Page 1 of 4 1 2 3 4 >
#2379606 - 09/30/17 09:44 PM Mopar Transmission For Sale - 4th Quarter
moparts Offline
#2379877 - 10/01/17 10:35 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
moparjoe360.4 Offline
Loc: Ohio
64-65 Hemi STEEL bellhousing, casting #2463236, all treads look good. I'm listing for my dad, pm me here for his contact info or with questions. Asking $900 OBO but he's negotiable.
#2380234 - 10/01/17 07:51 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
JamiePasson Offline
Loc: Sugarloaf, PA. USA
PASSON PERFORMANCE INTRODUCES 18 SPLINE HEMI 4 SPEED OVERDRIVE A-833 TRANSMISSIONS!
AVAILABLE AS A COMPLETE BOLT IN UNIT OR JUST A GEARSET CONVERSION KIT.
INTRODUCING THE PASSON PERFORMANCE HEMI 4 SPEED OVERDRIVE
Tire Size RPM Speed Rear End Ratio
28 " 3248 65 m.p.h. 4.10 : 1 1:1 Gearset
28 " 2580 65 m.p.h. 4.10 : 1 Passon Performance Overdrive .80:1
21% DROP IN CRUISING RPM!!!
Stock--------------- Overdrive
1st 2.65 : 1---------- 2.66 : 1
2nd 1.93 : 1----------1.59 : 1
3rd 1.39 : 1---------- 1.00 : 1
4th 1.00 : 1--------- .80 : 1
Stock Rear Ratio 1:1 4th--------- Adjusted Rear Ratio with Overdrive
3.23:1 ------------------------- 2.58:1
3.54:1 ------------------------- 2.83:1
3.55:1 ------------------------- 2.84:1
3.91:1 ------------------------- 3.13:1
4.10:1 ------------------------- 3.28:1
4.56:1 ------------------------- 3.65:1
Shortcomings of the Original Chrysler Overdrive:
1. Inherently weak due to the undercut mainshaft in the 3rd gear and 3-4 synchronizer area.
2. Limited to a 23 spline input shaft which is another weak spot in a high horsepower car.
3. Floating countershaft in case.
4. Lack of evenly spread gear ratios.
5. Lack of a well matched 1st gear ratio.
Benefits of the Passon Performance Overdrive:
1. Uses a stock 1:1 large journal mainshaft for increased strength.
2. The strength of an 18 spline input shaft.
3. An excellent gear spread to limit excessive RPM drop between shifts.
4. Can be swapped into your factory 4 speed case with just a gasket set.
5. THE ONLY OVERDRIVE on the market that require NO modifications to the vehicle! If your 4 speed fits now (which it does), this will fit!
6. ABSOLUTELY NO:
-CUTTING OR MODIFYING YOUR FLOOR
-CHANGING YOUR DRIVESHAFT
-MODIFYING OR USING SPECIAL BELLHOUSINGS
-INCORRECT DRIVELINE ANGLES
-INCORRECT SHIFTER LOCATION
-HEADACHES or AGGRAVATION
-SPENDING $4500.00!!! BECAUSE IT FITS RIGHT INTO YOUR CASE!!!!
7. Stronger than a factory Hemi 4 Speed due to improved materials and increased root diameter of all gears.
Available as a gearset ($1995.00) or an entire ready to install unit!!! ($3195.00)
NEW 18 SPLINE INPUT SHAFTS, 2.65:1 RATIO
NEW 18 SPLINE 3RD GEARS, 2.65:1 RATIO
They feature back tapered synchronizer teeth, which builds considerable life into the gear. They are made of a 9310 forging which is much stronger than the OEM 8620 material. These are an exact bolt in with no modification necessary.
Our gears are 100% made in the USA.
DON'T SETTLE FOR KOREAN GEARS AND SYNCHRONIZER ASSEMBLIES IN YOUR AMERICAN MOPAR MUSCLECAR!!!
ACCEPT NO SUBSTITUTES! OUR GEARS ARE THE ONLY GEARS MADE IN THE USA!!!!!! OUR QUALITY GEARS HAVE BEEN PROVING THEMSELVES FOR OVER FOUR YEARS NOW.
NEW 9310 2.65:1 HEMI CLUSTER GEARS COMING SOON!!!!!
COMPLETE ALUMINUM A-833 FOUR SPEED CASES.
All Configurations!
A-833 4 speed transmissions, parts and service. Full rebuild service available for ’64-’74 A,B,C,E,F Bodies. I offer 23 spline and 18 spline parts and service and overdrive parts and service as well. We have or can get any A-833 4 speed transmission parts that you may need. Custom transmission configurations built to fit your application. Race or Restoration. Many NOS, new and good used parts available. All cast iron units finished in show quality cast iron finish. We will respond to your messages ASAP .
