80 Arrow JanCen 499" low deck Mopar fresh approx 50 passes. Round tube mild steel with chromoly funny car cage 8.50 cert
Fiberglass hood ,doors,bumper,hatch and front clip....2335# with 170# driver
Molnar crank and rods
JE pistons
Indy CNC 295 SR heads
Harland Sharp rockers
Trend pushrods
ATI balancer
AED 1000cfm 4150
Coated 2" headers
Indy intake
Meziere water pump
Afco radiator
UCC 8" converter
Abuzzi glide with Reid case and roller tailshaft
DOM .083 driveshaft 1350 Spicer both ends Moser slip yoke
Dana with Strange axles 4.56 gear Perfect launch cover
Wilwood disc on all four corners
4 link with anti roll
Hoosiers front and rear approx 50 passes
Digital delay Elite 95 and Biondo throttle stop
ARC switch panel
Stroud chute and Comp Eng wheelie bars
Car is mostly run in S/R S/G 9.90 @ 148 has been 5.53 @ 125 in the 1/8th. Tons of new parts. Asking 21K t/k If you know what it costs to build a 8 second car you know this is a fraction of the cost. PM me here if interested.
5.53 @ 125 1/8th on the launch control..more left in her!
#2395905 - 10/31/17 07:26 AM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
Charlie Moore Offline
Loc: Strongsville, Ohio
1964 Dodge 330 Super Stock Legal. SS/AA,SS/BA. $65,000 440-666-1337. Sorry but I do not know how to attach a photo.
Edited by Charlie Moore (11/01/17 08:17 PM)
#2396429 - 10/31/17 11:43 PM Re: For Sale - Race Cars - 4th Quarter [Re: Charlie Moore]
64hemi330sedan Offline
Loc: OHIO THE HEART OF IT ALL
lil help Charlie.
Edited by 64hemi330sedan (10/31/17 11:47 PM)
#2399104 - 11/05/17 07:57 PM Re: For Sale - Race Cars - 4th Quarter [Re: joez]
Greg Offline
Loc: SC
This roadrunner has been owned since 1987. We have the original 383 motor, air grabber hood, original radiator, everything to put back to stock. Original Vitamin C paint and burnt orange interior car. Original invoice and paperwork available. Currently: 499 stroker 700 HP - Mid 10 second car at 3700+ pounds. Have all the engine build information Stage 6 Heads with port work, 1050 Dominator Carb, Aluminum radiator, 727 Transmission - reverse valve body w/griner trans-brake, Calvert Caltracs, Split mono leaf springs, Rancho 9 way adjustable shocks, 8 3/4 rear end, aftermarket axles, Weld draglites
$39,000
Picture Link
Edited by Greg (12/16/17 01:38 PM)
#2399656 - 11/06/17 07:33 PM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
acmopar Offline
Loc: Central Ohio
Plymouth Arrow built 340 with power glide 5500 converter trans brake 4.56 gears tubbed all aluminum interior all electronics electric shift turn key but has been setting a while would give a once over but runs shifts great and everything works as it should contact for more info or pics text preferred but if call please leave a message 614-395-6964
Edited by acmopar (11/06/17 07:36 PM)
#2409240 - 11/26/17 04:37 PM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
RapidusMaximus Offline
Loc: Haslet, Texas
1994 SWB Dakota, fresh 5.2 Magnum stroked with a 4" Scat crank (388 CI), Eagle rods, block partial filled, billet main caps, ARP fasteners throughout, Edelbrock heads mildly ported, JE pistons, Total Seal SS rings, approx 9.4 CR, Custom hydraulic roller turbo cam by PIE, MSD crank trigger ignition, 76mm turbo, .96 AR, 3" piping on hot and cold side, 3" down pipe with Magna flow muffler routed out to the stock location, air to air intercooler, Hypercontrol boost management system, ECU is a Classic FAST fuel injection system, Aeromotive 1000 fuel pump, 12 gallon fuel cell, braided lines, tablet with all tuning data included. SRT8 seats, chrome moly 8 point cage integrated into the interior and routed cleanly through the stock dash. SRT8 seats, new carpet, door panels, sliding rear glass and windshield. Moser 60, 3.54 gear, QA 1 coilover shocks on the front, AFCO's on the ladder bar equipped rear. Billet Specialties Wheels, 315/60/15 tires with less than 500 street miles and a 6 no prep passes. Trans is a 727 with a Turbo Action reverse pattern manual valve body, trans brake, PTC 9.5 in converter, and a CRT deep pan and pickup.This truck is a race car with a truck body, it is street driven on pump gas but prefers a 50/50 mix of race gas for serious stuff, it is very quiet and mild mannered with disc brakes on all for corners (stock up from, Wilwoods on rear).
