Page 20 of 21 1 2 18 19 20 21
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #2039750
03/27/16 03:09 PM
03/27/16 03:09 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
If you plan to use the late model P/S pump idler (on cars with electric power steering) on an earlier engine (non-VVT), be warned - the bracket is cast of the lowest quality aluminum which doesn't want to weld for @%!T. Think welding the most crappy 50's aluminum casting that's been in oil forever, and it's about that bad. And this was new out of the box, maybe it's made of pot metal....
Re: Gen III Hemi, please post things to avoid and know.. [Re: ntstlgl1970] #2375036
09/22/17 02:32 PM
09/22/17 02:32 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
So...I've read most of these 10 pages and I feel I'm suffering from information overload, LOL. I am obviously a Gen III newbe...my question, simply stated would be if I was going to a salvage yard looking for base parts to build a street strip Gen III what would be the desired parts to put on my shopping list, IE, desired years, configuration, short blocks, intakes, heads, etc.? Hope this isn't oversimplifying my question, thanks in advance. up
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #2375077
09/22/17 03:31 PM
09/22/17 03:31 PM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
hard to beat an eagle 5.7 from a truck, its got the best intake, almost the best heads, decent compression, the pistons are stronger than the earlier one, rods are slightly better, if you don't like VVT (I like it) then it is easy to lock out, if you like MDS (I like it) get one from a 1500 if you dont get one from a 2500 3500 or just leave the solenoids in and don't worry about it. The 6.4 apache cam is a real nice, easy upgrade. Short of coughing up the big bucks for a 6.4 apache or 6.4 BGE and upgradeing the cam with the apache, this is about the easiest cheapest route to big power.
Re: Gen III Hemi, please post things to avoid and know.. [Re: HotRodDave] #2375079
09/22/17 03:36 PM
09/22/17 03:36 PM
Weatherford, Texas
Weatherford, Texas
Good info, thanks, any particular year to stay away from or are any years more desirable than others?
1968 Plymouth GTX
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #2377673
09/27/17 12:48 PM
09/27/17 12:48 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
some of the 09-14a have a high mileage lifter issue.
Some timing chain issue, not sure which year.
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #2422794
12/23/17 08:55 PM
12/23/17 08:55 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I just picked up Larry Sheppard's "New Hemi Engines" book from Barnes and Noble. For $20, it's a pretty good read on some of the basics of the G3s, all in one place. My only gripes are he is pretty vague on some topics, touches only lightly on the BGE, and despite it being labeled "how to build max performance", there is very little building tips inside.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Gen III Hemi, please post things to avoid,,,,,,,,, [Re: gregsdart] #2467388
03/16/18 04:37 PM
03/16/18 04:37 PM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
1st, I know this is an old thread but I just re-read all 10 pages and didn't see my questions asked or answered.
03 ram 5.7 with 4 cooked rod bearings, suspect a failed oil change to be at fault. I have an extremely low mileage 06 jeep long block to swap in the truck after an .030 overbore ( due to water sitting in the bores and pitting the cyl walls). I'm wanting to know if the 06 MDS cam will work fine in my 03 non MDS build. I already plugged the MDS with billit plugs and the truck was NON-MDS to begin with. I guess my question is, is the cam the same ? The 03 cam looks like it got hot with the rest of the 03 engine. I'm using all the accessories from the truck, just basically replacing the engine with the rebuilt 06 long block minus the MDS.
2nd. Should I swap to the 6.1 valve springs and pushrods while the engine is apart. Short block is assembled, putting the rest together today if possible.
PS. The intended use of this will be a daily driven 2500 4x4 with 4.10 gears, and pulling a boat or camper or race car around.
Thanks in advance.
67 Dart GT Convertible 273
68 Barracuda 383
68 Roadrunner 383 4spd
1 '01 Ram 2500 4x4 diesel
2 '02 Rams 1500 4x4's 4.7s
3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4
Oh, and a 03 Grand Cherokee and an '00 durango smile
Re: Gen III Hemi, please post things to avoid,,,,,,,,, [Re: gregsdart] #2467397
03/16/18 04:49 PM
03/16/18 04:49 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
#1 The cam is not the same, but it's fine to use.
#2 while it's apart might as well upgrade to the 6.1 stuff.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Gen III Hemi, please post things to avoid,,,,,,,,, [Re: ric3xrt] #2467400
03/16/18 04:53 PM
03/16/18 04:53 PM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
Thanks for the response. What are your thoughts about using an 06 6.1 cam while I'm at it ? My dealership can get me the cam and springs overnight for around 550 bucks, haven't checked on the pushrods yet.
And if I do the cam, will it need a tune ? Just looking for torque, pulling, mileage.
68 Barracuda 383
Re: Gen III Hemi, please post things to avoid,,,,,,,,, [Re: ta3834bbl] #2467559
03/16/18 11:31 PM
03/16/18 11:31 PM
USA
hudsonhornet7x Offline
USA
Other guys here will know better than me, but $ 550 sounds very high for the 6.1 cam and springs.