REBUILT FACTORY HURST SHIFTERS IN STOCK. FROM $149.00
NEW HURST SHIFTERS IN STOCK $289.00
ALL NEW HURST SHIFTER SERVICE PARTS FROM 6.00
SHIFTER LINKAGE RODS FROM $119.00
Z BAR SERVICE KITS FROM $59.00
STEEL REPRODUCTION FLOOR HUMPS FROM $159.00
PEDAL ASSEMBLIES AND PARTS ALL BODYS INQUIRE
STOCK RECONDITIONED FLYWHEELS FROM $199.00
MCLEOD CLUTCH PACKAGES FROM $359.00
RECONDITIONED FACTORY BELLHOUSINGS FROM $259.00
BIG BLOCK STEEL INSPECTION COVERS 10.5” / 11” $89.00
SMALL BLOCK STEEL INSPECTION COVERS 10.5” $79.00
SMALL BLOCK STARTER SHIELDS $39.00
BILLET ALUMINUM HURST SHIFTER MOUNT PADS
WITH THE 3 CORRECT ALLEN HEAD BOLTS $59.00
RESTORED SHIFTER HANDLES FROM $249.00
REPRODUCTION PISTOL GRIP HANDLES FROM $204.00
’67 – 76 A BODY BALLSTUD FRAME BRACKETS $35.00
’66 – ’74 B / E BODY BALLSTUD FRAME BRACKETS $35.00
REPRODUCTION AND NOS SHIFTER BOOTS FROM $49.00
DASH REVERSE INDICATORS $89.00
4 SPD REVERSE LIGHT WIRE HARNESS ’67 UP A BODY $29.00
4 SPD REVERSE LIGHT WIRE HARNESS ’66 UP B / E $36.00
REPRODUCTION WOODGRAIN BALLS $40.00
REBUILT A-833 4 SPEEDS 23 SPLINE FROM $895.00
18 SPLINE FROM $2095.00
TOO MANY PARTS TO LIST!! CALL OR E-MAIL FOR MORE INFO!!
PRODUCTION HAS FINALLY STARTED ON OUR NEW A-855 5 SPEED TRANSMISSION. THE ONLY 5 SPEED TRANSMISSION ON THE MARKET THAT REQUIRES NO CUTTING OF THE VEHICLE. CALL OR EMAIL NOW TO GET ON THE WAITING LIST!!!!
COMPLETE CONVERSION PACKAGES AVAILABLE!
IF YOU DON’T SEE IT, ASK!!!!
WE TAKE VISA, MC AND DISCOVER CARDS FOR YOUR CONVENIENCE
PASSON PERFORMANCE
(570) 401 8949
309 TURKEY PATH
SUGARLOAF, PA 18249
YOUR A-833 SPECIALIST! All we do are A-833 manual transmissions!!!!!! “WE PURCHASE CORES”
www.PASSONPERFORMANCE.COM
OR E-MAIL US AT JAMIE@PASSONPERFORMANCE.COM
Edited by JamiePasson (10/30/17 09:30 AM)
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
#2380255 - 10/01/17 08:09 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
A-body big block 4-speed parts: Included are a 4-speed bell housing #2468372, bell housing inspection cover, big block clutch fork, big block A-body z-bar, new big block A-body z-bar bell housing and frame ball pivots, new ball stud seal, 2 new clutch linkage washers and a new throw-out bearing as shown in the picture. I have had the bell housing, inspection cover and clutch fork media blasted. The bell housing and clutch fork are primed. The inspection cover has been painted gloss black. I have also blasted and primed the z-bar since the photo was taken. $750 for everything. Selling only as a package. I would prefer not to ship but can deliver to the Mopar Nats with a $100 non-refundable deposit. gt340 at yahoo.com
#2380323 - 10/01/17 09:55 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
mrrandyj Offline
Loc: CT
727, 518 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 727, 518, 46RH, and 46RE transmission. The rear servo piston is a 1-piece design that replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. The piston is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. It comes in a kit with a heavy duty stainless steel return spring that will eliminate 1-2 shift overlap, a new seal, and a .075 extra thick retainer made from stainless steel that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This kit fits 67 and newer 727, 518, 618, 46RH, and 46RE transmissions. I also have a kit that fits the early 62-66 727’s. The price for either rear kit is $75.00.
MADE IN THE USA!!!
There is a $8.00 shipping charge per order. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
#2380325 - 10/01/17 09:57 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE DUAL RING FRONT BILLET SERVO KIT
Dual ring billet front servo kits for 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. The front servo is responsible for applying the front band during the 1-2 shift. This servo is based off of the highly desired 71 and earlier Chrysler “small pin” servo that is ideal for use in performance transmissions, only this one is much better. The piston and cover are CNC machined out of solid 6061 billet aluminum and the shaft is CNC machined from prehardened 4140 steel. There are 2 return springs custom made out of stainless steel that will help eliminate the 2-3 shift overlap that these transmissions are known for. There is a custom made metal gapless sealing ring that seals the cover to the case, and also a o-ring in the cover that seals it to the shaft. The o-ring and the gapless ring work together to eliminate internal leakage and allows more oil get to 3rd gear where it is needed most. The piston has 4 total sealing rings, doubling the sealing capacity of the original Chrysler servos. This is a ready to install kit, all the sealing rings and springs are included. The price for this kit is $125.00 plus $8.00 for shipping.
100% MADE IN THE USA
If you have any questions or to place an order my email address is mrrandyj@aol.com
#2380326 - 10/01/17 09:59 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
904 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 1967 and newer 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE Dodge Plymouth Chrysler Jeep or AMC transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1 piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the piston, a heavy duty return spring that will help eliminate the 1-2 shift overlap, a new seal, and a .075” extra thick stainless steel retainer that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This is a complete ready to install kit, no extra parts are needed and it is 100% Made in the USA. The price for this kit is $75.00. There is also a $8.00 per order shipping charge.
