Re: ANYONE USING PHOENIX 29.5 X 11.5 X 15 PH362 SLICKS?
[Re: moparjohn]
#2379754
10/01/17 07:38 AM
10/01/17 07:38 AM
Posts: 2,915 A shed in England
Tig
A shed in England
Not much help but we tried the 29.5 x 10.5 Phoenix after running the same size M/T. The Phoenix was a lot taller than the sidewall designation, it rubbed on the body work when the tyre grew at speed. IIRC it was acting more like a 30.5 tyre, car ran well with them though for the few passes we had them on till we realised what was happening. A friend bought them to try on his 10 sec truck, he was impressed also. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: moparjohn]
#2380220
10/01/17 09:40 PM
10/01/17 09:40 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I ran the Phoenix 29.5x10.5 on my 9 second Dart and loved them, they also were bigger than advertised.
[Re: moparjohn]
#2380297
10/01/17 11:19 PM
10/01/17 11:19 PM
ProSport
Akron, Ohio
I ran mine w/o tubes. I had a tube tear a few years ago right after a run and kinda scared me away from using them.
[Re: moparjohn]
#2380577
10/02/17 01:53 PM
10/02/17 01:53 PM
Posts: 625 Indianapolis In. usa
Quickrunner
I ran them tubeless for years on my roadrunner. Liked them better due to more tread per section width than similar MT's
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: moparjohn]
#2381359
10/03/17 06:57 PM
10/03/17 06:57 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I never used that size,but we always used Phoenix after Firestone quit making them. We always had very good hook with Phoenix,and we used tubes.And Phoenix tends to run a bit large on size,compared to other brands.
[Re: moparjohn]
#2381520
10/04/17 12:03 AM
10/04/17 12:03 AM
Posts: 89 Woodbury, CT.
mcduff
Woodbury, CT.
I have used them for years with good results. I have a few used sets that you can have for trial fitting...send a UPS pick up tag to Connecticut and they are yours.
Brett Miller 447 W9
[Re: mcduff]
#2381589
10/04/17 02:16 AM
10/04/17 02:16 AM
Posts: 69 norcal
JLaSalle
norcal
You'll get more runs out of them too because the sidewalls are stiffer than the mickeys.I saw .02-.03 reduction in reaction time when I switched to pheonix from the mickeys,due to the sidewall,I assume.
1967 Coronet R/T 9.83 134mph. 470 cid st.6 heads 10x pro et track champion
