you are going to have to conjur up a service manual or printout of the circuits involved I'd say briefly looking at it. First thing you'll have to figure out is "if" your current truck has the premium central timer module. From there I'd be looking at the under seat connectors and central timer connectors to see if the wiring harness is prepped for this option as well as the underhood junction block to see if there are even pins in the heated seat relay slot. Seat heat interface module is another item you'll need.
