Page 1 of 5 1 2 3 4 5 >
#2379625 - 09/30/17 09:51 PM For Sale - Big Block Engine - 4th Quarter
moparts Offline
#2379787 - 10/01/17 07:31 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
Suregrip391 Offline
Loc: USA
1967 C440 HP engine block, intake manifold, exhaust manifolds, distributor, carb, oil pan, waterpump housing, windage tray, radiator, balancer, air cleaner, crankshaft, wood wheel, underhood and under dash wiring, misc interior trim, side door glass, will update list later today, more parts included .$3500/all. Perfect fit for your 1967 Plymouth GTX or 1967 Coronet RT. Block cast in 1966, assembly date on front pad 2/2/67.
Edited by Suregrip391 (10/20/17 01:01 PM)
Edit Reason: Add pic
#2379922 - 10/01/17 11:44 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
budman1965 Offline
Loc: Edison, NJ 08817
70's era single snorkel air cleaner-has black wrinkle paint-good condition-no dents or damage-needs blasting and repaint Asking $80
Contact Bud 732-287-0982 or Kramden426@aol.com
#2379933 - 10/01/17 12:05 PM A12 Six Pack Carbs [Re: budman1965]
70sixpkRT Offline
Loc: South San Francisco, Ca
I have a set of Six Pack manual carbs for an A12. Front: Date code 1229 part# 4393. Center: Date code 1229 part# 4391 for manual. Rear: Date code 0929 part# 4394. All 3 carbs are untouched and in good condition.
$1600 + shipping.
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
#2380014 - 10/01/17 02:13 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
@#$%&*! Offline
New user name, Same old jerk!
Loc: 1940 North Victory Boulevard ...
Holley Street Dominator Intake Manifold RB 440-413
Blasted clean and washed with soap and water. All threads good and chased, never ported, no signs it was ever milled. Someone did shorten the front coil mount pedestal for some reason but it still has enough threads to hold a coil. Perhaps will work with a small-block coil bracket, I should try that.
$200 plus shipping
not offended by offers
PM through board
#2380018 - 10/01/17 02:21 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: @#$%&*!]
@#$%&*! Offline
'187 Oil Pan and Windage Tray
Factory 187 oil pan for big-block engines and factory windage tray. Good condition, OE paint!
$125 plus shipping
PM through board
#2380023 - 10/01/17 02:27 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: @#$%&*!]
@#$%&*! Offline
Timing Cover
Not much more to say about it 'cept it's for '72-back with timing tab on passenger side.
$30 plus shipping
PM through board
#2380030 - 10/01/17 02:32 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: @#$%&*!]
@#$%&*! Offline
933 Oil Pan
Not sure of the original application, maybe Imperial? Drain plug on the side of the sump instead of rear. Otherwise like other C-body BB oil pans in most respects.
$60 plus shipping
PM through board
#2380038 - 10/01/17 02:41 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: @#$%&*!]
@#$%&*! Offline
BB Truck Oil Pan + pickup and dipstick
Fits '72-'93 I believe. Dipstick tube may be bent, not sure of original shape but it's just tubing with a flare on the end and can be easily fabbed.
$125 plus shipping
PM through board
#2380246 - 10/01/17 08:02 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used Crane cam #278-2. Cam only, no lifters. $75
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner hose. $20
Cal Custom 14" aluminum air cleaner with filter. $100
1970 Big block single nipple oil breather with hose. $35
New 12" oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
Cal Custom 9" finned air cleaner top and base. No filter. $75
Mr. Gasket 1" thick carb spacer. $15
137 Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
1972 400 parts. Oil pump $5, various AC brackets $50 for the lot, spark plug shields $15 pair, exhaust manifold heat stove for non-hp manifolds (needs a little straightening) $15. $50 for everything.
Carb. throttle linkage pin. $10
Pair of big block exhaust manifolds. Part numbers 3830800 & 3830820. $80
Pair of big block exhaust manifolds. Part numbers 2532626 & 2532464. $100
Pair of big block heads. Part number 2406516. $100
Prices do not include shipping. gt340 at yahoo.com
#2380312 - 10/01/17 09:37 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
bill440rt Offline
Loc: NJ, USA
HEMI “215” fan with clutch. No numbers on the clutch, but does not appear to be a "short shaft" type clutch. Clutch is tight. Very minor surface rust in spots on the fan, but no pitting. Very nice part overall.
Price is $120 plus shipping.
PM here or email bill440 "AT" optonline.net if interested.
Thanks!
#2380551 - 10/02/17 11:25 AM 440 HP blocks, '68 and '71 [Re: bill440rt]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
D 440 HP (1968) Magnum Mopar block with matching main caps. This is a BARE block.
No damage and in great shape.
Bores are .030" over currently and looks like it just needs a quick hone to be used at that size.
Cast date 3/29/67, build date 12/23, VIN 8B240592
I also have a G 440 HP (1971) block and it's main caps (again, a bare block) that's currently .040" over and has a professionally installed sleeve in the #5 cylinder. The motor had been run since the sleeve, so there's no problem w/ it. It only had a scratch in the cylinder wall, no cracks or holes, that caused me to sleeve it.
Cast 12/16/70, built 1/11, VIN 1A150062
$400 each. No shipping, but I will wrap in plastic, strap to a pallet, and drop off at one of the local freight shipper.
I do take paypal if you cover the fee.
PM me here or call/text 843-431-8376
Thanks, Chip
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan SXT...baby hauler
#2380726 - 10/02/17 04:18 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
DudleyPerformanc Offline
Loc: North Carolina, USA
Wiseco 440 Pistons 55 Over *New in the box*
$395
Located in Walkertown NC
Near Winston Salem
Contact by Phone @ 336-595-2000
[img:center]http://[/img] [img:center]http://[/img]
Mark Dudley Performance and Parts
Walkertown, NC 27051
(336) 595-2000
We offer a complete line of High Performance
Parts, Engines, Transmission and Body needs for
1960-1970's Mopar's from Street to Strip.
#2380774 - 10/02/17 05:39 PM : For Sale - Big Block Engine - 4th Quarter [Re: DudleyPerformanc]
docr Offline
Loc: Indiana USA
For Sale:
OEM “One Year Only” – 1967 440 HP Dodge Coronet R/T, Plymouth GTX or Charger - Dual Snorkel Air Cleaner (top lid/base), with vent nipple on lid
4-1/4” hole diameter in base (for original AFB Carburetor), 3-1/2” OA height.