#2380329 - 10/01/17 10:02 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
BILLET DUAL RING ACCUMULATORS
These will fit just about any torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RE, and 48RE, almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These are a great upgrade for all the 727s and 904s and are also perfect for replacing the plastic accumulator that Chrysler switched to in the late 80s. The plastic accumulators are known for cracking and causing problems in performance transmissions. I have done these 2 different ways: First is an exact stock replacement, this one will accept all the stock springs whether they go between the case and the piston or the piston and the valve body. These are perfect for the turbo diesel guys that have tighter aftermarket torque converters, or for the person doing a stock type rebuild on a gas transmission. Second is with a built in blocker rod that will stop the accumulator from moving in the bore and firm up shifts. No need to cut down round stock and make a blocker rod anymore, I did it for you. Comes with all 4 sealing rings. The price on these are $45.00 each. There is also a $8.00 shipping and handling charge per order.
These are 100% Made in the USA. If you have any questions or want to place an order email mrrandyj@aol.com Thanks for looking!!!
#2380331 - 10/01/17 10:07 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE FRONT BAND STRUTS AND BILLET BAND ANCHORS
Heavy duty, double thick, billet steel front band strut and billet front band anchor for a Dodge, Plymouth, Chrysler, or AMC 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. This fits from the 1962 727 transmission, all the way up through the 2007 ½ Cummins Turbo Diesel 48RE, and everything in between. The OEM Chrysler front band struts are prone to bending, and the OEM band anchors are known for breaking in high performance and heavy duty applications. The band strut is CNC machined from 1/4” thick steel, which is twice as thick as the factory strut and it is black oxide coated for corrosion protection. The band anchor is also CNC machined from billet steel. Both are made in the USA. The price is $25.00 each, and includes shipping anywhere in the USA.
Email mrrandyj@aol.com
#2380334 - 10/01/17 10:14 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
47RH 47RE and 48RE Billet Rear Servo Kit
High performance, low/reverse billet rear servo kit for a 1994-2007 47RH, 47RE, and 48RE Dodge Cummins Turbo Diesel and SRT10 Ram truck automatic transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the aftermarket shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1-piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the billet aluminum piston, a heavy duty stainless steel return spring that will eliminate the manual 1-2 shift overlap, a new seal, and a extra thick CNC machined billet steel retainer that will not bend around the retaining ring and pop out of the case like the factory retainers do. This is a complete ready to install kit, no extra parts are needed. The price for this kit is $90.00 plus $8.00 for shipping.
#2380352 - 10/01/17 10:49 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
pittsburghracer Offline
Slowride
Loc: PA.
small block 727 transmission for sale. Advertising as a core because it has been sitting inside my house garage for many years and I don't know its history. Located 35 miles NE of Pittsburgh PA. 16229. will not ship but if paid for I will deliver to the Halloween Classic in ohio the end of October. 125.00 PM or jacadamore@gmail.com
1970 Duster
Edelbrock headed 408
6.143@110.89 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
6.001@113.27mph
9.44@138.23
Untitled by John Cadamore, on Flickr
#2380619 - 10/02/17 12:59 PM TCI BBM to powerglide adapter plate [Re: moparts]
johnnyd Offline
Loc: Boston, MA
TCI BBM to powerglide adapter plate. Already trimmed for a dragster and glide. Small crack in between bolt holes- can be TIG'd for easy repair $100
more pics
https://boston.craigslist.org/sob/pts/d/tci-bbm-to-powerglide-adapter/6315013142.html
#2380645 - 10/02/17 01:31 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
64dodge572 Offline
Loc: Ohio
BREWER’S PERFORMANCE, INC, Chrysler 4-speed transmission and parts specialists.
THE MOST COMPREHENSIVE, UP-TO-DATE WEBSITE FOR ALL YOUR 4-SPEED RELATED NEEDS:
www.brewersperformance.com
NEW: Hurst licensed pistol grip shifter, fits 2009-up Dodge Challenger 6 speed, including the new Hellcat. Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. Shifter can be modified for shorter throw, by cutting off the bottom mounting screw/hole. $249.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG-CHALL-6
NEW: Cast iron bearing retainer for 1968-72 18 spline transmissions with 308 front bearing, 4.805" outside diameter, 4.16" bolt circle, replaces cast #C97621/2801892 original retainers, and Mopar Performance P4529697. Gasket and seal included.
http://www.brewersperformance.com/proddetail.asp?prod=BR-621C
NEW: Pistol grip shifter, fits new Dodge Challenger/Charger automatics (and all LX platform cars). Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. $149.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG112
VISIT OUR NEW RESTORATION PARTS SECTION, SAME GREAT SERVICE AS OUR 4-SPEED PARTS:
http://brewersperformance.com/store.asp
WE BUY 4-SPEED TRANMISSIONS & PARTS
NEW LOWER PRICE--Rebuilt OE factory Hurst shifter mechanisms from $149.95
NEW PARTS—We now stock all service parts for Hurst Shifters, see our website:
http://brewersperformance.com/products.asp?cat=132
We are the manufactures of the following parts:
Reproduction 1968-69 Console shift handles for A & B body cars from $240.55
1970 Column/reverse interlock linkage kits for B-body big block and E-body big/small block cars $279.95
Correct 1970 B-body console boot with rectangular opening for pistol grip shifter $89.95
New Big Block bellhousings, heat treated aluminum $329.95, steel dust covers $99.95
67-76 A-body and 66-74 B & E body ballstud frame brackets $39.95 ea
Torque shafts (Z-bars) for all popular A B & E body cars $89.95 ea
A-body big block clutch linkage kits, Hydraulic slave kits also.
