Page 4 of 5 < 1 2 3 4 5 >
#2395860 - 10/31/17 12:25 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: Moparguy383]
Moparguy383 Offline
Loc: Cumberland, MD
Edelbrock TM7 intake manifold. Has had some smoothing and shaping of the runners. $165 plus shipping. I will take Paypal if it is sent as a gift.
Email me moparguy383@hotmail.com for more information or pictures
#2396035 - 10/31/17 11:35 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: Moparguy383]
davesmopars Offline
Loc: cheshire, ct
1969 440 from a GTX full Vin on block
magnaflux and all that stuff
open up oil passages
40 over
line hone squire decked
bored with block plates
eagle crank stroke 4.375
eagle rods 7.1
custom ross pistons
rings c&a
clearance block
fluid damper balancer
balanced rotating assembly
studied mains
oil pump indy max
cam shaft custom solid roller comp 698
comp roller lifters
timing chain billet tour.
stroker windage tray
milo pick up
pro fit rear seal
bronze gear
ez head kit
up graded plate
ported, but not maxed ported. flow 305 int and 217 exhaust
up graded valve string 943
up graded 10 ' locks and titanium retainers
pro fit seals
H sharp 1.6 rockers
custom push rods
assembly, clayed, cam degree
m1 intake with work done to it. nick sail with the work done to this intake he get more out of it than the victor. A lot of work done to the intake
welded up plenum, plenum work matched to the two inch indy adapter with work, port matched
1050 AED Tuned to this motor then fine tuned on dyno
indy valve covers
morso breathers
Charlies custom oil pan
Mopar race gasket set
indy adapter
MSD distributor
Dyno with sheet
Head flow sheet
I may have left something out
This is a bad ass motor and its not even maxed out.
This motor was built to drive on the street and go to the track once or twice a year. The only reason I am selling it is because I bought a 604 Hemi off my buddy to go In my 68 Barracuda.
I have way more into this, my loose your gain
11,500.00
until i fix my picture issue I can email pictures
Edited by davesmopars (11/03/17 03:26 PM)
#2396220 - 10/31/17 04:39 PM Mopar M1 Intake RB Single Plane [Re: moparts]
crackedback Offline
Loc: CA
Mopar M1 Intake for an RB engine. Great shape.
$175 + shipping from Indio, CA
It should fit in a USPS flat rate game board box, in the 20-25 shipping range in the US.
PM or email to robule1 at yahoo dot com
#2396223 - 10/31/17 04:41 PM Mopar M1 Intake Small Block Single Plane [Re: crackedback]
crackedback Offline
Loc: CA
Mopar SB M1 Single plane. This is the older model with the squared up thermostat housing. Good shape.
#2396225 - 10/31/17 04:42 PM Indy 400-3 4500 MW Port Intake manifold and valley plate [Re: crackedback]
crackedback Offline
Loc: CA
SOLD
#2396399 - 10/31/17 10:45 PM Re:440 RB Mopar dual plane intake [Re: crackedback]
mattsmopars Offline
Loc: tennessee,usa
Have a mopar performance 440 RB series dual plane intake up for sale. nice intake with no modifications or issues. On the bottom of it is number 4532063. $150.00 plus the shipping cost. PM me if you have questions or if your interested.
Matt
#2396466 - 11/01/17 01:47 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1970 and 1971 cast iron 440 SIX PACK intake manifold, excellent used condition $575.00 (708)288-2879 Scott
#2396576 - 11/01/17 09:47 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: dsd70bee]
kyhemi-dart Offline
Loc: kentucky
I have a aluminum Charlie’s oil pan with the tie rod hole through it. $300
Sean 270-401-8825
#2397394 - 11/02/17 02:30 PM A12 Six Pack Carbs [Re: Bob_Fromm]
70sixpkRT Online   content
Loc: South San Francisco, Ca
I have a set of Six Pack manual carbs for an A12. Front: Date code 1229 part# 4393. Center: Date code 1229 part# 4391 for manual. Rear: Date code 0929 part# 4394. All 3 carbs are untouched and in good condition.
$1600 + shipping.
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
#2397904 - 11/03/17 11:55 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
csmopar Offline
Loc: usa
1968 Mopar 440 block and main caps. Standard bore. 300 obo plus shipping(really prefer pick up on this but can ship fastenal). This block is a good core block, PM me for pics as i'm having trouble still with uploading pics. Will consider trades. Location in Southern Indiana.