(Difficult to find with this base) **** Excellent condition ****
Comes with Super Commando Pie Tin (Fixed to lid)
$425.00 plus shipping and insurance
E-mail only at sacdrose@att.net
Located in the 46530 (Northern Indiana) zip code
***** THANKS TO MOPARTS.COM *******
#2380789 - 10/02/17 05:54 PM Re: : For Sale - Big Block Engine - 4th Quarter [Re: docr]
docr Offline
Loc: Indiana USA
For Sale:
ONE YEAR ONLY – 1967 R/T or GTX --- 440 HP (Auto)
Single Point Distributor PN2642748. **** SOLD ******
ONE YEAR ONLY – 1967 440 (HP) Drivers Side (left) Exhaust Manifold.
PN 2806974. For Dodge RT or Plymouth GTX (Dated 10-?-?)
$260.00 (Includes shipping in lower 48 )
Carter 3253S- AM1 AFB '62 361CI (305 Horse Power) A/T – HP Dodge or
Power Pac Ply. ---- (Missing auto spring coil thermostat assembly) --- $60.00
Carter 4328S AFB (Same as 4326S, but with C.A.P.) – F6 Date (June ’66), w/Tag – Manual ----- $65.00 (Missing some linkage parts) – ’67 440 HP, one year only (A-134) – Needs work, 2 Throttle plates stuck.
Carter 4329S AFB (Same as 4327S, but with C.A.P.) – A6 Date (Jan. ’66), w/Tag – Automatic ----- $85.00 - ’67 440 HP, one year only (A-134)
(All carburetors most likely need rebuilt – Shipping extra)
***** THANKS MOPARTS.COM *****
Edited by docr (11/18/17 07:06 PM)
Edit Reason: Distributor - SOLD
#2380805 - 10/02/17 06:12 PM Re: : For Sale - Big Block Engine - 4th Quarter [Re: docr]
docr Offline
Loc: Indiana USA
For Sale:
Nice OEM – 1965 to 1967 Mopar- Single Round (2-1/4”)
Snorkel Air Cleaner (lid/base) (17' dia)
(“CAP” air nipple on side of lid)
4-1/4” hole diameter in base (for original AFB Carburetor), 3-3/4” OA height.
Accepts standard pie tins on lid
$60.00, (Includes Shipping in lower 48)
#2380959 - 10/02/17 09:29 PM Comp Cams High Energy Timing Set [Re: docr]
mopars4life Offline
Loc: Virginia
Comp Cams High Energy Timing Set - Big Block - New in the Box
I have a new high energy timing set- solid but single link. Retails for $45 but will sell for $35. Moparsforlife@hotmail.com.
#2381382 - 10/03/17 06:09 PM 1969 440 Hp from GTX [Re: mopars4life]
davesmopars Offline
Loc: cheshire, ct
1969 440 HP block
Built By Comp U Flow
528 pump gas E Z Heads
Built for the street
Dyno over 700 HP with sheet
Torque 650
Dyno time only
10.6 to 1 with aluminum heads
Long list of parts all good stuff and work done
14,500 invested
Best offer
only reason selling is I change direction in my 68 Barracuda Installed a 604 Hemi
It was going into an a body with factory mounts
Edited by moparts (10/23/17 09:42 AM)
Edit Reason: Ad Needs A Price or will be Deleted
#2383184 - 10/06/17 08:40 PM Edelbrock Mopar 440 RPM intake Edelbrock 1414 800 CFM carb [Re: moparts]
sawdust Offline
Loc: Green Lane, PA
Like new Edelbrock RPM intake, Mopar branded but same intake made by Edelbrock. Also Edelbrock 800 CFM carb in excellent condition. Electric choke, stock jets and metering rods. Used for about 15 miles, ran awesome but wanted more old school look. Switched to dual quad setup so no longer need. $500.
info@kriebeldesigns.com or PM me here.
1967 RO23 4 speed
1967 RO23 4 speed "Poison Ivy"
1967 RO23 4 speed "A-Town Hustler"
1967 NSS Belvedere Post 4 speed
1970 Triple red hemi cuda
2016 PCP Hellcat M6
#2383538 - 10/07/17 05:27 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
hemienvy Offline
Loc: Washington
All for Sale, my 511 RB project:
1977 440 block, now .030, cleaned, magged, and sonic checked.
The sheet is posted here. Sonic numbers are the .030 numbers,
they look pretty good.
KB billet 4.25 crank, magged, all standard, already has a bunch of mallory.
New Hemi rods and Ross 4.375" flattops, plus a used Fluiddampr.
Rebuilt 906 heads, mild port cleanup, new valves/springs/
hardware. Springs are Engle 594/595 double spring for .575"
solid flat tappet. Valves are 2.14/1.81.
Used and dinged up Hooker 5209 headers, but they are ceramic
coated, and have evac tubes.
Weiand Street Dom + Holley 4781-2 850DP/manual choke.
I didn't have them in the pics, but I'm including a set of
valve covers, I have cast Indy and old M/T finned, your choice.
I calculated right at 9.5~9.6 CR using shim head gaskets.
So, I think $3500 is a fair price, it's all good stuff. I live
north of Seattle. I'd prefer you come and visit me, which of
course limits my buyers, but I will crate it up to ship if you
are willing to pay, that could easily be $500+ though.
I can take as many pics as you need, just contact me.
OK. No pics yet. The sonic sheet is a PDF and the pics
are all too big so I'm trying to re-size. Please stand by.....
I give up on the pics, I can't get them small enough. I'll
email pics and sonic sheet to whoever wants them.
Edited by hemienvy (10/08/17 02:54 PM)
Edit Reason: very trying
#2384202 - 10/08/17 10:05 PM For Sale RB Wedge Stock Appearing, FAST, NSS, [Re: moparts]
RalphsRapidTrnst Offline
Loc: Bristol, CT
For Sale is your chance to buy the best Stock Appearing Drive Train for your 1967 to 1972 Mopar.
I am offering a just freshened one season 496CI RB-Wedge Motor. The Block is a late casting 440 sonic checked, magnaflux, line honed and decked. Bored and Stroked to 496CI. with 12 to 1 Compresion. The heads are Dwayne Porter Racing Open Chamber Cast Iron heads legal for any build from 1967 to 1974. Internals include Ferrero valves and the best valvle springs available. Ported to full capacity for maximum performance. The Cam is a full rollor spec'd out by Dwayne Porter Racing with nothing but the best Harlen Sharp Rockers and Smith Brothers Components. This is a complete Motor that can be heard running in my 1971 GTX. Also Available if interested is the 6BBL induction System intake and carbs that are tuned and ready to go. It doesnt stop there! Available is a complete full Rollor 727 Transmission with a manual forward valve body (that works great with a slap stick) built by the Best Randy Juliani Just freshened up as well. A one year old Lenny Stock Appearing Ultimate Convertor Concepts convertor built for this combinations.
