Page 1 of 2 1 2 >
#2379608 - 09/30/17 09:44 PM Mopar Differential For Sale - 4th Quarter
moparts Offline
#2383150 - 10/06/17 07:52 PM 1965-67 B-Body 8.75 rear [Re: moparts]
sawdust Offline
Loc: Green Lane, PA
Complete 8 3/4 rear less brakes for 1965, 1966, and 1967 B-Body.
489 center section with 4.30 gears, NOS clutch type Posi. High strength axles from Doctor Diff. 7290 U-bolt yoke.
Everything is new with less than 100 miles of driving and 3 light passes. Selling because switched to Dana 60. $1100 picked up.
info@kriebeldesigns.com or pm me here.
Edited by sawdust (11/10/17 10:18 PM)
1967 RO23 4 speed
1967 RO23 4 speed "Poison Ivy"
1967 RO23 4 speed "A-Town Hustler"
1967 NSS Belvedere Post 4 speed
1970 Triple red hemi cuda
2016 PCP Hellcat M6
#2389605 - 10/18/17 09:26 PM Re: Mopar Differential For Sale - 4th Quarter [Re: moparts]
rumundo Offline
Loc: Mississippi
I have a 489 case 3:55 3rd member that I'd like to sell. All parts are brand new and purchased from Doctor Diff about 4 months ago. I am unable to get the correct gear contact pattern, so I gave up and put my 3:23 back in my car. It has new pinion and carrier bearings too.
I have the dial indicator, setup bearings, and a home made tool to adjust the carrier bearing preload and extra shims and new crush sleeve.
There is currently a crush sleeve eliminator installed and you could probably add/remove shims to the pinion and get the correct wear pattern if you know what you are doing (I obviously don't).
I paid around 800 for the parts and already had the carrier. Make me an offer so I can quit looking at it because it pisses me off every time I see it.
[img]https://drive.google.com/open?id=0B9h_hTKK80XMVnlOQUxjcndfM0U[/img]
#2394294 - 10/28/17 03:27 PM Dana 60 4.10 gears [Re: moparts]
70HemiGTX Offline
Loc: PA
For Sale: Dana 60 4.10 gears. I think they cam out of a truck rear. Same difference. Do not know the milage on them. Teeth look nice. $150 shipped to the lower 48 or pick them up. Email me at: trdeppen"at"comcast.net or 7one7-57one-five180.
Thanks for the ad!
Edited by 70HemiGTX (10/29/17 07:39 PM)
#2394571 - 10/29/17 12:09 AM Re: Mopar Differential For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1970 B-body 4.10 Dana 60, fresh setup, new front seal $2500.00 (708)288-2879 Scott
#2394740 - 10/29/17 10:49 AM Re: Mopar Differential For Sale - 4th Quarter [Re: moparts]
bbtrux Online   content
Loc: ohio
489 sure grip center with 5.37 gears - $400.00 OBO ; (2) 8 3/4 housings and axles , both have welded on housing braces , came from mid 60's imperials, so have 5x5.5 bolt pattern , good housings to cut down for a-body, pro street, etc. - $100.00 each OBO. Call or text 419-512-1612 , or e-mail rocknwrench@gmail.com. Thank you.
#2394918 - 10/29/17 02:24 PM Re: Mopar Differential For Sale - 4th Quarter [Re: moparts]
chrisnben Offline
Loc: Madison, Wisconsin
Mopar 8-3/4 Axles- Have one pair of each; E-body and 68-70 B-body. $40/pair
message me here, thanks.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
#2395320 - 10/30/17 11:15 AM Re: Mopar Differential For Sale - 4th Quarter [Re: chrisnben]
fbs63 Offline
Loc: NW Indiana
Dana 60 rear for sale. 53 1/2" Axel flange to flange. 36 1/2" spring perch centers. Has new Trac Lok,4.10 ring and pinion,1350 joint yoke,35 spline Strange S/T series axles,11" drum brakes.Out of 63 Dodge B body with springs moved in. Very little use. $1200.00 Can arrange reasonable shipping or meet buyer within 300 miles. Located in North West Indiana. PM here,call or text 7zero8-two07-5374 SOLD
Edited by fbs63 (11/01/17 09:05 PM)
#2395468 - 10/30/17 02:24 PM Re: Mopar Differential For Sale - 4th Quarter [Re: fbs63]
rickseeman Offline
Loc: Little Rock, Arkansas
NOS 2.76 gears for 8-3/4 $150 prefer Paypal Rick 501-519-7425
2011 Drag Pak Challenger
#2395865 - 10/31/17 12:41 AM Re: Mopar Differential For Sale - 4th Quarter [Re: bbtrux]
dsd70bee Offline
Loc: oak park, il.
1970 and 1971 Cuda Dana 60 drive shaft $1000.00 (708)288-2879 Scott
#2396789 - 11/01/17 03:47 PM DANA 60 [Re: dsd70bee]
cl440 Offline
Loc: S.E. Michigan
Dana 60 complete backing plate to backing plate #603222 2
Pulled from a 71 Charger. Has 4.10 Dana gear. Looks good and turns free/smooth.