I am probably forgetting stuff but you get the idea, this is a professionally built and assembled street driven truck that has run 9's in it's past and the tune is the same now as it was then, only difference is the engine is fresh. Only reason for selling is I am looking for a 67-69 Dart to fit a particular "street" class that they won't let me into with this truck, with that being said, the ONLY thing i am interested in partial trading for is a 67-69 Dart that is already mini tubbed or is a good candidate for mini-tubbing and cal-tracking. I prefer a pm or email with a phone number for serious buyers to discuss details and additional picture requests, I am asking 18,500 or best close offer and like I said above am seriously interested in a 67-69 Dart partial trade. PM me here or email alilblacktruckatgmaildotcom, thanks
Edited by RapidusMaximus (12/08/17 05:28 AM)
1968 Plymouth GTX 440 4 Speed Dana
1973 Small block Duster under construction
1974 Dodge P/U Long Bed Stepside 318 Auto
1975 Jeep CJ5
2016 Dodge Ram Hemi 1500
#2412166 - 12/02/17 08:55 AM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
SCDaytona Offline
Loc: New Milford, CT
91 Dodge Daytona - VFN body- Chrome Moly cage- Certifed to 7.50 4 Link- 9" rear with 40 spline gun drilled axles with ceramic bearings and coated gears and bearings. Strange Strut front end with coated bearings at hubs. Car is presently set up for small block although I do have the plates for a big block. Car can be set up with most trans. such as glide, Profilte, 904 or 727. Has Biondo Mega 400 delay box, MSD DIgital 7 Ignition, Auto Meter Tach and gauges- Magnafuel 500 pump and aluminim fuel cell. Presently has a single 16 volt batttery and has mounts for dual battery. Car has run 8.15 on C16 and with Q16 (+30HP) ran 173 mph on a bad launch pass. Never sorted out on Q16. Has Penske Nitrogen shocks bult by Chris Bell. Can can be bought as a roller for $22k 383 Small BLock W8 CFE Heads sheet metal intake and Davince dominators- King Lightened crank, carrillo rods- Moroso oil and vacumm pumps and more $14K Profilte trans. w/ 2.23 1st gear air shifter and shields $5500. Call 860-354-6701-Can be bought complete if desired. [img:center]Engweb by Joseph Olejniczak, on Flickr[/img] [img:center]PICT4451WEB by Joseph Olejniczak, on Flickr[/img]
Edited by SCDaytona (12/02/17 09:49 AM)
#2412654 - 12/03/17 10:44 AM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
sixty9bee Offline
Loc: louisiana
1970 dodge challenger, 499,727.dana. ladder bars. eagle crank and rods, ross pistons, edelbrock heads, comp roller cam, Harland sharp rockers, indy intake, dominator carb, hooker headers, msd ignition. ati converter, turbo action transbrake, billet drum, super sprag. moser axles and spool pro gears 4.10. 3050 lbs fiberglass doors, deck, bumpers, front end lexan windows except windshield. motor just freshened has 0 runs, trans and rear gears and rear QA1 shocks have 10 passes. 9.60-9.70 1/4 6.10-6.20 1/8 best e.t. 9.500 @ 141.5 located in northwest Louisiana $25000 email sixty9bee@aol.com for pics and info
#2413996 - 12/05/17 10:14 PM Re: For Sale - Race Cars - 4th Quarter [Re: sixty9bee]
BBCoronet Offline
Loc: CentralVA.