Clutch pedal to torque shaft rods A, B & E bodies $59.95
Clutch pedal over center spings $49.95
Clutch pedal over center spring retention pins $19.95
Small block 10.5” bellhousing starter seal $39.95
Big block 10.5” & 11.0” starter shims/seals $12.95
Clutch pedal support firewall stud brackets for 66-74 B & E bodies $19.95 ea
Shifter linkage rod sets for A B & E body cars $124.95-$149.95 set
Transmission linkage operating levers for A B & E bodies $49.95-$56.95 set
Billet steel bearing retainers for 18 spline 4-speeds $129.95
Billet aluminum shifter mounting plates for A, B & E bodies, with all hardware $59.95
Clutch fork pivot brackets $19.95-$29.95
Synchronizer strut keys for 68-9 4-speeds $10.95 ea
Hurst shifter mechanisms to retain your stock Inland shift lever $299.95
Transmission side cover wiring clips, retains backup light wiring $8.95 pair
Conversion torque shaft kits for 10.5” small block bellhousings into 1963-66 A-body cars
We also stock:
New Hurst shifter mechanisms from $219.95
Bearing and seal kits from $99.95
Synchro rings $49.95 set/4
Restored factory Hurst shifter levers from $249.95
New pistol grips from $219.95, lenses, grips & bezels available
Shifter boots from $59.95
Shifter boot bezels from $29.95
Reverse indicator lamps $89.95, wiring harnesses from $29.95
Woodgrain shifter ball $39.95
Rebuilt transmissions from $1099.95
Polyurethane transmission mounts from $59.95
Speedometer cables from $39.95, speedometer pinion gears from $19.95
Torque shaft service kits from $59.95
New flywheels from $199.95, cast crank applications available
Bellhousings for all applications
Centerforce and McLeod clutch packages from $332.07
From one part to complete 4-speed conversion packages, we stock it all! Same day shipping on orders received by 2PM.
We accept Visa/MasterCard/Discover.
BREWER’S PERFORMANCE, INC.
10510 State Route 571
Laura, Ohio 45337
Phone:937-947-4416 or 937-698-4259 9am-5pm Monday-Friday
Fax:937-947-4419 24-7
#2380843 - 10/02/17 07:07 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Goat330 Offline
Loc: Randolph, Ohio--N.E. Ohio
65 big block 727 torqueflite,the one with the rear slip spline.It was rebuilt about 5 years ago and has not been used since then.New solid bands,clutches,all seals and paper are new,also has the later model input splines for the converter.IT wouldn't hurt to freshin the bands and clutchs in some tranny fluid before use.Also has a stock 65 valvebody with the correct rooster comb.I can supply a different VB if that wont work in your car.$700 and local pick-up only.Bill at wmemore@aol.com or PM,Thanks for the free ads Moparts.
#2380844 - 10/02/17 07:08 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Goat330 Offline
I have several slant 6 904s from early 70s darts laying around $20 each.Also have a couple of small block 727s for cores $30 each.Local pick-up only,Bill at wmemore@aol.com or PM,Thanks for the ads Moparts!
#2380845 - 10/02/17 07:13 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Goat330 Offline
Big block pushbutton T-flite with 62-64 trunnion type output shaft. have the parts to put together or a bare case, $50. Local pick-up only,Bill at330-947-3362 or wmemore@aol.com Thanks for the free ads Moparts!
#2380848 - 10/02/17 07:19 PM NEW RAM 10.5 x 23 Spline Clutch [Re: moparts]
GOT6PAK Offline
Loc: Southern California
I bought this clutch for a project and have since sold the project. It is NEW in the box only showing shelf wear. Comes with throw out bearing and alignment tool. Part# is 98776.
Asking SOLD
Located in So. Calif.
PM for any questions.
[img:center][img]https://i.imgur.com/4CIt94e.jpg?1[/img][/img]
Edited by GOT6PAK (10/22/17 01:52 PM)
#2382217 - 10/04/17 11:18 PM Mr. Gasket V gate shifter [Re: GOT6PAK]
Genuinejed Offline
Loc: Spokane,WA
Mr. Gasket V gate inline shifter. Looks to be in good shape. Shifter only, no rods or bracket. Chrome is decent.
Sold! Thanks Moparts
Genuinejed2@aol.com
Edited by Genuinejed (10/22/17 11:43 AM)
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
#2382983 - 10/06/17 01:03 PM 64-65 4 Speed Shifter [Re: Genuinejed]
sixpacksteve Offline
Loc: n.y.
64-65 b body bench seat shifter and handle
real nice shape!
$150+shipping
pm me
the shifter itself can be used for other applications!
SOLD! Thanks Moparts
Edited by sixpacksteve (10/09/17 08:40 AM)
#2382984 - 10/06/17 01:04 PM Re: 64-65 4 Speed Shifter [Re: sixpacksteve]
Loc: n.y.
another pic
#2383334 - 10/07/17 09:08 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
moparlouie Offline
Loc: ct.
Just Rebuilt 23 spline dual mount trans, clear coated for protection. Build date is 3744 (oct 28 1971) Date on pic is not correct, just got back from shop 10/1/17. $1000 plus shipping. lafrancebiglou@aol.com
Edited by moparlouie (10/09/17 11:49 AM)
Have been a member for years!
#2383388 - 10/07/17 11:14 AM AS68RC Transmission [Re: moparts]
RRL0044 Offline
Loc: Eastern PA
I have a transmission from a 2008 Ram 4500 for sale.
The unit is an Aisin AS68RC. It was pulled from a wrecked truck at 160,000 mi. No damage was done to the transmission in the wreck.
I am asking $2600 obo.
Edited by RRL0044 (10/07/17 11:39 AM)
#2383396 - 10/07/17 11:29 AM Dana S111 [Re: moparts]
RRL0044 Offline
Loc: Eastern PA
I have a pair of axles for sale from a 2008 Ram 4500(2WD). The front axle is a 10.827. The rear is a Dana S111. Axles were pulled from a wrecked truck at 160,000 miles. Both axles include brake components.