[b]Here are the performance numbers.
In a 1971 Plymouth GTX this combo with exhaust manifolds and a full 2.5 inch exhaust in a 4300Lb. GTX runs 11.3's at 123MPH.
The price!
$7500.00 for the 496CI Oil Pan to Valley Pan
$10,500.00 496 with Tuned Six Pack
$12,500.00 496, Complete Six Pack and Complete Trans and converter
Also Looking to Trade for Hemi Parts of Interest.
This combo is 100% Stock appearing legal and FAST Legal. Can also be used in any NSS class racing or bracket classes. A great combo for any Mopar MuscleCar.
Call or Email me 860 416-one228 RalphsRapidTransit @ Hotmail.com
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
#2384286 - 10/09/17 04:31 AM Re: For Sale New pcv valves with caps and pcv valves only [Re: RalphsRapidTrnst]
mosweethemi Offline
Loc: VA.
Hello I have a lot of PCV Valves new with caps and with out. Some caps has been painted engine paint .I have about 80 new in the pack they can in .Also one 273 ,426 Wedge or 426 Hemi Chrome cap,$35.00 ea plus shipping .Some caps was powder coated $45,00 ea . Single PCV Valves in the pack $25.99 ea plus shipping . Chrome cap $75.00 plus shipping . zip code 24477 e-mail me at (mosweethemi@yahoo.com ) also on here and call me at 540-337-4310
#2384398 - 10/09/17 10:49 AM Holley Six Pack Carburetors Carbs [Re: moparts]
rocket34 Offline
Loc: Virginia, USA
Holley Six Pack Carbs
Promax rebuilt these a couple years ago, tested them on a mule engine, I took them off the car a few months ago. I replaced them with new carbs and it runs exactly the same.
LIST - 4392 1209 (April 30 1969) -69 1/2 440 AUTOMATIC CENTER CARBURETOR - $550
LIST 4790 2247 ( show contact info Repro 1970 340 OUTBOARD $250
LIST - 4365 - 1 0595 (1975?) 1970 440 REAR OUTBOARD - $250
$850 for all three
Trades/plus or minus cash: for 69 Road Runner six pack hood, B Body Dana 60 , Hemi Transmission, FASS for 06 Dodge Ram Cummins, HD Rear bumper for 2006 Dodge Ram , 45 or 100 lb olympic plates etc. A lot of these would depend on locality.
69 Road Runner work in progress
#2384410 - 10/09/17 11:02 AM 383 Magnum Intake [Re: rocket34]
mopars4life Offline
Loc: Virginia
383 Magnum Intake
Removed from a 1970 Dodge Super Bee. $70 takes it.
#2384411 - 10/09/17 11:03 AM 1969 383 Shortblock [Re: mopars4life]
mopars4life Offline
Loc: Virginia
1969 383 Shortblock
I have a 1969 383 engine out of a coronet. It should be stock bore and untouched. The cylinder walls were lubricated to prevent rust and it spins nicely. It has the balancer, oil pan and I also have a water pump housing for it. $350 takes it – must pick up! moparsforlife@hotmail.com
#2385068 - 10/10/17 11:16 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
4 bbl intake manifold with 6/30/66 casting date. Correct for '67 440 HP but will fit any RB engine. Asking $60 plus shipping. Paypal, money order or check. PM me on the board. SALE PENDING
Edited by AndyF (10/13/17 08:20 PM)
#2385150 - 10/10/17 02:37 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
++MAX WEDGE++ Offline
Loc: Near Columbus, Ohio
1967 383 engine. Pressured checked and magged 300.00 obo
Edited by ++MAX WEDGE++ (10/14/17 07:15 AM)
#2386175 - 10/12/17 08:47 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: KOS]
jonesboys Offline
Loc: waynesboro va
1971 440 engine complete 500.00 contact billy dickerson 540-470-4398 im listing for a friend and can answer most ? non hp looks original still has factory valley gasket in place also lots of cyl head cores 906-452-346 casting numbers
#2387134 - 10/13/17 09:35 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
moparply Offline
Loc: NJ
NOS Max Wedge swinging oil pickup base, mint condition, $400
Very rare. Always cracked, bent or damaged.
Mail kenei@comcast.net
#2387363 - 10/14/17 12:58 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
old_racer Offline
Loc: Wi.
almost new crane solid roller cam ir-280/4778-8 a few dyno runs can hardly see witness marks from lifters, 717 lift, 280@.050dur. .012 lash. have cam card. an original box. $125.00
email for pic's
hemimax@hotmail.com
#2387410 - 10/14/17 02:54 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
DusterW2 Offline
Loc: Portsmouth, VA
MP main bearing set for B engine, P/N P4286971, 010 undersize, NEW $75 + shipping from 23703.
Clevite 77 main bearing set for RB engine, P/N MS-877P, (P series), STD, NEW $75 + shipping from 23703.
Fel-Pro Head Gasket, P/N 1009 (Only One), NEW, $35 + shipping 23703
Fel-Pro Head Gasket Set, P/N 8519PT (Two), NEW, $30 + shipping 23703
jduster340@verizon.net or PM DusterW2 (Prefer US Postal Money Order)
1972 Duster 340 W2, 904; 11.21/118.7, 60' 1.55 1971 Duster 340, 727; 13.04/105, 60' 1.88
#2387629 - 10/15/17 08:22 AM 68 383, needs assembly [Re: moparts]
cbusters Offline
Loc: Florida
1968 383 Dodge, Plymouth, Complete Engine apart, +.030 Bore, 10/10 Crank
All Parts Date Coded with Correct Production Line Castings for a 68 Car unless noted:
New Included:
Pistons (pressed on rods) & Rings
Comp Cam W/Lifters(Purple Cam Specs)
Cam Bearings installed
Timing Chain and gears
Water Pump
Oil Pump
Valley Tray
Bearings
Exhaust Manifold studs & nuts
Freeze Plugs
Gaskets, seals
Used Included:
Block +.030
Heads & bolts
Crankshaft 10/10 with Pilot Bushing
Rods
Intake & bolts
Exhaust Manifolds w/good valve, studs, nuts for 69 B-Body (w/baked-on Eastwood cast finish)
Water Pump Housing & bolts
Timing Cover, oil deflector & bolts
Balancer w/bolt & washer
Valve Covers & bolts
Rear seal retainer & bolts
Valley Tray end bars & bolts
402 Oil Pan & bolts
Windage Tray
Oil Pump pickup
Stock Rockers, Shafts and Pushrods
Crane Adjustable Ductile Rockers
Distributor (incorrect) w/Pertronics Conversion and Pertronics Coil
Like new Edelbrock AVS
Motor Mounts & bolts
Brackets, Pulleys (detailed) for Alternator, Water Pump and Power Steering
Coil Bracket & bolts
Throttle and Return Spring Brackets
Cooler Lines
4 Blade Fan w/Spacer & Bolts
No need to chase down missing parts
Included: Later Model 727 & Converter w/Old Unrun Rebuild
$3200
#2388342 - 10/16/17 06:00 PM Re: 68 383, needs assembly [Re: cbusters]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
V8 Big block single point tune up kit for aluminum distributors
mallory brass insert black hd cap
mallory tan super duty riveted rotor
mallory super duty contact points
std strap type condenser
$40
cowgerwilliam035@gmail.com
#2388683 - 10/17/17 10:20 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
KOS Offline
6pak air cleaner lid.....$80.paypal ok PM me
#2388971 - 10/17/17 07:09 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
mopars4ever Offline
Loc: md
A pair of mopar exhaust flange gaskets part number 3818115 $12.00 Shipped US PM me.
