68 b body master cylinder #2373883
09/20/17 01:44 PM
09/20/17 01:44 PM
Omaha
road Offline OP
road  Offline OP
Omaha
Not getting fluid to come out of the front (Rear brake reservoir) of a rebuilt Master cylinder. In car and would like not to take out.
Thoughts
Re: 68 b body master cylinder [Re: road] #2373928
09/20/17 03:17 PM
09/20/17 03:17 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
bench bleed on car, just be careful with your paint. could be a junk rebuild.
Re: 68 b body master cylinder [Re: road] #2374023
09/20/17 06:43 PM
09/20/17 06:43 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Thoughts
Cking directly at the master cylinder line connection ?
If nothing you need to pull it off , no way around that
Re: 68 b body master cylinder [Re: road] #2374139
09/20/17 09:25 PM
09/20/17 09:25 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Just had the same problem. It took me 3 masters to get a good one
