Re: Best PCV valve?
[Re: fourgearsavoy]
#2384821
10/09/17 11:54 PM
10/09/17 11:54 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well guys we have more than enough to make the order but if it's OK I'm gonna wait until I get home tomorrow to see if anyone else want's in on this deal. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Best PCV valve?
[Re: UCUDANT]
#2385324
10/10/17 10:36 PM
10/10/17 10:36 PM
Posts: 8,128 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Huge thanks to Moparx for answering my original question (with this part), and now the masses responded with a purchase that's good stuff Don't forget to source a grommet that will work in your application guys
Re: Best PCV valve?
[Re: davenc]
#2385369
10/10/17 11:41 PM
10/10/17 11:41 PM
fourgearsavoy
Rittman Ohio
OK guys this thing really took off and I got an E-mail from the company and she said if it would be easier if each member could contact her individually. Here is the E-mail: Thank you for your information regarding the Group Buy. If it is easier for you, please have the members who are interested in participating send me their information just like you did. When I get 8 names, I will then send out the invoices through PayPal. Please call if you have any further questions. Barbara Wagner Customer Service M/E Wagner Performance Products barbara.wagner@mewagner.com www.mewagner.com570-899-4544 Just mention that you are with the Moparts group buy and the discount will be applied to your order. I'm kinda overwhelmed I thought it would be hard to get 8 orders now we have twice as many. Thanks Gus
Re: Best PCV valve?
[Re: UCUDANT]
#2385648
10/11/17 02:48 PM
10/11/17 02:48 PM
Posts: 1,317 Ohio
jlatessa
Ohio
My order is in for two, thanks for the leg work Gus
Joe
P.S. as an aside I called Fram tech support to see if they had any specs on the PCVs that some said are better for our application, i.e. low idle vacuum, He knew some were for some GM and Ford hi-perf engines but could not come up with any real numbers, so I opted for the adjustable one rather than guess.
Joe
Re: Best PCV valve?
[Re: jlatessa]
#2385874
10/11/17 08:39 PM
10/11/17 08:39 PM
fourgearsavoy
Rittman Ohio
I'm glad the group buy deal is working, I just received my invoice and I cant wait to get my valve. Since my carb doesn't have a port for vacuum and they don't recommend using an intake runner source I will need to drill my plenum. I was going to use the booster port on my Performer RPM intake but I guess that wont work so I'm going to pull the intake and find a good spot to drill and tap for a source. Does anyone else have this situation? Gus
Re: Best PCV valve?
[Re: UCUDANT]
#2385899
10/11/17 09:38 PM
10/11/17 09:38 PM
Posts: 1,317 Ohio
jlatessa
Ohio
My center carb has a port below the throttle blade I can use, but the original PCV was connected to a port under the rear carb in the intake.
I'll have to look at the schematic to see if my memory is correct.
I would imagine the central port might be the one to use when calibrating the new PCV.
I'll try both to see if there's a difference when I get ours.
Joe
Well, I was wrong again!! PCV tube goes to center carb! Rear fitting in intake must be for power brakes??