#2389741 - 10/19/17 09:16 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
crabman173 Offline
Loc: Big Lick , North Carolina
Jan 1968 D 440 engine fresh built
Started with perfect core-factory steel crank, LY, Wiseco forged flat tops , balanced, new Hemi pan, double roller, big summit cam 224/234 at 050, Fel Pros, 346 heads all new guides, new valves, springs, Cm retainers, factory rockers, perf RPM intake new, new Rick Ehrenburg Mopar electronic distributor
NICE 440 should make 410 HP easy as pie Tire melter that will still operate vacuum assec's with ease and just be a good fun 440 --located in NC can ship cheap as dirt--$4999 firm dusterdave173@gmail.com or 704 244 6649 Thanks
Description: 6
I have always had a fascination with fast cars at the expense of more normal character development
#2390017 - 10/19/17 06:59 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
E-Ticket Offline
Loc: Louisville, KY
Holley Street Dominator Intake For RB Motor.
$195.00 insured UPS shipping included in the lower 48!
Interested parties please PM me.
Thanks for the ad space Moparts!!!
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
#2391288 - 10/22/17 01:38 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
tntauto Offline
Loc: MI
I have 2 1970 440 HP Motors with 6 pack internals.
Complete from Intake to Oil Pan..
Both are Standard bore.
1 is Cast August of 1969 0G119566
the other is cast December of 1970 0G192825
$2,500 each..
I do not know how to load pictures on this site..
Text or Call 586 484 4o39 for more info and pictures.
Edited by tntauto (10/25/17 06:28 PM)
#2391578 - 10/22/17 11:18 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
Frank Losurdo Offline
Loc: Illinois
I have a 1972 440HP six pack motor, 1971 casting year, Forged crank, flat top pistons, VIRGIN BORE, it is original, I have multiple pairs of heads so you can choose what heads. $1000
Elburn, Il
Email: frankshemi@gmail.com or call/text (630)816-7164
Edited by Frank Losurdo (10/22/17 11:19 PM)
#2391844 - 10/23/17 01:15 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
torredcuda Offline
Loc: NH
2 440 engines complete, "running when pulled" , one `74 and one `75, $700 ea or B.O. , pick up only in Epping NH
https://www.facebook.com/pages/Northeast-Mighty-Mopar-Club/365435766974452?ref=aymt_homepage_panel
`72 Barracuda 340/4spd
`70 road runner 383/auto
`70 Duster 360/auto drag car
`71 Duster project
`76 W100 clubcab project
`83 W350 plow truck
#2391972 - 10/23/17 04:53 PM Jones Cam Designs (Mike Jones) BB Solid Roller cam [Re: torredcuda]
BradH Offline
Loc: Valhalla... eventually
This is a NIB (New In Box) BB Mopar solid roller from Jones Cam Designs (http://jonescams.com). It's intended for a fairly hot 440-ish c.i. street/strip application. It uses his inverse-radius endurance lobes and can be run with up to 1.7 rockers with the proper valve train components (i.e., you're not limited to running 1.5s).
Seat duration: 308/312
Duration at .050": 259/261
LSA: 109; suggested ICL 106
Lift:
- 1.5: .636"/.631", .016" hot lash
- 1.6: .678"/.674", .018" hot lash
Also, the #4 journal is grooved for full-time rocker shaft oiling, per my request when I ordered it.
The original cost was over $400, and Jones' cam prices have increased significantly since I purchased it.
The price is $330 shipped to the lower 48 US states. I accept USPS money orders and cash. Sorry, no PayPal or international sales.
Please PM me here, or text 7-zero-3 - 3-one-7 - 7-nine-8-seven... Thanks!
FYI, here are the build specs I provided to Jones Cams originally:
- Street/strip application
- 451 cubes
- 10.8 CR (93 E10 octane pump fuel)
- Ported Edelbrock Victor heads (std port, not MW)
- 1.6 intake / 1.5 exhaust rockers
- Single-plane intake w/ 950 4150 carb
- 2" headers w/ full 3" exhaust
- auto w/ 9.5" converter 4200-stall (4500 flash)
- 3800#s car & driver
- 4.10 gears & 28" tires
- max RPM 7000 (1/4 mile trap RPM)
Edited by BradH (10/31/17 04:52 PM)
#2391974 - 10/23/17 04:54 PM Two Edelbrock Victor 440 Intake Manifolds [Re: BradH]
BradH Offline
11.21.2017 Update: Both intakes are sold.
11.8.2017 Update: Jet Hot-coated intake sold; other intake still available.
I have for sale two (2) used Edelbrock 2954 Victor 440 manifolds (standard port w/ 4150 flange). Both are used, but neither has been touched by a grinder that I can tell.
One is exactly as it came out of the box, other than some gas stains and port matching scribe marks. I purchased it used locally, but never ended up using it.
The other had been Jet Hot coated both inside and out before I took it on trade in a parts deal, although it's unmodified otherwise. Never ended up using this intake, either.
They sell new from Summit, Jeg's, et al, for about $320.
The price for EACH is $220 shipped to the lower 48 US states. I accept USPS money orders and cash. Sorry, no PayPal or international sales.
Pic shows coated intake on left, if it's not obvious in the image.
