Anyone measure A/F Ratio using multimeter with an O2 sensor?
#2376877
09/26/17 12:00 AM
09/26/17 12:00 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
It seems like this should be an easy way to make a crude Air/Fuel gauge for basic carburetor tuning on normally aspirated cars.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Anyone measure A/F Ratio using multimeter with an O2 sensor?
[Re: Michael Ecks]
#2376893
09/26/17 12:22 AM
09/26/17 12:22 AM
Posts: 1,822 Colorado
denfireguy
Colorado
It seems like this should be an easy way to make a crude Air/Fuel gauge for basic carburetor tuning on normally aspirated cars. You can with a narrow band sensor but it does not tell you much. Hook the heater up to 12V and measure the output of the sensor. With the engine running, the sensor will read 1 volt when at 14.7 to 1 AFR. Any other voltage indicates the AFR is not stoic. Wideband sensors give you a lot more information but they are not linear and indicators like the LC-1 translates the voltages for you into AFR. There are Arduino applications to do the same thing: https://www.youtube.com/watch?v=W9Izy425jGQCraig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#2376897
09/26/17 12:26 AM
09/26/17 12:26 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It seems like this should be an easy way to make a crude Air/Fuel gauge for basic carburetor tuning on normally aspirated cars. You can with a narrow band sensor but it does not tell you much. Hook the heater up to 12V and measure the output of the sensor. With the engine running, the sensor will read 1 volt when at 14.7 to 1 AFR. Any other voltage indicates the AFR is not stoic. Wideband sensors give you a lot more information but they are not linear and indicators like the LC-1 translates the voltages for you into AFR. There are Arduino applications to do the same thing: https://www.youtube.com/watch?v=W9Izy425jGQCraig Widebands are actually linear. My LC2 talks to my Megasquirt ECU with a two-point line, "what AFR 0v" is and "what AFR 5v is". Arduinos are fun to play with and I could see this being one of the lowest-cost solutions, if you have a little electrical/coding background.
[Re: GoodysGotaCuda]
#2376992
09/26/17 10:06 AM
09/26/17 10:06 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The signal really should be cleaned up by a signal conditioner of some sort, using a multimeter will bounce around to a point it will not be useful. Use an analog meter, response time is slow enough to "condition" the signal.
#2378407
09/28/17 06:02 PM
09/28/17 06:02 PM
denfireguy
Colorado
It seems like this should be an easy way to make a crude Air/Fuel gauge for basic carburetor tuning on normally aspirated cars. You can with a narrow band sensor but it does not tell you much. Hook the heater up to 12V and measure the output of the sensor. With the engine running, the sensor will read 1 volt when at 14.7 to 1 AFR. Any other voltage indicates the AFR is not stoic. Wideband sensors give you a lot more information but they are not linear and indicators like the LC-1 translates the voltages for you into AFR. There are Arduino applications to do the same thing: https://www.youtube.com/watch?v=W9Izy425jGQCraig Widebands are actually linear. My LC2 talks to my Megasquirt ECU with a two-point line, "what AFR 0v" is and "what AFR 5v is". Arduinos are fun to play with and I could see this being one of the lowest-cost solutions, if you have a little electrical/coding background. Mine was even easier: just told the Megasquirt it was an LC-2 (LC-1 with no display). Craig
[Re: denfireguy]
#2378469
09/28/17 08:22 PM
09/28/17 08:22 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It seems like this should be an easy way to make a crude Air/Fuel gauge for basic carburetor tuning on normally aspirated cars. You can with a narrow band sensor but it does not tell you much. Hook the heater up to 12V and measure the output of the sensor. With the engine running, the sensor will read 1 volt when at 14.7 to 1 AFR. Any other voltage indicates the AFR is not stoic. Wideband sensors give you a lot more information but they are not linear and indicators like the LC-1 translates the voltages for you into AFR. There are Arduino applications to do the same thing: https://www.youtube.com/watch?v=W9Izy425jGQCraig Widebands are actually linear. My LC2 talks to my Megasquirt ECU with a two-point line, "what AFR 0v" is and "what AFR 5v is". Arduinos are fun to play with and I could see this being one of the lowest-cost solutions, if you have a little electrical/coding background. Mine was even easier: just told the Megasquirt it was an LC-2 (LC-1 with no display). Craig The preloaded LC2 numbers varied slightly from how my LC2 came from Innovate, so I loaded those specific numbers in.