I am asking:
Front - $1,000 obo
Rear - $2,500 obo
#2383787 - 10/08/17 09:31 AM Hurst Ramrod Shifter [Re: RRL0044]
Loc: n.y.
Still works great!
bracket rods included!
$500.+shipping PM me.
SOLD! THANKS MOPARTS
Edited by sixpacksteve (10/21/17 06:59 PM)
#2383788 - 10/08/17 09:32 AM Re: Hurst Ramrod Shifter [Re: sixpacksteve]
Loc: n.y.
another pic
#2384470 - 10/09/17 12:57 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
938-DAN Offline
Loc: New Jersey
For Sale:
1970 four speed manual transmission. Heavy duty 18 spline from a 1970 model vehicle built at the St. Louis plant "0G126261". Out of long term storage, appears to be in good shape.
For sale locally in New Jersey zip code 08077, can not ship this.
Price is $1,700.00 with correct bell housing cast #2892513 or $1,300.00 for just the transmission.
Pictures too large to post here so please contact me for details.
Please email ASonn86814@aol.com .
Thank you.
Edited by 938-DAN (10/23/17 02:59 PM)
#2384491 - 10/09/17 01:23 PM HUSRT B Body Ramrod Super shifter 4 Speed rods [Re: 938-DAN]
davesmopars Offline
Loc: cheshire, ct
HUSRT B Body Ramrod and Super shifter 4 Speed rods
100.00 plus shipping
PM Me Here
Edited by davesmopars (10/09/17 01:25 PM)
#2384673 - 10/09/17 05:51 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dart4forte Offline
Loc: Mesa, Arizona
64-72 4 speed setup. Had this set aside for a 64 Dart 4 speed convertable but plans change.
Fresh Hurst A body tower with billet bracket
Correct A body flat stick (Non Obtanium)
A body rods and tabs
A body boot and plate
Inner fender reinforcement plate
Bell housing ball
Brewers early A body bell housing ball stud (Adapts torque arm to later bell housings)
$425 plus shipping
Mesa, AZ
#2384688 - 10/09/17 06:18 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dart4forte Offline
Loc: Mesa, Arizona
833 Steel shift forks. 1-2 and 3-4 forks sold as a pair. These parts are used however they are in good shape. Good idea to use these in a drag car.
$60.00 for the pair plus $7.95 shipping
Also I have a pair of bronze forks, good shape $40.00 for the pair plus shipping
Mesa, AZ
#2384761 - 10/09/17 08:29 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: dart4forte]
Azzkikrcuda Offline
Loc: North Dakota
Turbo Action 10" converter for 727 Small and Bigblock. PN# 17805S Medium Stall. Was in a 70 Challenger 496cid with 4.10 gear, around 10,000 street miles on it. Worked good, Stalled around 4000rpm, changed combo. $375+shipping PM me here if interested
Specs and info http://www.turboaction.com/s800.html
The only Carbs I care about are under the hood!
#2384831 - 10/09/17 10:15 PM HURST A Body Ramrod 4 Speed shifter [Re: Azzkikrcuda]
davesmopars Offline
Loc: cheshire, ct
Today is the last day of the Sale. I do not need to see after today
Complete in excellent condition
Just bolt in and go
900.00 plus shipping
only to the end of this week sale. normally 1200.00
I have two of theses decided to sell one of them. the one on the trans is just to show you how it looks mounted
Edited by davesmopars (10/16/17 12:16 PM)
#2384833 - 10/09/17 10:17 PM HUSRT B Body Ramrod and Super shifter 4 Speed rods [Re: davesmopars]
davesmopars Offline
Loc: cheshire, ct
PM Me Here
#2385538 - 10/11/17 09:43 AM Re: 1968 11" mopar B Body Bellhousing. #2892262. Exec. Cond. [Re: moparts]
71yelladustr Offline
Loc: Missouri U.S.A.
70-74 E body original Hurst pistol grip shifter assembly with early push-in handle. Includes linkage,like new bezel, and boot. $500+shipping
McLeod RST dual disc clutch setup. Less than 250 miles. Excellent shape. For 1"x23 spline trans and 10.5 flywheel. $550+shipping.
PM,call,or text (573)433-0192. Thanks.
71 duster 452" 906 heads by KG, E-85 727 Dana 60
#2385551 - 10/11/17 10:09 AM Mopar Big block Bell Housing 2892513 [Re: 71yelladustr]
davesmopars Offline
Loc: cheshire, ct
B and E Body Big Block Bell Housing
casting number 2892513
395.00 plus shipping
Edited by davesmopars (10/12/17 07:54 AM)
#2385568 - 10/11/17 10:30 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
I HAVE A VERY GOOD USED #BMM-80706 B&M PROSTICK SHIFTER WITH
FORWARD PATTEREN FOR YOUR MOPAR.
$185 FREE SHIPPING IN USA
CALL OR TEXT FOR PICS 724-208-4570
#2385578 - 10/11/17 10:49 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
JUST REBUILT 727 BIG BLOCK TRANS NEW CRT FULL MANUAL VB WITH LOW BAND APPLY,CRT RED FLEX KD BAND&KEVLAR REV BAND,BILLET REAR SERVO,BLOCKED ACC.,A&A MODIFIED FRONT SERVO WITH SPECIAL SPRING,4.2 LEVER.H.D.BAND STRUT,BOLT IN SPRAG,DEEP PAN,STOCK DRUM WITH ALTO RED CLUTCHES,REAR DRUM ALTO RED CLUTCHES,MODIFIED OILING SYSTEM,REAR CLUTCH MODIFIED WITH SPECIAL SPRING & PISTON,NEW PUMP GEARS,TEFLON SEALS IN PUMP & STATOR.