Re: Gen III Hemi, please post things to avoid,,,,,,,,, [Re: hudsonhornet7x] #2494910
05/11/18 09:41 PM
05/11/18 09:41 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I was quoted $68 for a 6.4 cam and $300 for a 5.7 cam. Didn't price the springs. A full set of lifters for my 2012 Ram was a little over $500.
Re: Gen III Hemi, please post things to avoid,,,,,,,,, [Re: AeroMonte] #2639414
03/31/19 11:06 PM
03/31/19 11:06 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
I'm sorely tempted to do one before I retire, and likely retire the car. I'd freshen the 360 and sell it to free up some cash. My "vision" is a standard bore 5.7 with H-beam rods and a forged piston shooting for 10.5-11.0:1 compression. Basically stock heads, and a bigger cam that will still play nice with the stock rockers. I'd go the carb route, with something like an 850-950 Holley. I would obviously like to stick with my 904, and the 5.13's I'm currently running.
I currently run a motor plate and electric water pump. I see headers and ignition as big hurdles in a 69 Dart with a stock cross member. What else? As it stands, I don't see this being a tremendous deal, or am I dreaming in technicolor?
Re: Gen III Hemi, please post things to avoid,,,,,,,,, [Re: Greenwood] #2682030
07/28/19 01:38 PM
07/28/19 01:38 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
It's not that big of a deal, Headers Call TTI they make em, Ignition , MSD Hemi-6 is the box you want.
aeicnc.com is a good place for motor plate,
Stock bore and stroke 5.7 10-12 to 1 compression , Comp cams 273 Arrow/prefix single plane intake will get you about 500Hp with some work to the 03-08 heads , If you go with the 09+ 5.7 eagle heads 500Hp is easier.
Manley has a good stock bore piston so does DSS, 6.1 cranks are getting harder to find just keep that in mind. Eagle and Scat both have decent H- beam rods for under 500
There is user here that sells the Prefix line of products, search around the G3 section and you'll find hemi
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Gen III Hemi, please post things to avoid,,,,,,,,, [Re: Ray408G3Hemi] #2682084
07/28/19 05:54 PM
07/28/19 05:54 PM
K
Kiddart Offline
Kiddart  Offline
K
if this is a new motor build? Pack the oil pump with assembly grease or petroleum jelly, you will thank me later!!
Thank you
Kiddart
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #2696535
09/11/19 12:46 PM
09/11/19 12:46 PM
Alabama
swapdaddyxx1 Offline
Alabama
I have a problem that I'm sure others have experienced. At the last oil change by the local quickie oil change, the mechanic? broke the handle of the dip stick in my 300C. I think this is a design flaw since the metal in the dipstick is not extended all the way up into the handle. The mechanic was not able to get the stick out of the tube He tried drilling a small hole in the plastic left on top of the stick, inserting a small screw to pull it out with pliers but this did not work. The plastic left in the tube seems to be stuck to the tube. I will soon be 83 yrs old with some rather severe physical limitations and not able to do much anymore. The car which is my wife's car will soon be due for another oil change and I don't think I want this same guy messing with it. I am sure there is a bracket welded onto the tube and bolted to the engine block but there is no room to get my hand down between the engine and the inner fender liner. Can it be accessed from under the car if it is on a lift? Anyone else experienced this and any ideas without having to go to dealer who is not convienentley (sp) located?
Re: Gen III Hemi, please post things to avoid and know.. [Re: swapdaddyxx1] #2696579
09/11/19 02:54 PM
09/11/19 02:54 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
If the screw is still in the handle use a heat gun to heat up the dip stick tube under the handle. This will release the orings on the handle and it should slide out.
Re: Gen III Hemi, please post things to avoid and know.. [Re: biff426] #2757477
03/30/20 03:53 AM
03/30/20 03:53 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Milodon pan, TTI Mounts, TTI headers, factory suspension and steering box - car is a 67 Belvedere II.
Very smooth install however full lock causes the drag link to interfere and scrape the back of the pan well.
This could result in the pan cracking after time.
Simple solution is to split a couple of feet of 3/4 ID hose and wrap the drag link with it.
More professional fix is to weld a couple of 3/16 turn stops on the lower control arms.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Gen III Hemi, please post things to avoid and know.. [Re: Moparmal] #2757575
03/30/20 12:40 PM
03/30/20 12:40 PM
Kalispell Mt.
HotRodDave Offline
Kalispell Mt.
Maybe you could slot the motor mount holes a smidge
Re: Gen III Hemi, please post things to avoid and know.. [Re: HotRodDave] #2772664
05/09/20 12:02 AM
05/09/20 12:02 AM
Moparmal Offline
Moparmal  Offline
Good thought!
Re: Gen III Hemi, please post things to avoid and know.. [Re: Moparmal] #2810603
08/19/20 11:27 AM
08/19/20 11:27 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
All, I don't know if this information has been provided quite yet but I wanted to let everyone know. I just got a camshaft quoted from Comp Cams and LSM. For a solid roller VVT from LSM, it would be $1200. Comp cams doesn't have any VVT cores but for a solid roller non VVT cam the cost was about $1100. Both of these cams were going to be high rpm big duration camshafts for my engine build. Just an fyi for anyone interested.
Adriel Paradise
Substation Design Engineer III
