Page 1 of 3 1 2 3 >
#2379629 - 09/30/17 09:52 PM For Sale - Elephant Hemi Engines - 4th Quarter
moparts Offline
#2380291 - 10/01/17 09:13 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
938-DAN Offline
Loc: New Jersey
For Sale:
Pair of original 426 Hemi exhaust manifolds. Dated October and November of 1966. Very nice condition but heat riser has been removed and holes plugged and passenger side manifold has a crack in the flange area that will need to be repaired. Price is $700.00 for the pair including shipping within the continental US.
Please email with questions or for more pictures ASonn86814@aol.com .
Thank you.
Edited by 938-DAN (10/15/17 11:30 AM)
#2380295 - 10/01/17 09:16 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
938-DAN Offline
Loc: New Jersey
For Sale:
1969 426 Hemi engine and matching manual transmission from a 1969 Dodge Coronet R/T WS23J9. Block casting date 6/10/68, cylinder heads dated June 18 and June 26 of 1968. Good used cores for a 1969 B body hemi project.
I have the assembled long block with intake manifold, oil pan, heads, rocker arms, valve covers, water pump and balancer. I also have the heavy duty 18 spline four speed manual transmission with matching VIN number and the correct cast bell housing.
Cylinder heads and oil pan were removed for visual inspection. No damage or excessive wear observed. Engine retains the original factory standard pistons #2780514 and #2780515. Combustion chambers in heads are clean with no pits. No sludge, no rust, no corrosion and the engine turns over easily by hand. This is a really nice core engine.
I DO NOT have the carburetors, exhaust manifolds, distributor, pulleys, fan, flywheel or starter.
This is not the typical collection of mismatched leftover parts, it is a complete long block and matching transmission as removed from a vehicle. No visible damage but it does appear to have been in storage for a long time and will need to be gone through. Selling the package for $18,500.00. Must be picked up in southern New Jersey, zip code 08096. Please email ASonn86814@aol.com .
Thank you.
Edited by 938-DAN (10/23/17 02:55 PM)
#2380625 - 10/02/17 01:07 PM Hemi valve cover gaskets [Re: moparts]
johnnyd Offline
Loc: Boston, MA
2 Sets Hemi valve cover gaskets $35 for both sets NOS Mr. Gasket 374 SOLD!!! Thanks MOPARTS!
Edited by johnnyd (10/04/17 06:35 PM)
#2381478 - 10/03/17 08:46 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
Dragula Offline
Loc: Taxes R-US, NY
$25k price drop.
This is the last time the Callies crank can be turned, and so I am lowering the price. Engine is almost back together and you can hear it run as I am putting it back in the car
All aluminum Indy style Hemi parts purchased from BGR. Complete 1250 carb to pan minus motor plate. I currently have it all apart as we have nearly fixed the last remaining issue from last year. This engine makes over 800hp on pump gas and is an absolute street terror.
Last year I did window it after starving #7 rod bearing for oil. The block was professionally repaired and is currently out for a final line hone just to make sure nothing moved. All parts that were hurt were replaced or repaired professionally.
All good parts, 11.2:1 compression. Heads ported and flowed..all build specs here...Should have it all back together here in a few weeks. Can hear it run in a few weeks as it will back in the car.
May take a 6.1 Hemi stroker and $$$ in trade...
All build specs here
http://board.moparts.org/ubbthreads/ubbt...ld-updated.html
Very Streetable:
https://www.youtube.com/watch?v=WYw6RA-k5Bk&t=37s
Edited by Dragula (11/07/17 05:59 PM)
'71 Duster Pump Gas 512RB
https://www.youtube.com/watch?v=Z_XTmRBuvWs (6.19)
https://www.youtube.com/watch?v=gQZGfDBPROM (9.70 at 138.5mph)
'70 Cuda Hemi, 605 almost ready again.
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.31)
#2381623 - 10/04/17 04:57 AM Hilborn Fuel Injection [Re: moparts]
70HemiGTX Offline
Loc: PA
SOLD. Thanks Moparts.
Edited by 70HemiGTX (10/11/17 04:37 PM)
#2381762 - 10/04/17 11:29 AM 572 Race Legend new [Re: 70HemiGTX]
67R/T4speeder Offline
Loc: Pismo Beach,California
part# 426-c6-572-960
In the crate
$21,000.00
zip 93433
troxellsgarage@gmail.com
Andy
www.troxellsgarage.com
#2382052 - 10/04/17 06:45 PM Hemi race weight valve covers [Re: moparts]
70HemiGTX Offline
Loc: PA
For Sale: Hemi dual plug light weight aluminum valve covers. Very nice condition. I polished them. What you see is what you get. One full set of single hole block-offs. One full set of twin plug block-offs. 4 new breathers. They are ready to bolt on. $600 shipped to the lower 48. Email me at: trdeppen"at"comcast.net or pm me here.
#2386416 - 10/12/17 04:17 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: 36viper]
HemiGreg Offline
Loc: L.I. N.Y. Hemi Street
Hemi factory blocks std,+30,+60
all never hurt 66,68,69,69,the 69s are unstamped
$4500-6000 pickup only li.ny 11783
5167817653 leave message
http://www.hemigreg.com
Orignal Hemi Cuda (shaker is in garage)
"No clones allowed"
#2387365 - 10/14/17 01:01 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
old_racer Offline
Loc: Wi.
new in box mopar perf crossram intake never mounted. $625.00
email for pic's
hemimax@hotmail.com
#2387403 - 10/14/17 02:46 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: old_racer]
dsd70bee Offline
Loc: oak park, il.