$1.400 AND FREE SHIPPING IN USA
CALL OR TEXT FOR INFORMATION AND PICS.
724-208-4570
OTHER TRANS AVAILABLE CALL FOR NEEDS.
#2385587 - 10/11/17 11:04 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
MOPAR 904 SMALL BLOCK TRANS STREET/STRIP,STOCK DRUM MODIFIED WITH SPECIAL SPRING TO STOP IT FROM UNWINDING ON TOP END,5-ALTO RED CLUTCHES,KOLENE STEELS,FORWARD DRUM 4-ALTO RED CLUTCHES,KOLENE STEELS,5.0 LEVER,H.D.BAND STRUT,CRT 1.6 WIDE MODIFIED RED KD FLEX BAND,CRT RED DOUBLE WRAP REV.BAND,LIGHTENED SUN GEAR,REAR DRUM,LOW/REV DRUM,LOW GEAR SET,4-PINION STEEL PLANETS,FRT/REAR,DEEP PAN,TEFLON SEALS,NEW PUMP GEARS,GASKETS,SEALS,BILLET REAR SERVO,BLOCKED ACC.,2-SPRING FRONT SERVO,CRT FULL MANUAL VB WITH LOW BAND APPLY.
$1,400 FREE SHIPPING IN USA
CALL OR TEXT FOR PICS. 724-208-4570
#2385796 - 10/11/17 04:22 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: 2abodymcodes]
2abodymcodes Offline
Loc: Shelby, Ohio
Hughes 3500 stall converter. Part # 27-35. 27 spline. out of a 904. Used 3 seasons for weekend racing. $280.00 plus shipping. Send a P.M. or text to (419)543-6014
Edited by 2abodymcodes (10/11/17 04:24 PM)
#2386395 - 10/12/17 03:49 PM E Body Hurst Super Shifter [Re: 2abodymcodes]
davesmopars Offline
Loc: cheshire, ct
lock out reverse push down to engage
correct rods and levers
correct mounting bracket
***sold***
Edited by davesmopars (10/25/17 09:49 AM)
#2387123 - 10/13/17 09:15 PM Re: E Body Hurst Super Shifter [Re: moparts]
RR J Offline
Loc: Minnesota
I have 2 cable shift trans for sale.
One is a 1965 Dodge BB complete. $300 obo
The others are 1 65 tran BB with the bell cut off,
1 64 BB complete. $300 obo for the two.
NO SHIPPING. PM or call 218-626-5223
Edited by RR J (11/05/17 01:02 AM)
#2387982 - 10/15/17 11:33 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Slowride
Loc: PA.
Small block 727 core for sale. Been sitting inside my heated garage for years so condition unknown and is why I'm selling as a core. WILL NOT SHIP but can deliver to the Halloween Classic at Norwalk Ohio later this month if paid in full before race. 125.00
1970 Duster
6.143@110.89 mph
6.001@113.27mph
9.44@138.23
#2388170 - 10/16/17 12:24 PM HURST A Body Ramrod 4 Speed shifter [Re: pittsburghracer]
davesmopars Offline
Loc: cheshire, ct
Just bolt in and go
1200.00 shipped
Edited by davesmopars (10/17/17 09:14 AM)
#2389628 - 10/18/17 10:14 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
ejtmopar Offline
Loc: plymouth, NH
Used big block 727 transmission Pulled from a 68 Imperial Crown Coupe< I drove the car before I pulled it apart and the transmission worked fine through all the gears. It has been sitting in my garage for 3 years now so you may want to freshen it up. $375
No shipping Local pick up only.
ejtmopar@hotmail.com
Rumney, NH
#2390938 - 10/21/17 05:44 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
mopars4ever Offline
Loc: md
Used starter shield for manual trans cars. $13 shipped US
#2391843 - 10/23/17 01:13 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
torredcuda Offline
Loc: NH
Push button BB 727 for sale, came out of running , driving `64 Imperial, $150 or B.O. local pich up only in Epping NH
https://www.facebook.com/pages/Northeast-Mighty-Mopar-Club/365435766974452?ref=aymt_homepage_panel
`72 Barracuda 340/4spd
`70 road runner 383/auto
`70 Duster 360/auto drag car
`71 Duster project
`76 W100 clubcab project
`83 W350 plow truck
#2394530 - 10/28/17 11:17 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1971 to 1974 B-body and 1970 to 1974 E-body NOS shifter boot bezel, part #2996415 $150.00 (708)288-2879 Scott
#2394534 - 10/28/17 11:23 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
426 HEMI 727 torqueflite front drum, rear drum and brand new band, all parts are in excellent condition $750.00 for everything (708)288-2879 Scott
#2394542 - 10/28/17 11:34 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1962 and 1963 Max Wedge T-85 3-speed transmission $2500.00 also have the correct aluminum bellhousing for the T-85 $650.00 (708)288-2879 Scott
#2394546 - 10/28/17 11:38 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1966 and 1867 B-body 426 HEMI bellhousing for direct drive starter, casting #2780512, excellent used condition $1150.00 (708)288-2879 Scott
#2394549 - 10/28/17 11:43 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1968 and 1869 B-body 426 HEMI bellhousing for direct drive starter, casting #2892259, excellent used condition $1450.00 (708)288-2879 Scott
#2394552 - 10/28/17 11:46 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
NOS in the box 1969 and up three prong neutral safety switch $60.00 (708)288-2879 Scott
#2394560 - 10/28/17 11:52 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1969 383, 440 and 440 SIX PACK 11 inch bellhousing, casting #2892626, not cracked, I have ran a tap down all the threaded holes and there are no stripped threads, excellent used condition $450.00 (708) 288-2879 Scott
#2394562 - 10/28/17 11:55 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1970 to 1974 383, 400, 426 HEMI, 440 and 440 SIX PACK 10 1/2 inch bellhousing, casting #2892513, not cracked, I have ran a tap down all the threaded holes and there are no stripped threads, excellent used condition $400.00 (708) 288-2879 Scott
#2394568 - 10/29/17 12:04 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1968 and 1969 18 spline HEMI 4-speed transmission, rebuilt about 8 years ago and never installed in a car $2200.00 (708)288-2879 Scott
#2394741 - 10/29/17 10:51 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
bbtrux Offline
Loc: ohio
833od from 84 D-100 318 truck , complete with shifter bellhousing , clutch and flywheel - $375.00 OBO ; small block 727 core - $50.00 OBO. Call or text 419-512-1612 , or e-mail rocknwrench@gmail.com. Thank you.
