Page 3 of 5 < 1 2 3 4 5 >
#2391972 - 10/23/17 04:53 PM Jones Cam Designs (Mike Jones) BB Solid Roller cam [Re: torredcuda]
BradH Offline
Loc: Valhalla... eventually
This is a NIB (New In Box) BB Mopar solid roller from Jones Cam Designs (http://jonescams.com). It's intended for a fairly hot 440-ish c.i. street/strip application. It uses his inverse-radius endurance lobes and can be run with up to 1.7 rockers with the proper valve train components (i.e., you're not limited to running 1.5s).
Seat duration: 308/312
Duration at .050": 259/261
LSA: 109; suggested ICL 106
Lift:
- 1.5: .636"/.631", .016" hot lash
- 1.6: .678"/.674", .018" hot lash
Also, the #4 journal is grooved for full-time rocker shaft oiling, per my request when I ordered it.
The original cost was over $400, and Jones' cam prices have increased significantly since I purchased it.
The price is $330 shipped to the lower 48 US states. I accept USPS money orders and cash. Sorry, no PayPal or international sales.
Please PM me here, or text 7-zero-3 - 3-one-7 - 7-nine-8-seven... Thanks!
FYI, here are the build specs I provided to Jones Cams originally:
- Street/strip application
- 451 cubes
- 10.8 CR (93 E10 octane pump fuel)
- Ported Edelbrock Victor heads (std port, not MW)
- 1.6 intake / 1.5 exhaust rockers
- Single-plane intake w/ 950 4150 carb
- 2" headers w/ full 3" exhaust
- auto w/ 9.5" converter 4200-stall (4500 flash)
- 3800#s car & driver
- 4.10 gears & 28" tires
- max RPM 7000 (1/4 mile trap RPM)
Edited by BradH (10/31/17 04:52 PM)
#2391974 - 10/23/17 04:54 PM Two Edelbrock Victor 440 Intake Manifolds [Re: BradH]
BradH Offline
11.21.2017 Update: Both intakes are sold.
11.8.2017 Update: Jet Hot-coated intake sold; other intake still available.
I have for sale two (2) used Edelbrock 2954 Victor 440 manifolds (standard port w/ 4150 flange). Both are used, but neither has been touched by a grinder that I can tell.
One is exactly as it came out of the box, other than some gas stains and port matching scribe marks. I purchased it used locally, but never ended up using it.
The other had been Jet Hot coated both inside and out before I took it on trade in a parts deal, although it's unmodified otherwise. Never ended up using this intake, either.
They sell new from Summit, Jeg's, et al, for about $320.
The price for EACH is $220 shipped to the lower 48 US states. I accept USPS money orders and cash. Sorry, no PayPal or international sales.
Pic shows coated intake on left, if it's not obvious in the image.
11.1.2017 - MOPARTS SPECIAL! EITHER INTAKE FOR $200 SHIPPED, PER ABOVE.
Edited by BradH (11/21/17 11:06 PM)
#2392724 - 10/24/17 11:51 PM Indy 440-1 Top End [Re: moparts]
dart69bigblock Offline
Loc: Omaha, NE
**Sold***
Selling a used pair aluminum 440-1 heads that have been ported and have SS valves. They come with 1.6 Jesel shaft rockers, aluminum valve covers and a Indy 4500 flange intake that has been gasket matched. I bought these used a few years back from a member on here and have since changed directions. I do not have flow numbers as he did not have them when I bought them. Asking $3000/obo. Call text or email. 402-650-3101
chrismstucker@gmail.com
I have more pictures I can send or take any if you want to see something specific.
Edited by dart69bigblock (11/19/17 10:40 AM)
#2394066 - 10/27/17 09:33 PM Big Block Exhaust Manifolds [Re: dart69bigblock]
mopars4life Offline
Loc: Virginia
Believe to be from full size or truck. $100 for the pair. moparsforlife@hotmail.com
#2394207 - 10/28/17 11:30 AM indy ez heads -intake [Re: mopars4life]
komninon Offline
Loc: chicago il usa
indy ez heads mw
indy intake mw
holley 850dp with dual line and carter mechanical fuel pump
msd distributor
still on my 68 charger. porter racing heads did all the work
great condition low miles. Going EFI...
located in Chicago come check it out go for a ride. all paperwork from PRH
$2900
#2394339 - 10/28/17 05:41 PM Mr. Gasket 6007, Aluminum 2 Inch 4BBL Carburetor Spacer. [Re: cbusters]
streetkit Offline
Loc: Northern CA
Mr. Gasket 6007, Aluminum 2 Inch 4BBL Carburetor Spacer. Used but in excellent condition. Will come with 2 new open plenum 4bbl gaskets.
