Re: Best PCV valve?
[Re: srunge55]
#2389634
10/19/17 12:21 AM
10/19/17 12:21 AM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
I need to do some more tuning on mine because it seems to be burning a little oil I might need to put a separator on it because my engine never had any blue smoke before. I need to go over the instructions again. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Best PCV valve?
[Re: UCUDANT]
#2390304
10/20/17 02:37 PM
10/20/17 02:37 PM
Posts: 403 Colorado front range
BcudaChris
The NAPA grommet is a little tight around the PCV body, and in the hole of my generic fleabay fabbed AL rocker boxes, but fits. Hopefully no more weeping around the grommet.OD We'll see in the spring when this thing is back on the road.
I was using a Mr. Gasket grommet and a Fram 4.6 Mustang valve.
Re: Best PCV valve?
[Re: UCUDANT]
#2390787
10/21/17 01:04 PM
10/21/17 01:04 PM
Posts: 1,317 Ohio
jlatessa
Ohio
I bought a Mustang separator that's small and well made with a needle valve drain, it's at my son's house now.
I'll try to see if he can relay the #s to me and I'll update....stay tuned, Joe
"Steeda" Oil separator Kit, #555-3710