11.1.2017 - MOPARTS SPECIAL! EITHER INTAKE FOR $200 SHIPPED, PER ABOVE.
Edited by BradH (11/21/17 11:06 PM)
#2392724 - 10/24/17 11:51 PM Indy 440-1 Top End [Re: moparts]
dart69bigblock Offline
Loc: Omaha, NE
**Sold***
Selling a used pair aluminum 440-1 heads that have been ported and have SS valves. They come with 1.6 Jesel shaft rockers, aluminum valve covers and a Indy 4500 flange intake that has been gasket matched. I bought these used a few years back from a member on here and have since changed directions. I do not have flow numbers as he did not have them when I bought them. Asking $3000/obo. Call text or email. 402-650-3101
chrismstucker@gmail.com
I have more pictures I can send or take any if you want to see something specific.
Edited by dart69bigblock (11/19/17 10:40 AM)
#2394066 - 10/27/17 09:33 PM Big Block Exhaust Manifolds [Re: dart69bigblock]
mopars4life Offline
Loc: Virginia
Believe to be from full size or truck. $100 for the pair. moparsforlife@hotmail.com
#2394207 - 10/28/17 11:30 AM indy ez heads -intake [Re: mopars4life]
komninon Offline
Loc: chicago il usa
indy ez heads mw
indy intake mw
holley 850dp with dual line and carter mechanical fuel pump
msd distributor
still on my 68 charger. porter racing heads did all the work
great condition low miles. Going EFI...
located in Chicago come check it out go for a ride. all paperwork from PRH
$2900
#2394339 - 10/28/17 05:41 PM Mr. Gasket 6007, Aluminum 2 Inch 4BBL Carburetor Spacer. [Re: cbusters]
streetkit Offline
Loc: Northern CA
Mr. Gasket 6007, Aluminum 2 Inch 4BBL Carburetor Spacer. Used but in excellent condition. Will come with 2 new open plenum 4bbl gaskets.
$25 shipped to your door anywhere in the USA.
glolas@comcast.net
Edited by streetkit (10/28/17 05:44 PM)
1973 Dodge D100
#2394584 - 10/29/17 12:40 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Original 1970 440 SIX PACK 4-speed dual point distributor, The shaft is tight but spins freely, I have tested the vacuum advance, it pulls, I have installed a new lead wire, part #3438314, date code 44-9 $750.00 (708)288-2879 Scott
#2394589 - 10/29/17 12:48 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One pair of 1973 400 and 440HP exhaust manifolds in nice used condition RH casting #3751074 date code A153, LH casting #3751068, date code 12,21,72, both manifolds are in nice used condition $350.00 for the pair (708)288-2879 Scott
#2394592 - 10/29/17 12:55 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1971 440HP 4-speed Carter AVS carb, date code G0, nice used original carb $300.00 (708)288-2879 Scott
#2394595 - 10/29/17 01:03 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1969 440 HP automatic carter AVS carb #4618, date code L8, excellent core to restore $300.00 (708)288-2879 Scott
#2394598 - 10/29/17 01:08 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Vintage Donovan gear drive for big block Mopar and 426 HEMI, I do not have the cam gear or the crank gear, what you see in the pictures is what I have $275.00 (708)288-2879 Scott
#2394752 - 10/29/17 10:59 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
bbtrux Offline
Loc: ohio
78 400 engine , turns easily by hand -$400.00 OBO ; 400 block with caps and crank - $300.00 OBO ; cast RB intakes , some square bore , some spread bore , $25.00 each OBO . Call or text 419-512-1612 , or e-mail rocknwrench@gmail.com. Thank you.
Edited by bbtrux (11/21/17 08:47 PM)
#2394904 - 10/29/17 02:02 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: bbtrux]
dsd70bee Offline
Loc: oak park, il.
1970 and 1971 440 SIX PACK base plate and lid $550.00 (708)288-2879 Scott
#2394916 - 10/29/17 02:22 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: dsd70bee]
chrisnben Offline
Loc: Madison, Wisconsin
Brand new TTI brand 383/440 headers for B or E body Mopars. Polished Ceramic coated outside & thermal barrier on inside. Steps from 2" to 2-1/8" primaries & 3-1/2" collectors- part #440-218. Recommended for 500+ HP engines. (retail is $950) $750 pair, save $200!.
message me here, thanks.
Edited by chrisnben (10/29/17 08:25 PM)
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
#2394926 - 10/29/17 02:36 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
chrisnben Offline
1968- 383 engine with knife-edged forged crank. comes with 30 over Speedpro pistons and new ring set. Block is standard bore now & disassembled(I can have it bored for cost). Very clean, stored correctly. Also has 906 heads, timing cover but no intake. $400 total for quick sale.
Can ship via Fastenal most anywhere for $200. I charge $100 for palletizing/dropoff. Paypal accepted with 3% added.
Message me here, thanks.
Edited by chrisnben (11/07/17 09:36 PM)
#2394991 - 10/29/17 05:09 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1969, 1970 and 1971 426 HEMI oval air filter NOS in the box, this is the real deal, never installed on a car $650.00 (708)288-2879 Scott
#2395051 - 10/29/17 07:32 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Weiand tunnel ram type 440 SIX PACK intake manifold, excellent used condition $1350.00 (708)288-2879 Scott
#2395059 - 10/29/17 07:46 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One set of original Max Wedge rocker arms and stands $300.00 for everything (708)288-2879 Scott
#2395643 - 10/30/17 06:57 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1970 440 HP single point distributor, part #3438222, date code 44 9, this distributor is in excellent used condition, I have tested the vacuum advance, it pulls, the lead wire is in good condition $375.00 (708)288-2879 Scott
#2395853 - 10/31/17 12:18 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
Moparguy383 Offline
Loc: Cumberland, MD
Pair of nice older headers for a big block, they have a few dings and clearance dents but otherwise very nice. They are not rusted out, thin junk. These are well made headers, 2 inch primaries, 3.5 inch collectors. I bought these off of a buddy in 1991 and they have been stored in my climate controlled shop ever since. I had them sand blasted and coated with Eastwood's silver high temperature coating. They would be on my car now, but I found out they will not work with power steering. $275 plus shipping. I will take Paypal if it is sent as a gift.
Email me moparguy383@hotmail.com for more pictures or information.
#2395860 - 10/31/17 12:25 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: Moparguy383]
Moparguy383 Offline
Loc: Cumberland, MD
Edelbrock TM7 intake manifold. Has had some smoothing and shaping of the runners. $165 plus shipping. I will take Paypal if it is sent as a gift.