#2394917 - 10/29/17 02:23 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
chrisnben Offline
Loc: Madison, Wisconsin
Small block Trans bellhousing & inspection cover. fits any 68-76 model A833 trans. $175
message me here, thanks.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
#2395753 - 10/30/17 09:25 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Moparguy383 Offline
Loc: Cumberland, MD
SOLDB&M SFI approved flexplate for a cast crank big block. Only used for 2 years, then changed engines and this went on the shelf. $65 shipped in the lower 48. I will take paypal if you send it as a gift.
Email me moparguy383@hotmail.com for more pictures or information.
Edited by Moparguy383 (11/07/17 12:00 AM)
#2395857 - 10/31/17 12:22 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: Moparguy383]
dsd70bee Offline
Loc: oak park, il.
1970 and early 1971 E-body Hurst Pistol Grip shifter box excellent used condition $250.00 (708) 288-2879 Scott
#2395864 - 10/31/17 12:34 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
1970 to 1972 E-body and 1971 and 1972 B-body shift linkage for Pistol Grip shifters, excellent used condition $150.00 (708)288-2879
#2395875 - 10/31/17 01:35 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Moparguy383 Offline
Loc: Cumberland, MD
New Derale transmission cooler. Part number 13751, 9x9x1.25 inches, -6 AN inlet & outlet. Would not fit my application and I waited to long to return it. My loss is your gain. $50 plus shipping. I will take Paypal if it is sent as a gift.
#2398843 - 11/05/17 11:31 AM Re: 1969 B-Body 18 Spline Hemi 4-Speed Transmission [Re: moparts]
Moparlang Offline
Loc: MD
1969 Hemi 4-Speed For Sale. This trans is out of an A34 Coded 1969 GTX that was totalled in the 1970's, VIN L9G275558, build date of 5-26 according to the fender tag. It was a 440 car that had about 30k miles on it. This was installed in a 1972 Cuda show car back then and was rarely driven. As you can see, it has the later model tailshaft housing on it with the dual shifter mounts on it. This is a good working trans, with little movement in the input bearing, input bearing retainer has some surface rust, but no grooves and needs to be cleaned. Stamping on the VIN area is PP833 9G275558. Asking $1800.00. PM me for more info or pics.
Thanks Moparts!!
https://photos.google.com/album/AF1QipPzLAYei3YukqQLl8ynprIyg6po4NK5HhdbPNQm
The "mailman's son" Bad mailman!!
#2399398 - 11/06/17 12:26 PM 426 hemi transmissions for sale [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
70 426 hemi transmission case part #PK3410671 $1,300
69 426 hemi auto transmission part #PK2892094 apart and missing a few parts $1,500
66 426 hemi auto transmission part #H2538389 apart and missing parts $750
69 b-body 4spd transmission 23 spline $749
orange park,fl
email: gdmusclecarparts@yahoo.com
shop # 904-272-1803
cell # 904-589-4645
Edited by gdmusclecar (11/06/17 12:40 PM)
#2400115 - 11/07/17 04:41 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
mosweethemi Offline
Loc: VA.
Hello I have a 1969 Barracuda or Dart transmission for sale that came in a 383 car. Part number 2892091 needs rebuilt . $1000.00 or best offer e-mail me at mosweethemi@yahoo.com or call 540-337-4310 and on here . thanks Moparts O.B.O
Edited by mosweethemi (11/10/17 06:24 AM)
#2400635 - 11/08/17 03:44 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
CRT Offline
Loc: Cedar Lake IN
10% off all trans parts ( not including torque converters ) or
$100.00 off any CRT "PRO" Series transmission.
