Page 2 of 3 < 1 2 3 >
#2372847 - 09/18/17 03:27 PM Re: 6.4 BGE specs [Re: WO23Coronet]
ric3xrt Offline
Loc: Trumbauersville PA
Originally Posted By WO23Coronet
Originally Posted By ric3xrt
IF you get the chance to cut both heads open, the Hellcat have more material under the Intake valve seat and waters passages around exhaust port are larger.
Over the BGE head?
Yes
#2429334 - 01/05/18 01:23 AM Re: 6.4 BGE specs [Re: WO23Coronet]
cudadoug Offline
Loc: Between a rock & a hard place
I have a rookie G3 BGE question...
Will my eagle heads work with a 6.4 BGE OE shortblock?
#2429341 - 01/05/18 02:31 AM Re: 6.4 BGE specs [Re: WO23Coronet]
sp392 Offline
Loc: Etobicoke
From a junk yard stand point, I am pretty sure BGE's will be way harder to find than SRT 392's down the road.
#2429361 - 01/05/18 06:45 AM Re: 6.4 BGE specs [Re: cudadoug]
ric3xrt Offline
Yes, that's what I have in my 2014 Ram right now is SRT392 Block with the stock 2014 Eagle heads from my Ram.
Truth has no agenda, but those with an agenda don't always acknowledge truth
74 D100 D-Code,3x75 D100 D-code, 3x77 D100 D-code,6x78 D150 D-D-code...lots of pre 81 trucks
75 4x2 Ramcharger....G3 coming soon
2003 Ram st
2004 Rumble Bee
2004 Ram GTX(Plum Crazy)
2005 Ram GTXtreme(s Plum Crazy,Banana Yellow)
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building)
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2430047 - 01/06/18 02:13 PM Re: 6.4 BGE specs [Re: ric3xrt]
cudadoug Offline
What is the actual compression of that deal? Were the BGE heads a "small" chamber similar to the Eagles?
#2430357 - 01/07/18 12:35 AM Re: 6.4 BGE specs [Re: WO23Coronet]
ric3xrt Offline
BGE heads are small chamber
My actual compression is 9.7 to 1 the pistons I used were a set of probe pistons for 4.09 bore 6.1 with a 4.05 stroke. We had to modify them by milling .018 off the top because I used a 4.08 stroke scat crank and 6.125 Manley H-beam rods
2003 Ram st
2004 Rumble Bee
#2431020 - 01/08/18 10:23 AM Re: 6.4 BGE specs [Re: WO23Coronet]
cudadoug Offline
Okay, good...thank you. I was curious if the Eagle head on the BGE resulted in a high CR ala an early 5.7 block.
#2434743 - 01/14/18 09:11 PM Re: 6.4 BGE specs [Re: L4staero]
gts95 Offline
Loc: D/FW
I have a BGE on its way to me so i will keep u updated. I think its in the hemi vendors best interest to not let on that the pistons and rods are any good. Their livelyhood is selling pistons and rods always with the scare tactics of no more than 5 psi boost on 6.4s etc. Or you need pistons and rods to make power.....Quite a few cars locally on standard pistons. Low 10s in a 300 with a 6.4.
Heads are cast same as a hellcat... same material andnports just intake bolt pattern differs
Sweet! Are you going to tear into abit or run as is?
Will be doing a full tear down
Did this teardown ever occur? Would be very interested to hear what you found. Forged pistons??
1970 Super Bee, WM21, 383, auto, FY1, a/c, project! 1971 Chrysler 300 2dr, U-code, console car 1980 Chrysler LeBaron LS Limited coupe 2008 Chrysler Aspen, HEMI 2011 Ram 3500 MegaCab, 6.7
#2434815 - 01/14/18 11:46 PM Re: 6.4 BGE specs [Re: gts95]
L4staero Offline
Loc: Australia
Yes i carried out a full strip down. The pistons are not forged like Mopar said in their press release. They are cast but have an extra 20% material above the top ring and the rods have a tapered small end like a Hellcat
#2434828 - 01/15/18 12:18 AM Re: 6.4 BGE specs [Re: L4staero]
gts95 Offline
Loc: D/FW
Interesting. Still sounds like a good bang for the buck for a shortblock from Mopar. I have a 2013 5.7 HEMI with a snapped rod, so strongly considering purchasing the BGE shortblock from Mopar, and bolting on my stock Eagle heads. My concern is figuring out my compression ratio with the Eagle heads.