$25 shipped to your door anywhere in the USA.
glolas@comcast.net
Edited by streetkit (10/28/17 05:44 PM)
1973 Dodge D100
#2394584 - 10/29/17 12:40 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Original 1970 440 SIX PACK 4-speed dual point distributor, The shaft is tight but spins freely, I have tested the vacuum advance, it pulls, I have installed a new lead wire, part #3438314, date code 44-9 $750.00 (708)288-2879 Scott
#2394589 - 10/29/17 12:48 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One pair of 1973 400 and 440HP exhaust manifolds in nice used condition RH casting #3751074 date code A153, LH casting #3751068, date code 12,21,72, both manifolds are in nice used condition $350.00 for the pair (708)288-2879 Scott
#2394592 - 10/29/17 12:55 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1971 440HP 4-speed Carter AVS carb, date code G0, nice used original carb $300.00 (708)288-2879 Scott
#2394595 - 10/29/17 01:03 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1969 440 HP automatic carter AVS carb #4618, date code L8, excellent core to restore $300.00 (708)288-2879 Scott
#2394598 - 10/29/17 01:08 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Vintage Donovan gear drive for big block Mopar and 426 HEMI, I do not have the cam gear or the crank gear, what you see in the pictures is what I have $275.00 (708)288-2879 Scott
#2394752 - 10/29/17 10:59 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
bbtrux Offline
Loc: ohio
78 400 engine , turns easily by hand -$400.00 OBO ; 400 block with caps and crank - $300.00 OBO ; cast RB intakes , some square bore , some spread bore , $25.00 each OBO . Call or text 419-512-1612 , or e-mail rocknwrench@gmail.com. Thank you.
Edited by bbtrux (11/21/17 08:47 PM)
#2394904 - 10/29/17 02:02 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: bbtrux]
dsd70bee Offline
Loc: oak park, il.
1970 and 1971 440 SIX PACK base plate and lid $550.00 (708)288-2879 Scott
#2394916 - 10/29/17 02:22 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: dsd70bee]
chrisnben Offline
Loc: Madison, Wisconsin
Brand new TTI brand 383/440 headers for B or E body Mopars. Polished Ceramic coated outside & thermal barrier on inside. Steps from 2" to 2-1/8" primaries & 3-1/2" collectors- part #440-218. Recommended for 500+ HP engines. (retail is $950) $750 pair, save $200!.
message me here, thanks.
Edited by chrisnben (10/29/17 08:25 PM)
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
#2394926 - 10/29/17 02:36 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
chrisnben Offline
1968- 383 engine with knife-edged forged crank. comes with 30 over Speedpro pistons and new ring set. Block is standard bore now & disassembled(I can have it bored for cost). Very clean, stored correctly. Also has 906 heads, timing cover but no intake. $400 total for quick sale.
Can ship via Fastenal most anywhere for $200. I charge $100 for palletizing/dropoff. Paypal accepted with 3% added.
Message me here, thanks.
Edited by chrisnben (11/07/17 09:36 PM)
#2394991 - 10/29/17 05:09 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1969, 1970 and 1971 426 HEMI oval air filter NOS in the box, this is the real deal, never installed on a car $650.00 (708)288-2879 Scott
#2395051 - 10/29/17 07:32 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Weiand tunnel ram type 440 SIX PACK intake manifold, excellent used condition $1350.00 (708)288-2879 Scott
#2395059 - 10/29/17 07:46 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One set of original Max Wedge rocker arms and stands $300.00 for everything (708)288-2879 Scott
#2395643 - 10/30/17 06:57 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1970 440 HP single point distributor, part #3438222, date code 44 9, this distributor is in excellent used condition, I have tested the vacuum advance, it pulls, the lead wire is in good condition $375.00 (708)288-2879 Scott
#2395853 - 10/31/17 12:18 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
Moparguy383 Offline
Loc: Cumberland, MD
Pair of nice older headers for a big block, they have a few dings and clearance dents but otherwise very nice. They are not rusted out, thin junk. These are well made headers, 2 inch primaries, 3.5 inch collectors. I bought these off of a buddy in 1991 and they have been stored in my climate controlled shop ever since. I had them sand blasted and coated with Eastwood's silver high temperature coating. They would be on my car now, but I found out they will not work with power steering. $275 plus shipping. I will take Paypal if it is sent as a gift.
Email me moparguy383@hotmail.com for more pictures or information.
24,969 Registered Members
185,453 Topics
Feets eat your heart out
by CokeBottleKid
11/25/17 04:46 AM
70 Cuda Grille and Grille Molding Options
by rss
11/25/17 02:19 AM
Garage door guys. Help leveling door.
by MoparPosterChild
11/25/17 12:47 AM
Well, I did it. '17 Challenger.
by 68SportFury
11/24/17 10:23 PM
