Page 1 of 4 1 2 3 4 >
#2379624 - 09/30/17 09:50 PM For Sale - Small Block Engine - 4th Quarter
moparts Offline
#2380093 - 10/01/17 04:19 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
dart4forte Offline
Loc: Mesa, Arizona
Small block engine to transmission brackets. Creats a more solid engine/transmission assembly.
$50 plus shipping
Mesa, AZ
Edited by dart4forte (10/01/17 04:19 PM)
#2380251 - 10/01/17 08:06 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner hose. $20
Original Cal Custom 14" finned aluminum air cleaner with filter. $100
Original Cal Custom 9" finned air cleaner top and base. No filter. $75
1970 Style single nipple oil breather with hose. $35
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
AC alternator bracket from a mid 70s 360. $15
Good used intake to water pump crossover hose from a mid 70s 360 with AC. $5
Small block passenger side biscuit motor mount bracket. $30
137 New Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
New Cloyes C-3028 small block Mopar timing chain. $25
Carb. throttle linkage stud. $10
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Pair of factory small block valve covers. Not sure of year. Nice shape. $75
1971 318 intake & 2 barrel carb. $100
Email: gt340 at yahoo.com
#2381018 - 10/02/17 10:56 PM Small Block Fluidampr - New [Re: Rocket]
Rocket Offline
Loc: CT
I have a new small block fluidampr that I purchased but will not be using. I purchased this a number of years ago and has been boxed and on the shelf.
Price is $375 shipped to the lower 48 states.
Contact procketrichard@hotmail.com for more information
#2381020 - 10/02/17 10:57 PM 360 4 Bold Main Caps - New [Re: Rocket]
Rocket Offline
Loc: CT
I have a new 4 bolt main cap kit Mopar Performance part # P5249675 for 360 engines. These are the same main caps used for Mopar R series race blocks. They are ductile iron. They are a superior material to stock caps and use more material for strength. You can use these on a stock 360 block without using the outer bolt holes. Some builders cut off the outer 2 bolts for ease of installation. A great upgrade for stroker engine builds. Kit comes with 4 caps and bolts.
I have attached an example of what they look like when installed with the outer 2 bolts machined off. I used a similar 340 main kit (middle 3 caps only and sI did not have the first cap) on a 340 stroker I built.
This 360 main cap kit lists for $180 on summit. I will sell it for $140 shipped in the lower 48 states.
Contact me at procketrichard@hotmail.com with questions
#2383065 - 10/06/17 04:06 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
whip65lash Offline
Loc: amherst, ohio
Rebuilt 360 -1972 block..030 over,10/10 mains,internal balance crank,new pistons,cam,lifters,timing chain,intake,water pump,fuel pump,6qt pan,windgage tray,arp bolts,dampner.Heads-New springs,retainers locks,stainless valves,mild port work,cam degreeded in,professionally assembled.Comp cam 510 at.50 nu. 20-225-4 Mopar intake pt.p4452883 Also have rebuilt 727 small block trans withturbo action conv 2500 stall.Like to sell as a package deal.Was going to put in my 34 Dodge truck and decided to go with old school 392 hemi.$3.800 for everything.Trades considered B.B Race parts, 440-654-8431 Ask for Rich.Thanks for ad Moparts.
Edited by whip65lash (10/06/17 05:00 PM)
#2383086 - 10/06/17 05:18 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
EV2Bird Offline
On Vacation
Loc: Kansas Roads Between 0 and 140...
SOLD... THANKS MOPARTS
NEW Mopar Performance .557 Solid Camshaft 273 318 340 360
CAM ONLY!
Still has there protective coating and yellow paper wralower 48 usa only.
PM me here. THANKS!
I purchased it approx 7 months ago, used a comp cam I had and needed the lifters from the .557 kit.
#2383138 - 10/06/17 07:43 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
EV2Bird Offline
On Vacation
Comp Cams 273 318 340 360
Comp Cams 305AH-8 Camshaft
Comp Cams 822-16 Lifters
$250 Shipped Lower 48 only
PM me here.
Thanks.
#2383140 - 10/06/17 07:46 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
EV2Bird Offline
On Vacation
New Mopar Performance Cam Kit P4120231 284/284 lift 484/484 Dur 239@50 108 68 Overlap
Cam and Lifters $140 shipped usa lower 48 only
PM me here. Thanks.
#2383217 - 10/06/17 09:47 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
J. Hammer Offline
Loc: Memphis,TN
Mopar M-1 dual plane intake manifold,fits magnum heads. Excellent condition. 180.00 SOLD
Edelbrock 7576 RPM airgap dual plane intake manifold. Excellent condition 200.00 SOLD
Mopar M1 single plane magnum intake new. 275.00 with free ground shipping
PM me with any questions
Edited by J. Hammer (10/30/17 03:04 AM)
#2384657 - 10/09/17 05:32 PM Two R1 blocks for sale [Re: moparts]
MGC340 Offline
Loc: Sioux Falls, SD
2 Mopar race R1 small blocks
R1 low deck small block. SOLD!!!!!!!!!!!!!!!