#2398809 - 11/05/17 10:45 AM Re: 505 Max Wedge Re: For Sale - Big Block Engine - 4th Quarter [Re: Smoparmike]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
single point v8 tune up kit, with dist lead wire&bushing kit.$50
cowgerwilliam035@gmail.com
#2398818 - 11/05/17 10:54 AM Re: 505 Max Wedge Re: For Sale - Big Block Engine - 4th Quarter [Re: Joesixpack]
Joesixpack Offline
361-383-413-440 1964-1965-1966 with AC, temp sending unit. new usa made .$10 each
cowgerwiliam035@gmail.com
#2398910 - 11/05/17 01:34 PM (2) 383 Engines - Need Rebuild - One is a 70 HP [Re: moparts]
Mopar_Mike Offline
Loc: Danville, NH
I have (2) 383 engines I am not going to use. One is a 1970 383HP (F383 3 9 HP) the other a 1971 383 (G383 7 7). Both are stuck and have been sitting for years, indoors though. They are both original bore engines and no cracks or damage. Both need to be rebuilt. Included are 906 heads, 383-4bbl intake, balancer, a 402 HP oil pan, a regular oil pan. $1000 for all parts. All parts need to be cleaned and restored. If you want just the HP block, heads and intake its $700.
Some people have been asking about the VIN on the 70 383HP. It is 0A210648
fas141@comcast.net
Edited by Mopar_Mike (11/07/17 06:14 PM)
RS23L7 440 4-Speed
RS27L7 440 727
WS23L7 484 Hemi - 727 - Dana 4.10
WS27L7 440 727
#2399074 - 11/05/17 07:05 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
SixDRacing Offline
Loc: hobbs, new mexico
8 used diamond pistons #18031. 4.35 bore, 1.882 comp height, 4.15 stroke, 1.09 pin, 18.12 dish, with pins. 200.00
8 used trw? L2185 pistons. 4.25 bore, 3.75 stroke. large dome, with pins.1.09 pin. 100.00.
8 ly rods. 6.76 length, 1.09 pin. arp rod bolts. they have been polished on the beams and top has been rounded. 100.00
shipping on buyer. neracer@hotmail.com. I will send pics to phone or e mail.
#2399274 - 11/06/17 08:57 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
CoDart Offline
Loc: Fort Collins, Colorado
Up for sale is a drivers side HP manifold. Its in great shape, no breaks or cracks. #2951865 manifold. Date code is 6.4.70
$150 plus shipping. Thank you! SOLD!!
#2401985 - 11/11/17 01:36 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: CoDart]
moparjohn Offline
Loc: N.W. INDIANA
1969 and 1970 383 non HP engines for sale.
1) 1969 non HP block standard bore with maincaps, forged crank with standard rod and mains, set of 8 connecting rods, NO pistons, pair of matching 906 heads with head bolts. The engine is apart and ready for rebuild. The price is $200.00.
2) 1970 non HP engine complete as pulled from a 49,000 mile Sport Sattelite. The engine has 906 heads and a cam upgrade. This is a long block with 4161S carb and 36567 distributor included. There are no exhaust manifolds. The price is $400.00.
I am in northwest Indiana near the Indiana Toll Road, I-94 and I-65 Westville / Michigan City for easy pickup! Contact me at moparjohn@frontier.com
Thanks! John
Edited by moparjohn (Yesterday at 05:30 PM)
#2402075 - 11/11/17 04:41 PM NOS carter M2769S fuel pump, early max wedge & HP big block [Re: moparjohn]
Rapid340 Offline
Loc: oberlin, Ohio
Box reads: for Chrysler No. 1879 296
$115 plus shipping
jeffpatterson@copper.net
Jeff Patterson 71 Duster 340, Factory Appearing
11.000 122.3 MPH on 6 in. M&H Volkswagen tires.
Intelligence? http://www.youtube.com/watch?v=cpM76ymlnbA
#2402094 - 11/11/17 05:03 PM mopar 440 adjustable pushrods [Re: Rapid340]
Rapid340 Offline
Loc: oberlin, Ohio
These were purchased by someone for a 440 with stock hydraulic valve gear but never were used. There is a little mild corrosion on some. They have been on the shelf for years removed from wrapper.
I rolled them looking for any that may be bent and they appear to be good.
$115 plus shipping
#2402692 - 11/12/17 05:18 PM 1967 HP Exhaust Manifolds - One year Only !!!! [Re: moparts]
R/T1968R/T Offline
Loc: New York
Nice shape, blasted clean.Riser is blocked off, easy fix. Looks like 2806900 and 2806974 casting dates Dec 14, 66 and Nov 15, 66 $350 plus shipping
Edited by R/T1968R/T (11/12/17 05:22 PM)
#2402939 - 11/13/17 08:50 AM Mopar Performance Air Cleaner *BRAND NEW* [Re: moparts]
Sweet5ltr Offline
Loc: Florida
Mopar Performance Air Cleaner Assembly w/ Mancini Drop Base & Wix 2" Filter. Test fit, clearance is too tight with my dominator manifold + 2" spacer.
BRAND NEW - WON'T FIT MY APPLICATION - $90 shipped. PayPal.
Edited by Sweet5ltr (11/13/17 08:54 AM)
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
24,964 Registered Members
185,410 Topics
1200-1500hp - World iron hemi block?
by Superfreak
11/23/17 03:14 PM
Summit Black Friday Cyper Monday sale
by pittsburghracer
11/23/17 02:45 PM
Why can't i attach a pic to my post?
by PAULS_340
11/23/17 02:36 PM
What bolts to remove when pulling small block?
by PAULS_340
11/23/17 02:35 PM
