Re: Attaching Duster nameplate to fender
[Re: AndyF]
#2375780
09/24/17 01:44 AM
09/24/17 01:44 AM
Posts: 857 The Dalles, OR.
Dusted_Ya
The Dalles, OR.
These are the correct ones and like stumpy said Ace hardware probably carries them.
http://www.ebay.com/itm/20-PUSH-ON-EMBLEM-TRIM-RETAINERS-1930S-60S-GM-FORD-MOPAR-MUSTANG-CAMARO-CUDA-/311414638515?hash=item4881c247b3:g:amkAAOSwPcVVvFwC&vxp=mtr
Retired Mopar fanatic
[Re: AndyF]
#2375951
09/24/17 03:32 PM
09/24/17 03:32 PM
Posts: 294 Maryland
MoparMike1974
Maryland
I believe the originals on a duster were the nylon ones. I have seen the metal ones on earlier cars. The duster did use the metal ones on the plastic badge that goes on the inside of door panel.
http://www.ebay.com/itm/Mopar-Emblem-Trim-Retainers-62-Up-A-B-C-E-Body-10-Pack-13-/132317100720?hash=item1eceb6bab0:g:MEMAAOSwurZZLzIR&vxp=mtr
[Re: AndyF]
#2377910
09/27/17 08:21 PM
09/27/17 08:21 PM
Posts: 30,989 Oregon
AndyF
Good thing I ordered both types. The plastic clips didn't work on my car, the nameplate ended up loose enough to rattle around. So I put the little barrel nuts on there and that made it nice and snug. The plastic clips must require a smaller hole in the fender or something. Here is what I used: http://www.ebay.com/itm/131759049694?rmvSB=true
[Re: MoparMike1974]
#2378089
09/28/17 01:34 AM
09/28/17 01:34 AM
AndyF
If I remember correctly, the plastic ones have a slight shoulder that gets pressed into the hole of the fender first. Then the emblem pin gets inserted which kinda swages the plastic out to hold it in place. They are a pain to install but when done right they hold well. That was what I did but I think the holes in the fender were too large for the clips. The holes in the fender were right at 3/16 which fit the barrel nuts just fine. The clips seemed like they needed a smaller hole. Could be the clips were not made correctly or maybe my fenders were drilled for barrel nuts. I don't really know and I'm not sure who would know. I called a couple of folks but nobody had any dimensions or hard facts. That is why I just bought both and tried them. They were only a few bucks each so it I didn't mind trying both to see which worked the best.