Email me moparguy383@hotmail.com for more information or pictures
#2396035 - 10/31/17 11:35 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: Moparguy383]
davesmopars Offline
Loc: cheshire, ct
1969 440 from a GTX full Vin on block
magnaflux and all that stuff
open up oil passages
40 over
line hone squire decked
bored with block plates
eagle crank stroke 4.375
eagle rods 7.1
custom ross pistons
rings c&a
clearance block
fluid damper balancer
balanced rotating assembly
studied mains
oil pump indy max
cam shaft custom solid roller comp 698
comp roller lifters
timing chain billet tour.
stroker windage tray
milo pick up
pro fit rear seal
bronze gear
ez head kit
up graded plate
ported, but not maxed ported. flow 305 int and 217 exhaust
up graded valve string 943
up graded 10 ' locks and titanium retainers
pro fit seals
H sharp 1.6 rockers
custom push rods
assembly, clayed, cam degree
m1 intake with work done to it. nick sail with the work done to this intake he get more out of it than the victor. A lot of work done to the intake
welded up plenum, plenum work matched to the two inch indy adapter with work, port matched
1050 AED Tuned to this motor then fine tuned on dyno
indy valve covers
morso breathers
Charlies custom oil pan
Mopar race gasket set
indy adapter
MSD distributor
Dyno with sheet
Head flow sheet
I may have left something out
This is a bad ass motor and its not even maxed out.
This motor was built to drive on the street and go to the track once or twice a year. The only reason I am selling it is because I bought a 604 Hemi off my buddy to go In my 68 Barracuda.
I have way more into this, my loose your gain
11,500.00
until i fix my picture issue I can email pictures
Edited by davesmopars (11/03/17 03:26 PM)
#2396220 - 10/31/17 04:39 PM Mopar M1 Intake RB Single Plane [Re: moparts]
crackedback Offline
Loc: CA
Mopar M1 Intake for an RB engine. Great shape.
$175 + shipping from Indio, CA
It should fit in a USPS flat rate game board box, in the 20-25 shipping range in the US.
PM or email to robule1 at yahoo dot com
#2396223 - 10/31/17 04:41 PM Mopar M1 Intake Small Block Single Plane [Re: crackedback]
crackedback Offline
Loc: CA
Mopar SB M1 Single plane. This is the older model with the squared up thermostat housing. Good shape.
#2396225 - 10/31/17 04:42 PM Indy 400-3 4500 MW Port Intake manifold and valley plate [Re: crackedback]
crackedback Offline
Loc: CA
SOLD
#2396399 - 10/31/17 10:45 PM Re:440 RB Mopar dual plane intake [Re: crackedback]
mattsmopars Offline
Loc: tennessee,usa
Have a mopar performance 440 RB series dual plane intake up for sale. nice intake with no modifications or issues. On the bottom of it is number 4532063. $150.00 plus the shipping cost. PM me if you have questions or if your interested.
Matt
#2396466 - 11/01/17 01:47 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1970 and 1971 cast iron 440 SIX PACK intake manifold, excellent used condition $575.00 (708)288-2879 Scott
#2396576 - 11/01/17 09:47 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: dsd70bee]
kyhemi-dart Offline
Loc: kentucky
I have a aluminum Charlie’s oil pan with the tie rod hole through it. $300
Sean 270-401-8825
#2397394 - 11/02/17 02:30 PM A12 Six Pack Carbs [Re: Bob_Fromm]
70sixpkRT Offline
$1600 + shipping.
4-speed
3:54 Dana
#2397904 - 11/03/17 11:55 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
csmopar Offline
Loc: usa
1968 Mopar 440 block and main caps. Standard bore. 300 obo plus shipping(really prefer pick up on this but can ship fastenal). This block is a good core block, PM me for pics as i'm having trouble still with uploading pics. Will consider trades. Location in Southern Indiana.
#2398809 - 11/05/17 10:45 AM Re: 505 Max Wedge Re: For Sale - Big Block Engine - 4th Quarter [Re: Smoparmike]
Joesixpack Offline
single point v8 tune up kit, with dist lead wire&bushing kit.$50
#2398818 - 11/05/17 10:54 AM Re: 505 Max Wedge Re: For Sale - Big Block Engine - 4th Quarter [Re: Joesixpack]
Joesixpack Offline
361-383-413-440 1964-1965-1966 with AC, temp sending unit. new usa made .$10 each
cowgerwiliam035@gmail.com
#2398910 - 11/05/17 01:34 PM (2) 383 Engines - Need Rebuild - One is a 70 HP [Re: moparts]
Mopar_Mike Offline
Loc: Danville, NH
I have (2) 383 engines I am not going to use. One is a 1970 383HP (F383 3 9 HP) the other a 1971 383 (G383 7 7). Both are stuck and have been sitting for years, indoors though. They are both original bore engines and no cracks or damage. Both need to be rebuilt. Included are 906 heads, 383-4bbl intake, balancer, a 402 HP oil pan, a regular oil pan. $1000 for all parts. All parts need to be cleaned and restored. If you want just the HP block, heads and intake its $700.
Some people have been asking about the VIN on the 70 383HP. It is 0A210648
fas141@comcast.net
Edited by Mopar_Mike (11/07/17 06:14 PM)
RS23L7 440 4-Speed
RS27L7 440 727
WS23L7 484 Hemi - 727 - Dana 4.10
WS27L7 440 727
#2399074 - 11/05/17 07:05 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
SixDRacing Offline
Loc: hobbs, new mexico
8 used diamond pistons #18031. 4.35 bore, 1.882 comp height, 4.15 stroke, 1.09 pin, 18.12 dish, with pins. 200.00
8 used trw? L2185 pistons. 4.25 bore, 3.75 stroke. large dome, with pins.1.09 pin. 100.00.
8 ly rods. 6.76 length, 1.09 pin. arp rod bolts. they have been polished on the beams and top has been rounded. 100.00
shipping on buyer. neracer@hotmail.com. I will send pics to phone or e mail.
#2399274 - 11/06/17 08:57 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
CoDart Offline
Loc: Fort Collins, Colorado
Up for sale is a drivers side HP manifold. Its in great shape, no breaks or cracks. #2951865 manifold. Date code is 6.4.70
$150 plus shipping. Thank you! SOLD!!
#2401985 - 11/11/17 01:36 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: CoDart]
moparjohn Offline
Loc: N.W. INDIANA
1969 and 1970 383 non HP engines for sale.