I priced the Apache shortblock and BGE shortblock from my dealer and they are very close in price.....would seem the BGE is the beefier setup.
#2435319 - 01/15/18 08:52 PM Re: 6.4 BGE specs [Re: WO23Coronet]
L4staero Offline
Loc: Australia
A new Eagle short is like $900 if you return a core
#2435351 - 01/15/18 09:52 PM Re: 6.4 BGE specs [Re: WO23Coronet]
RTSrunner Offline
Loc: Pittsburgh,PA
I wonder if they'll take an early motor as a core?
#2435399 - 01/15/18 10:48 PM Re: 6.4 BGE specs [Re: ric3xrt]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
Most piston mfg will allow 2 changes to a shelf piston for shelf piston price
#2435435 - 01/16/18 12:04 AM Re: 6.4 BGE specs [Re: L4staero]
gts95 Offline
Loc: D/FW
Yah....but the motor is out now and I live by the old adage theres no substitute for cubic inches.....
Trying to figure out how they get the lower compression in the BGE motor over the Apache. And how will that work out if I bolt on my Eagle heads to a BGE shortblock.
#2435635 - 01/16/18 11:14 AM Re: 6.4 BGE specs [Re: gts95]
cudadoug Offline
Diff in compression is either pistons and/or chamber cc's. Not alot of specs published out there.
I have been told that the BGE is "9:1" with a relatively small chamber head. How small compared to the Eagle head, I wish I knew.
#2435720 - 01/16/18 01:19 PM Re: 6.4 BGE specs [Re: WO23Coronet]
ric3xrt Offline
I don't have those in fornt of me right now, I'll get them tonight,
Eagle are smaller then BGE, I think it's 65CC and 69CC .I'll double check tonight.
#2435824 - 01/16/18 03:30 PM Re: 6.4 BGE specs [Re: cudadoug]
gts95 Offline
Loc: D/FW
I agree that the technical specs on the BGE 6.4 is sparse on the Internet. The Allpar article introducing the engine back in 2014 listed the compression ratio as "10:1". Where did you read 9:1?
https://www.allpar.com/mopar/V8/truck-hemi.html
#2436068 - 01/16/18 09:59 PM Re: 6.4 BGE specs [Re: WO23Coronet]
EagleDuster Offline
Loc: Northern Colorado
You could CC the heads if you already have them, kits from Summit are cheap... also could check the 1/2" down fill volume and piston-to-deck distance to see how "tall" they are in that BGE block.
Edited by EagleDuster (01/16/18 10:21 PM)
Khalid
1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
#2436152 - 01/17/18 01:29 AM Re: 6.4 BGE specs [Re: WO23Coronet]
cudadoug Offline
I hadn't seen the allpar data; good stuff. I read 9:1 by an "expert" on Facebook.
My eagle heads are right at 67.2 cc's as cast.
So then the question becomes how much cam can you stuff in a BGE/Eagle combo with the OE piston...
#2436173 - 01/17/18 05:11 AM Re: 6.4 BGE specs [Re: WO23Coronet]
L4staero Offline
Loc: Australia
BGE has same chamber size as Apache
The lower comp in the BGE is from dished pistons
25,338 Registered Members
190,109 Topics
1966 Dodge Charger Premium
by tomsjack
58 minutes 25 seconds ago
Question on media pressure blasters.
by 71sat440
Today at 01:18 AM
Happy Father’s Day
by humpty
Yesterday at 11:26 PM
carlisle room?
by pettyblue440
Yesterday at 10:42 PM