9.095 deck
4.085 bore
4-bolt mains
48' lifter
Bushed lifters
50 mm cam bearings
Has extra head bolts
$1700 with 2 new 50mm cam cores.
R1 tall deck block
Uncut tall deck
4.030 bore
4 bolt mains
48' lifter bore
Extra head bolts have been milled off.
Bushed lifters
New cam bearings in box
$2800
Please pm me for details, thanks Mark
Edited by MGC340 (10/29/17 11:17 PM)
#2386442 - 10/12/17 05:11 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
++MAX WEDGE++ Offline
Loc: Near Columbus, Ohio
340 short block engine, All new parts, forged pistons, steel crank (standard) balanced assembly. 70 block 2300.00
Edited by ++MAX WEDGE++ (10/12/17 05:17 PM)
#2387746 - 10/15/17 01:00 PM 360 Crankshaft - $25 [Re: moparts]
MuuMuu101 Online   laugh2
I got lucky at Woodward!
Loc: Covina, Ca
I have a spare 360 crankshaft from my engine prior to stroking it. It's just been sitting in my garage and I'll probably never use it. It may need to be polished. $25 cash takes it!
PM me if interested. Will not ship. Located in SoCal. Can deliver to Fall Fling.
68 Dart GT Project Thread: Linky!
#2388973 - 10/17/17 07:12 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
mopars4ever Offline
Loc: md
A pair of mopar exhaust flange gaskets part number 3818115 $12.00 Shipped US PM me.
#2389389 - 10/18/17 02:36 PM Re: For Sale - Small Block Mallory Distrutor [Re: moparts]
DusTed74 Offline
Loc: WI. U.S.A.
I bought this distributor new 3 years ago. It works flawless. It comes with a Mallory circuit guard, and a spare rotor. $250. includes shipping to the lower 48 states.
You may contact me here. Thanks.......Ted
#2390036 - 10/19/17 07:50 PM 2531915 340 4bbl intake OEM [Re: DusTed74]
Rapid340 Offline
Loc: oberlin, Ohio
OEM 1968 or 1969 340 intake manifold
casting 2531915
close up of date code and casting # shown
good condition, it had been hot-tanked and painted years ago and never used. All machined surfaces and threads look good, oil shield is there.
$145 plus shipping
thanks
jeffpatterson@copper.net
Jeff Patterson 71 Duster 340, Factory Appearing
11.000 122.3 MPH on 6 in. M&H Volkswagen tires.
Intelligence? http://www.youtube.com/watch?v=cpM76ymlnbA
#2391263 - 10/22/17 01:02 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: J. Hammer]
J. Hammer Offline
Loc: Memphis,TN
Bullet solid cam/ lifters. This is for a street/strip turbo sb mopar. Very low run time. 264@.020 232@.050 .470 with 1.5 rockers 114lsa. 180.00 contact me with any questions.
Edited by J. Hammer (11/17/17 11:39 PM)
#2391849 - 10/23/17 01:19 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
torredcuda Offline
Loc: NH
`71 340 short block, threw rod and needs 1 sleeve, at least one rod, crank may be salvageable but has damage, $350 or B.O. , pick up in Epping NH
https://www.facebook.com/pages/Northeast-Mighty-Mopar-Club/365435766974452?ref=aymt_homepage_panel
`72 Barracuda 340/4spd
`70 road runner 383/auto
`70 Duster 360/auto drag car
`71 Duster project
`76 W100 clubcab project
`83 W350 plow truck
#2393928 - 10/27/17 05:03 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
kingvern Offline
Loc: Michigan
408 stroker less than 100 miles. 552 hp 519 torque. I have all paper work. All parts are forged. Heads and intake were done Hughes engines w 2.08 intake and 1.60 exhaust valves and ther big mouth porting. Many high dollar parts. Can hear it run. Does not come with electric water pump or fitech fuel injection set up. Or alternator and pulleys. I have double in this engine. Any questions please message me. Pics on request. 8000.00
Edited by kingvern (10/27/17 05:08 PM)
#2394060 - 10/27/17 09:20 PM 4 Blade fans [Re: kingvern]
mopars4life Offline
Loc: Virginia
4 blade fans - have 2
$20 a piece
moparsforlife@hotmail.com
25,000 Registered Members
185,239 Topics
Just to piss off some people!
by instigator
12/12/17 11:19 PM
62 Sport Fury
by 62maxwgn
12/12/17 11:04 PM
Restoring finish on carburetor
by 440mopar
12/12/17 10:34 PM
Clutch pedal spring removal with diaphragm clutches?
by PAULS_340
12/12/17 10:32 PM