1) 1969 non HP block standard bore with maincaps, forged crank with standard rod and mains, set of 8 connecting rods, NO pistons, pair of matching 906 heads with head bolts. The engine is apart and ready for rebuild. The price is $200.00.
2) 1970 non HP engine complete as pulled from a 49,000 mile Sport Sattelite. The engine has 906 heads and a cam upgrade. This is a long block with 4161S carb and 36567 distributor included. There are no exhaust manifolds. The price is $400.00.
I am in northwest Indiana near the Indiana Toll Road, I-94 and I-65 Westville / Michigan City for easy pickup! Contact me at moparjohn@frontier.com
Thanks! John
Edited by moparjohn (11/22/17 05:30 PM)
#2402075 - 11/11/17 04:41 PM NOS carter M2769S fuel pump, early max wedge & HP big block [Re: moparjohn]
Rapid340 Offline
Loc: oberlin, Ohio
Box reads: for Chrysler No. 1879 296
$115 plus shipping
jeffpatterson@copper.net
Jeff Patterson 71 Duster 340, Factory Appearing
11.000 122.3 MPH on 6 in. M&H Volkswagen tires.
Intelligence? http://www.youtube.com/watch?v=cpM76ymlnbA
#2402094 - 11/11/17 05:03 PM mopar 440 adjustable pushrods [Re: Rapid340]
Rapid340 Offline
Loc: oberlin, Ohio
These were purchased by someone for a 440 with stock hydraulic valve gear but never were used. There is a little mild corrosion on some. They have been on the shelf for years removed from wrapper.
I rolled them looking for any that may be bent and they appear to be good.
$115 plus shipping
#2402692 - 11/12/17 05:18 PM 1967 HP Exhaust Manifolds - One year Only !!!! [Re: moparts]
R/T1968R/T Offline
Loc: New York
Nice shape, blasted clean.Riser is blocked off, easy fix. Looks like 2806900 and 2806974 casting dates Dec 14, 66 and Nov 15, 66 $350 plus shipping
Edited by R/T1968R/T (11/12/17 05:22 PM)
#2402939 - 11/13/17 08:50 AM Mopar Performance Air Cleaner *BRAND NEW* [Re: moparts]
Sweet5ltr Offline
Loc: Florida
Mopar Performance Air Cleaner Assembly w/ Mancini Drop Base & Wix 2" Filter. Test fit, clearance is too tight with my dominator manifold + 2" spacer.
BRAND NEW - WON'T FIT MY APPLICATION - $90 shipped. PayPal.
Edited by Sweet5ltr (11/13/17 08:54 AM)
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
#2403617 - 11/14/17 03:42 PM Crane Iron Rockers 1.5, 9.130 ball cup Crane Pushrods [Re: moparts]
1KoolBee Offline
Loc: San Diego, CA
SOLD Complete set of 1.5 ratio Crane Nodular Iron rockers . These rockers are good used condition. Rocker tips were redone by Rockers Unlimited and adjusters are excellent. Several rockers have some minor scoring in the bore. PM me your email for pix. Could add banana grooves in shafts and run as-is in milder builds, or send off to Dvorak Machine or Rockers Unlimited and have them bushed which would make them last forever. Included are 3 used chrome shafts that show some wear but should be usable with minor polishing. Springs included. Priced accordingly at $200 plus the ride.
SOLDComplete set of Crane chromoly ball/cup pushrods. 9.130 overall length (tip to top of cup. These are in excellent shape, with almost no signs of any use. I think they are for 413-440 with adjustable rockers and hydraulic lifters (and EDM solid lifters) but you should measure your setup to be sure. $75 plus the ride.
One brand new left iron crane rocker 1.6, bought as a spare for another set of rockers I just sold. $30 plus the ride.
Thanks Moparts
Edited by 1KoolBee (Yesterday at 10:07 PM)
#2403643 - 11/14/17 04:29 PM BB Rocker Arm Spacer Springs [Re: moparts]
BradH Offline
Does anyone need 1 or 2 sets of BB rocker arm springs like the ones that come w/ Crane rockers? I found a couple of sets of 8-each recently while digging up a few spares for someone and figured I'd make 'em available.
$15 per set or $25 for both sets, including shipping in the lower 48.
PM me here. Thanks - Brad
#2403676 - 11/14/17 05:37 PM Firecore dist, MSD coil & MS 8.5mm wires [Re: moparts]
topside Offline
Loc: So Near, Yet So Far
Nearly new (500 miles)for RB: Firecore mech distributor with MSD Blaster2 coil & SuperConductor spark plug wire set. Very nice condition, works perfectly, except 1 plug wire is mismatched due to a header burn.
I changed to a vacuum advance unit & different coil for street driving.
Setup cost $340, but $250 gets it to your door in the US.
PM me here, thanks.
#2403894 - 11/15/17 08:23 AM parts for sale [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
440 six rods and new 0.30 trw six pack pistons $599 set
73-74 440 hp (lh) exhaust manifold $199
72 400-4spd distributer part #3656329 $69
orange park,fl
e-mail: gdmusclecarparts@yahoo.com
shop # 904-272-1803
cell # 904-589-4645
Edited by gdmusclecar (11/15/17 08:24 AM)
#2404184 - 11/15/17 05:35 PM 1978 Thermoquad 9112s and 1973 oem 440 Valve Covers [Re: moparts]
Adam71Charger Offline
Loc: Tacoma, Washington USA
I have a used 78 thermoquad in good condition. Clean and complete. Hasnt been run in years, so a rebuild is in order. I want $50 plus shipping. You can text me at 253 691 4880.
follow the link to see more pictures. Im also selling 2 distributors and 1973 440 valve covers.
20171113_190517 by Richard Bailey, on Flickr
20171113_190616 by Richard Bailey, on Flickr
20171113_190157 by Richard Bailey, on Flickr
20171113_190434 by Richard Bailey, on Flickr
20171113_192843 by Richard Bailey, on Flickr
Edited by Adam71Charger (11/15/17 05:37 PM)
#2404423 - 11/16/17 08:00 AM big block parts for sale [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
440 crossram edelbrock str intake nice $1,999
orange park,fl.
shop # 904-272-1803
cell # 904-589-4645
#2404795 - 11/16/17 11:13 PM 1971 400 Block 230 Cast Thick Main [Re: moparts]
Newbomb_Turk Offline
Loc: Archbald, PA
I have for sale a 1971 400 230 casting thick main block. Casting date 7/71, Std bore, virgin motor. Has 1 broken bolt in water pump mount, not a big deal to fix. Will meet within reason or can pallet & drop off at truck freight shipper. $1200. OBO
Email is the best way to get me
newbombturk1@earthlink.net
Thanks, John
Edited by Newbomb_Turk (11/19/17 02:35 PM)
1971 Demon 440 auto Drag car full tub, Best 10.47 @ 126
#2405382 - 11/18/17 08:42 AM Re: 1971 400 Block 230 Cast Thick Main [Re: Newbomb_Turk]
69 charger man Offline
Loc: NJ
Power steering pump core with pulley. Not really sure what it came off, but should fit a bunch of stuff. 10$ plus shipping. Please pm me. Thanks for the add
#2405654 - 11/18/17 06:17 PM Factory iron intakes [Re: moparts]
gss Offline
Loc: State, country, etc.