Friday 24th & Monday 27th from 10am-6pm Chicago time
call 219-374-0100 or order on line at www.CopeRacingTrans.com
Edited by CRT (11/15/17 11:51 AM)
Cope Racing Transmissions
#2400706 - 11/08/17 06:42 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
junkyardmaxie Offline
Loc: OH
1971 904 stock valve body [ rod doesnt come with it had to use it on man valve body]and steel pan both good condition $40.00 plus shipping
#2400709 - 11/08/17 06:50 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Loc: OH
727 heavy duty trans parts NEW $28.00 shipped
#2400730 - 11/08/17 07:36 PM 383 400 440 Truck - 4X4 - 727 Transmission [Re: moparts]
Mopar_Mike Offline
Loc: Danville, NH
This is a good 1973 (part number on rail *3898856..........400/440.....727..........truck, 4WD, long-heavy duty) Big Block Truck 4X4 727 transmission. Comes with original converter. $150 No shipping unless you arrange it.
fas141@comcast.net
Edited by Mopar_Mike (11/08/17 07:40 PM)
RS23L7 440 4-Speed
RS27L7 440 727
WS23L7 484 Hemi - 727 - Dana 4.10
WS27L7 440 727
#2401598 - 11/10/17 06:51 PM A body 4 speed tailshaft and housing [Re: Mopar_Mike]
Genuinejed Offline
Loc: Spokane,WA
A body four speed output shaft and housing.
Nice shape. $300 shipped.
Genuinejed2@aol.com
Edited by Genuinejed (11/10/17 06:52 PM)
#2401603 - 11/10/17 06:59 PM 4 speed case [Re: Genuinejed]
Genuinejed Offline
Loc: Spokane,WA
Had 18 spline guts in it, early small bearing version good shape.
$150 plus shipping
Genuinejed2@aol.com
#2402124 - 11/11/17 05:48 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Scotts72Rallye Offline
Loc: Third Stone from the Sun
Lokar KD-2727HT
Chrysler TF-727 Stainless Steel Kickdown Cable Kit, Brushed Finish, Aluminum Fittings and Ferrule. Need more info just see the links below. Summit and Jegs are both asking $76, I'm only asking $60 with free shipping to the lower 48 states. PM me here if interested. Thanks!
Info links:
http://www.jegs.com/i/Lokar/625/KD-2727HT/10002/-1
https://www.summitracing.com/parts/lok-kd-2727ht
Edited by Scotts72Rallye (11/11/17 05:58 PM)
1972 Dodge Challenger Rallye
UNDER CONSTRUCTION
#2402152 - 11/11/17 06:21 PM Re: New 5.13 Richmond Gears, 8 3/4, 742 case [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
I have for sale a new set of Richmond Gear 5.13 gears for the 8 ¾ rear with the 742 housing. These gears have never been used and are still in the original box.
https://www.summitracing.com/parts/rmg-6901451
I would like to get $170 for the set shipped to any US location.
Edison, NJ
rider1454@aol.com
#2402486 - 11/12/17 10:59 AM Re: New 5.13 Richmond Gears, 8 3/4, 742 case [Re: PHYSIXX]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
NORS USA MADE Neutral safety switch,1965-1966-1967-1968 727, $50 plus 8 priority mail
cowgerwilliam035@gmail.com
#2402660 - 11/12/17 04:04 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Ellies Dart Offline
Loc: South Bend, Indiana
Torque converter out 77 Ram Charger ,had 360ci cast crank motor.it has about 750 miles on it when truck was rolled over, $100 plus shipping from south bend in 46628. 574-274-8214 or elliesdart@comcast.net. popcorn
#2402763 - 11/12/17 07:41 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Quicksilver440 Offline
Loc: Central Valley, CA.
OEM 130 tooth internal/neutral balance 340/440 6 bolt flywheel $135
Part No. 05-029 LUK Clutch/pressure plate/Throw-out bearing Kit Repset Brand new...installed and removed when my son realized his bell housing required a different flywheel and clutch for the starter to engage. $80
Edited by Quicksilver440 (11/12/17 07:51 PM)
First time out, best ET was 11.67 at 116.56 mph
...Rob
#2403176 - 11/13/17 04:38 PM Slant 6 833 Alum Bellhousing [Re: Quicksilver440]
jcc Offline
Loc: Trumussia
Used, will fit other Trans, has had clutch Z bar bosses removed for Hyd clutch package application, they are not likely reinstallable. uses the larger pilot (OD?),may need to acquire reducer bushing in your application, all threaded holes have been chased, as is, as pictured, ships from SW Fla, $100 + shipping/packing, payment within 7 days, PM
Edited by jcc (11/14/17 09:24 AM)
#2403892 - 11/15/17 08:11 AM parts for sale [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
70 t/a challenger,aar cuda 340 six pack automatic transmission part #3410769.This trans is complete $2,000
8-3/4 3.23 suregrip chunk 489 case $895
8-3/4 3.91 ring and pinion $150
e-body 4spd transmission tailhousing $275
orange park,fl.
e-mail: gdmusclecarparts@yahoo.com
shop # 904-272-1803
cell # 904-589-4645
#2404236 - 11/15/17 07:23 PM Two 833 A Body transmissions for sale ****sold**** [Re: moparts]
GKMOPAR Offline
Loc: Hilliard, Ohio
I have 2 - 833 4 spd transmissions for sale. One is a 69 VIN LM23P9B1XXX34 (can't quite read the middle 3 #s) and the other is a 70 VIN 0R220932. I purchased these a couple of years ago for my Demon but have found another that is a better match. I have not tried them. They appear to be in good shape. I can turn by hand and shift into different gears. Come with shift levers and shifter mounting pads. Price is $400 each. Prefer local pickup. Thanks
Gerry
******sold******
Edited by GKMOPAR (11/18/17 07:59 AM)
24,969 Registered Members
185,451 Topics
Garage door guys. Help leveling door.
by MoparPosterChild
Today at 12:47 AM
Well, I did it. '17 Challenger.
by 68SportFury
Yesterday at 10:23 PM
Similarity between new Durango taillights and 70 GTX grill
by Airgrabber
Yesterday at 10:11 PM
water damaged cars
by Stroker Scamp
Yesterday at 10:10 PM