$2,200.00 OBO You pick it up (No shipping)
chucklewis440@gmail.com
#2398249 - 11/03/17 11:59 PM Re: Mopar Differential For Sale - 4th Quarter [Re: moparts]
J. Hammer Offline
Loc: Memphis,TN
A body 8 3/4 rear end,3.23 open carrier,small bolt pattern axles, backing plates. 600.00 obo
#2401480 - 11/10/17 02:23 PM Re: Mopar Differential For Sale - 4th Quarter [Re: fbs63]
moparjohn Offline
Loc: N.W. INDIANA
C body 8 3/4 bare housings for sale $95.00 each.
Price does not include shipping.
Contact me at moparjohn@frontier.com
Thanks! John
#2401612 - 11/10/17 07:20 PM Re: Set of Moroso #46200 3" screw in axle studs [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
SOLD!
I have for sale a used set of 10 Moroso #46200 screw in axle studs. They are ½”-20 x 3”. They are in perfect condition with no stripped or damaged threads at all. I would like to get $20 for the set plus the shipping of $7.15 via the USPS small flat rate box.
https://www.summitracing.com/parts/mor-46200/overview/
Edison, NJ
rider1454 at aol.com
Edited by PHYSIXX (11/12/17 02:40 PM)
#2401613 - 11/10/17 07:21 PM Re: Set of Strange Engineering 2 1/2" screw in axle studs [Re: PHYSIXX]
PHYSIXX Offline
I have for sale a set of 10 axle studs that came with a Strange Engineering front disk brake kit. These studs are P/N A1028 and are ½”-20 x 2 ½”. I went with the 3” studs so these are for sale. No washers though. I needed them for the 3” studs.
https://www.summitracing.com/parts/str-a1028
I would like to get $10 for the set of 10 studs plus the shipping of $7.15 via the USPS small flat rate box.
Edison, NJ
#2402070 - 11/11/17 04:33 PM NOS Mopar 2070845 8 3/4 clutch kit [Re: PHYSIXX]
Rapid340 Offline
Loc: oberlin, Ohio
NOS Mopar 2070845 8 3/4 power lok clutch kit
Made in USA
This is your best shot at getting the right materials, hardness and tension for OEM performance and life.
Date on box is 12/81
***SOLD
jeffpatterson@copper.net
Edited by Rapid340 (12/28/17 10:40 AM)
Jeff Patterson 71 Duster 340, Factory Appearing
11.000 122.3 MPH on 6 in. M&H Volkswagen tires.
Intelligence? http://www.youtube.com/watch?v=cpM76ymlnbA
#2402744 - 11/12/17 07:03 PM Re: Mopar Differential For Sale - 4th Quarter [Re: moparts]
killersix Offline
Loc: West Michigan, Usa.
Complete A-body small bolt pattern 8 3/4 rear end assy. Complete flared drum to flared drum. 741 center section, 3.23 open small yoke. Just pulled complete assy. Has not been cleaned or opened up at this time. Asking $550.00 complete. Locted in southwest Michigan area. Cannot ship. Call or text 269-377-5942 or e-mail jburza@gobles.org
#2408361 - 11/24/17 03:55 PM Re: Mopar Differential For Sale - 4th Quarter [Re: moparts]
killersix Offline
Nice pair of 8 3/4 - Dana 60 lower shock plates. Good studs and threads. $75.00 a pair shipped in the lower 48 states. jburza@gobles.org
#2408470 - 11/24/17 09:15 PM Re: Mopar Differential For Sale - 4th Quarter [Re: killersix]
jonesboys Offline
Loc: waynesboro va
8.75 rear narrowed for an a body minitub setup new green bearings on stock axles that have been cut to size and resplined 410 suregrip 489 case mopar gears can supply backing plates drums brakes 1200.00 540-649-5813
#2410294 - 11/28/17 05:41 PM 8-3/4 3.23 SUREGRIP CHUNK [Re: moparts]
gdmusclecar Online   content
Loc: ORANGE PARK,FL
8-3/4 3.23 SUREGRIP 489 CASE,CLEAN UNIT NO DAMAGE OR REPAIRS. $750
*WE CAN SHIP*
ORANGE PARK,FL.
E-MAIL: GDMUSCLECARPARTS@YAHOO.COM
SHOP# 904-272-1803
CELL# 904-589-4645
Page 1 of 2 1 2 >
25,075 Registered Members
185,663 Topics
Can't get this plastic bag to burn with a propane torch
by RM21N0A
01/20/18 03:37 PM
1973 Charger SE
by Neil
01/20/18 03:13 PM
Help - Need advice on an apartment issue
by Ramrod39
01/20/18 02:58 PM
HaHaHa - Great One!
by Sunroofcuda
01/20/18 02:32 PM