Factory cast iron intake manifolds. Good shape, need to be cleaned and painted.
1. 1967 440 HP #2806178, date 2-10-67 $40
2. 1969 383 #2806301 $SOLD
3. 1972 400 #3614046 spread bore, no EGR $10
4. 1976 440 4v #3830949 $10
Prices plus actual shipping from MN 55807
Edited by gss (11/19/17 07:12 PM)
#2405845 - 11/19/17 06:43 AM 3.900" Stroker Crank for B-engine. New. American steel. [Re: moparts]
YYZ Offline
Loc: Toronto (YYZ) Ontario
Brand new Mopar Performance B-engine stroker crank for 361/383/400/426
This is one of the American-made cranks, excellent steel, that was made with a 3.75" stroke, B-engine main journals and an 8-bolt Hemi flange.
I have had the crank offset ground and indexed by a local shop to exactly 3.900" stroke, perfect TDC and 2.200" rod journal sizes for much better rod and bearing choices.
The shop does many cranks for Tim Banning/FHO.
I have almost $2K into the crank with the work, it is ready to drop in.
$800 plus the ride.
inviolet@outlook.com or PM me on the board
#2405897 - 11/19/17 10:31 AM Holley 3310-2 4bbl carburetor. 750 CFM [Re: mopars4life]
streetkit Offline
Loc: Northern CA
Holley 3310-2 4bbl carburetor. 750 CFM Vacuum Secondary Dual Feed Performance Carburetor with a manual choke. This carb is used and it has been sitting on a shelf for a while so it will need to be rebuilt. It is not frozen. Chrome fuel line is included.
$100 shipped to your door anywhere in the USA.
Located in Northern CA.
glolas@comcast.net
1973 Dodge D100
#2406336 - 11/20/17 11:43 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
bbtrux Offline
Loc: ohio
carburetors - 4781-2 850 double pumper off of running car - $200.00 OBO ; Holley 4749-2 , correct for 67-70 383 and 440 in non carter applications , needs rebuild - $50.00 OBO ; carter AFB 3615S ,correct for 64-67 413 , needs rebuilt - $50.00 OBO ; thermoquad 9151S , correct for 78 440 truck , needs rebuilt - $50.00 OBO ; 6518SA , industrial (rv) 440 carb , needs rebuilt - $50.00 OBO ; 6518S thermoquad , industrial 440 (rv) , needs rebuilt - $50.00 OBO ; 6488S thermoquad , correct for 74 360 automatic , needs rebuild - $50.00 OBO - 9182S thermoquad , correct for 78 400 auto , needs rebuild , bowl vent and air cleaner stud bent - $25.00 OBO ; Holley 6180-1 , dont know application , needs rebuilt - $50.00 OBO ; Holley 6189 , dont know application , needs rebuilt - $50.00 OBO . Call or text 419-512-1612 , or e-mail rocknwrench@gmail.com. Thank you.
Edited by bbtrux (11/20/17 11:44 AM)
#2406523 - 11/20/17 06:49 PM 1973 440 Pistons and Rods standard bore [Re: moparts]
1971louvergtx Offline
Loc: melbourne, florida
I am rebuilding the engine in my 1973 town and country, and decided on new rods and bigger pistons. I have for sale the old piston and rod assemblies, 8 each. The engine had approximately 115k miles on it. The pistons are standard bore, and cylinders had acceptable numbers for taper and out of roundness. Pistons are flat top, about 8.2 to 1. LY rods with bolt/nuts.
Engine was never apart until I pulled it down.
Not sure what they would be worth to someone.
$150 or offers PLUS actual shipping from 32935. I hate to throw them in the trash, but don't need them any more.
roadrunner69 (at)cfl.rr.com
321-863-372nine
Edited by 1971louvergtx (11/20/17 06:49 PM)
#2406611 - 11/20/17 09:51 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
H4E2M6I Offline
Loc: Belvidere,IL N.W. Chicago ...
50+ yr old barn find off of a 383. Rare intake and non original Carter carbs. Don't really know that much about this combo or condition of these carbs but they look their age. Part # on manifold reads 1827899-1 and a code ? above that is J 16 7 Selling this combo at $450 This manifold was not factory installed but was only available as a dealer installed performance option or sold across the dealers parts counter. Serious calls only please. 815-218-1733
Edited by H4E2M6I (11/20/17 10:58 PM)
#2407195 - 11/21/17 11:16 PM 440 6 pk coil bracket [Re: moparts]
GKMOPAR Offline
Loc: Hilliard, Ohio
Have a 440 6pk coil mounting bracket. Never used. $20 plus shipping.
#2408289 - Yesterday at 12:49 PM Re: 440 6 pk coil bracket [Re: GKMOPAR]
Joesixpack Offline
7 NOS IGNITION CONDENSERS#1881 757 MOPAR,DODGE,PLYMOUTH WITH # ON IT
FITS CAST IRON DISTRIBUTORS, AND 361-383-413-426-440 DUAL POINT DISTRIBUTORS. $85
Edited by Joesixpack (Yesterday at 12:50 PM)
#2408290 - Yesterday at 12:53 PM Re: 440 6 pk coil bracket [Re: Joesixpack]
Joesixpack Offline
2 NOS MOPAR IGNITION CONDENSERS CH-108
#2875939 WITH PENTASTAR , WITH # ON IT
FITS DODGE&PLYMOUTH CAST IRON DISTRIBUTORS, AND 383 HP 440 HP,426H DUAL POINT DISTRIBUTORS. $50
24,969 Registered Members
185,453 Topics
Feets eat your heart out
by CokeBottleKid
Today at 04:46 AM
70 Cuda Grille and Grille Molding Options
by rss
Today at 02:19 AM
Garage door guys. Help leveling door.
by MoparPosterChild
Today at 12:47 AM
Well, I did it. '17 Challenger.
by 68SportFury
Yesterday at 10:23 PM