72-74 Cuda Drag car. Project was started and never finished. Body has some rust and cowl has been cut down. No interior, Dash or wiring. Car has been back half and caged. Welds look nice and all appear to be TIG welded. Four link, CE Coil overs, 46" Dana 60 w/4:88 gears, Spool, Strange axles.(no brakes but has caliper brkts) (I believe the rear is all New AtoA) Has parachute mount and wheelie bar brackets. Stock K frame up front. No front sheet metal, doors or deck lid....What you see is whats there. Save it or use it for parts.... No VIN or Title. $2500.00 picked up in Va. (zip 23093) * Mopar Trades * PM for PH#
#2415839 - 12/09/17 04:12 PM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
Slap Shot Offline
Loc: Dover,Pa
1969 Plymouth Barracuda (fastback) drag car has vin plate and clear title I will be pulling the 426 Hemi setup out of it and selling with a 448 wedge engine and auto trans this is a fresh set up that ran 10.50s in a Plymouth Duster. $15,000 with wedge setup 717 577-0270 York,Pa
#2417547 - 12/12/17 05:06 PM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
TBorman Offline
Loc: Louisiana
2002 Jerry Bickel Pro stock Neon. Carbon Body, Interior, Brakes, setup for BB and Glide. Ford 9 in., 3.89 Gear, 40 Spline, Gun drilled Axles, 7AL3 Ignition, race pak, Fire System. Car comes with Motor Plate, Mid Plate, Mark Williams Aluminum Drive Shaft and Stainless Side Exit Headers. (EX- Darrell Alderman Car)
$45K For more information message me or call (337)789-1764
#2419520 - 12/16/17 02:12 PM Re: For Sale - Race Cars - 4th Quarter [Re: moparts]
Mister bee Offline
Loc: Mississippi
72 challenger drag car for sale . Indy small block “r3” 440 ci , Ford 9 inch with 4 link, magnum force front end, stainless steel 2” headers, full chrome moly cage, car weighs 2450, runs 5.70 in eighth. $25,000 with extra hoods, trans, and 3rd member. For photos text me at 1-601-731-4359.
Edited by Mister bee (12/24/17 12:04 PM)
#2424598 - 12/27/17 05:39 PM 68 Dodge Dart [Re: Mister bee]
sixpacksteve Offline
Loc: n.y.
68 block, 505" stroker
4.25 scat crank n H beam rods
12.5 flat top pistons
external oiling milodon pan
682 Bullet cam
Edelbrock victor max heads
T&D roller setup
indy max intake
1150 holley
MSD ignition system
hedman hustler headers
Coan full race trans w/transbrake
Ultimate 8" 5500 convertor
custom strange driveshaft
Dana 60 rear 4:10
M/T slicks 29.5x10.5
Cage NOT certified
seat belts are 6/17
can make streetable w/exhaust
has glass fenders and hood
has super stock seats and aluminum brackets by Gary Ball
has steel bumpers,brackets rear seat etc..
Engine has just been Rebuilt w/pistons valves etc..
Only 9 passes on motor
and Trans rebuilt w/ Only 4 Passes!
Cars best so far 9.70 at 138 mph
60 ft. 1.39
asking 25K i have at least that much just in receipt
pm me for more pics and info!
Edited by sixpacksteve (12/29/17 10:50 AM)
25,083 Registered Members
185,767 Topics
Does anybody have a Summit Racing discount code?
by BigHemiVegas
01/23/18 12:22 PM
Ram 1500 Spindle Swap
by Evil Spirit
01/23/18 11:18 AM
wheel choices on a 68 Barracuda
by superchuck
01/23/18 11:05 AM
'68 Dart GTS H Code...sorta
by 56_Royal_Lancer
01/23/18 10:20 AM