One set of 426 HEMI rocker assemblies, Everything aftermarket for a Top Fuel or Alcohol aluminum type head, Stage V roller tip intake rockers $2000.00 for the pair (708)288-2879 Scott
#2387416 - 10/14/17 03:06 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One set of eight 426 HEMI Stage V roller tip intake rockers in excellent used condition $750.00 for the set (708)288-2879 Scott
#2389469 - 10/18/17 05:39 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
70HemiGTX Offline
Loc: PA
For Sale: I have 3 Hemi valve covers.
1. Chrome Direct Connection 70-71 passenger's side valve cover. Very nice condition. Has spark plug loom. Never had the wireloom tabs. No dents. $400 shipped to the lower 48.
2. Chrome 70-71 passenger's side valve cover. Ok condition. Has spark plug loom. Wireloom tabs are missing. $300 shipped to lower 48.
3. Chrome 69 and earlier valve cover. Chrome is nice. Had a hole drilled in the backside of the valve cover. Has an AN plug in it. What for????? ******SOLD********
Email me at: trdeppen"at"comcast.net or pm me here or call 7one7-five71-518zero.
Thanks for the ad.
Edited by 70HemiGTX (11/06/17 09:20 PM)
#2390572 - 10/20/17 09:13 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
shorty Offline
Loc: Bristol, TN (ThunderValley USA...
1969 426 HEMI, Mostly Complete with Perfect Never Any Damage or Cracks Block, Hemi Crankshaft 2780533, Super Nice and Complete Cylinder Heads with all Valve Train, Racer Brown Solid Cam & Lifters. NO Intake or Carbs.
Block has VIN # XS29J9BXXXXXX with casting date 8/5/68
Block is .40 over
Cylinder Heads - 2780559 with F/28/8 & G/30/8 Codes
The block still has perfect cross hatch pattern in bores from prior rebuild many years ago and never used. Pistons, Rods and Oil Pan removed by previous owner for another application. Cam is .544(I) .527(E) Duration 254 @.050
Contact : red_srt10 at @ yahoo.com OR PM on Site
$17,500
#2390794 - 10/21/17 11:19 AM 1970 426 hemi engine [Re: shorty]
Little Detroit Offline
Loc: WV
1970 426 hemi engine with all machine work completed and all new parts for assembly. casting date is 11/11/68 out of 70 hemi cuda which still survives today. block is .020 overbore ,block squared, line bored, cam bearings and brass soft plugs installed, rods resized and rebushed with arp rod bolts installed, pistons are .020 hyper eutectic 10.25 comp, rings are sealed power already file fit to cylinder, crank is 10/10, engine assembly is balanced, new melling high volume oil pump, bronze dist bushing, bronze distributor drive gear,cams shaft is Racer Brown "cheater " hyd cam and springs with lifters, heads are virgin with the exception of gasket porting,5 angle valve job and springs set at appropriate height for camshaft ,correctly dated intake manifold, 1970 4 spd carburetors date matched, felpro gaskets, spring return brackets and springs,arp head bolts and studs ,original 70-71 valve covers. if you are want a great engine to complete your 1970 hemi car this should fill your needs. the engine has left apart for your inspection as stated earlier all parts are either reconditioned or new in their perspective boxes. $30,000.00 or best serious offer,some trades possible. 304 797 0607 thank you.
#2390798 - 10/21/17 11:25 AM Re: 1970 426 hemi valve cover [Re: Little Detroit]
Loc: WV
1970-71 valve cover one only. $ 300.00 304 797 0607
#2390918 - 10/21/17 04:22 PM New Diamond Hemi pistons [Re: moparts]
Steve1118 Offline
Loc: Walton's Mountain, Pa
For sale, +.060 Diamond Hemi pistons. 4.31 bore, 4.15 crank, 1.03 pin, 12.1 to one compression. Brand new, still in box, never even unpacked except to look at one. $700. Bought to put together a stroker motor, but never got around to it and now, in my mid sixties will stick with 426 size motors for NSS racing, so this stuff is laying around. 814-288-9924
Edited by Steve1118 (10/21/17 07:43 PM)
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
#2391898 - 10/23/17 02:45 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
938-DAN Offline
Loc: New Jersey
For Sale:
Matched set of carburetors for 1971 426 Hemi engine with manual transmission. Front is 4742s dated ML9; rear is 4745s dated ML9.
Rear carburetor mounting flange was repaired. Repair appears to have been professionally done; will not affect fit or function and will be difficult to see when installed.
Nice set of cores to rebuild or restore. Price is $4,000.00 for the pair; shipping within the continental US included. Please email with questions or for additional pictures ASonn86814@aol.com .
Thank you.
Edited by 938-DAN (10/23/17 04:23 PM)
#2392553 - 10/24/17 07:20 PM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: HemiGreg]
ScottSmith_Harms Offline
Mr Wizzard
Loc: Spokane Washington
Hey Greg, any chance you can call me? 801-940-2689 Thanks, Scott
#2394599 - 10/29/17 01:10 AM Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Vintage Donovan gear drive for big block Mopar and 426 HEMI, I do not have the cam gear or the crank gear, what you see in the pictures is what I have $275.00 (708)288-2879 Scott
Page 1 of 3 1 2 3 >
24,963 Registered Members
185,379 Topics
D-Series drop spindles
by olwhite64
11 minutes 41 seconds ago
New project- '66 A body
by dfsmopars
Today at 04:01 PM
What is this space saver rim from?
by cnxt
Today at 03:17 PM
3766077 rims, what are they?
by cnxt
Today at 03:13 PM
