Re: Projected tip plugs more prone to detonation?
[Re: mopar dave]
#2375485
09/23/17 02:33 PM
09/23/17 02:33 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Just ordered a set in a 6. See how those do. I put ngk race 7's in and had an intermittant misfire. Unless you have a bad plug, connection or ? no reason the 7's should cause a misfire as I've run em w/zero issues at 12.1.1 comp..........
[Re: davenc]
#2375600
09/23/17 06:41 PM
09/23/17 06:41 PM
crabman173
crabman173
We run R5671-8 NGK with 13.7:1 on alky perfect! It is a recessed tip we use an old Vertex magneto run the gap about .018 It lights a 10% nitro alky mix perfectly would run more nitro but have way to much compression--next one is an 11:1 so we can lay the juice to it! I will call NGK and buy exactly what they say
[Re: mopar dave]
#2375658
09/23/17 08:36 PM
09/23/17 08:36 PM
Thumperdart
State of confusion
Dont know but definitely had more misfires on the race 7's than the projected tip 5's. Could be that running on the edge of rich may not clean off the 7 like it does the 5's. Gonna leave the 7's awhile and see how they work out. No experience ever running hotter than maybe a 6 in ngk and that's too hot for most of what I mess with but you are close to 11.1 iirc so not exactly low comp. and if in fact it liked the 5's I'd look real close at the porcelain w/a mag. glass and see how they look but still say #7 if the tunes close............... Just re read that you ran non projected tips in a 7..........Is that correct cos that's not the best plug for you imo, get the 7 projected tip and let tune this thing............
[Re: dthemi]
#2375954
09/24/17 03:38 PM
09/24/17 03:38 PM
Posts: 2,724 541 slobovia
A990
541 slobovia
Just to interject something I know doesn't answer the question. The most detonation resistant plug I've seen with in car, and on dyno experience is an NGK 6061-10. That is against autolite AR series, and champions true race series plugs. Can't copy the pic, but look at the electrode, and strap arrangement in the link. http://static.summitracing.com/global/images/prod/large/NGK-5962_w.jpg Does the non resistor part cause problems?
