#2370540 - 09/14/17 03:01 AM b body rear spring mount question
tex013 Offline
Loc: Sydney,Australia
I know a 68 Plymouth b body is 1"shorter wheelbase than a 68 Dodge
Is this gain in the rear spring mount length ?
I would like to move my diff back a little to fit a 30"/30.5"tall rear tyre , I have a 68 Satellite .
Or should I just use a 1/4"spacer/shim ?
thanks ,
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
#2370810 - 09/14/17 02:57 PM Re: b body rear spring mount question [Re: tex013]
AndyF Online   content
Loc: Oregon
There are a bunch of different spring hanger combos available since Ma Mopar redesigned that part on a regular basis. You might get lucky and find one that moves your axle back a bit. Mancini sells a large variety of hangers so maybe look over their selection and see what fits. I build my own hangers but that isn't an option for most folks.
#2370909 - 09/14/17 06:15 PM Re: b body rear spring mount question [Re: tex013]
tex013 Offline
thanks Andy
Tex
New best MPH 130.32
#2371035 - 09/14/17 10:36 PM Re: b body rear spring mount question [Re: tex013]
NANKET Online   work
Loc: northwest USA
Yes dodge is longer in the spring hanger by one inch.
You could get longer hangers like for super stock springs, then re drill the hole for the leaf spring thru bolt to put the rear axle right where you want.
#2371108 - 09/15/17 04:57 AM Re: b body rear spring mount question [Re: tex013]
tex013 Offline
Tex
New best MPH 130.32
25,383 Registered Members
191,007 Topics
93 Viper door handel ?
by kevin69bman
07/21/18 11:04 PM
RIP Bluebonnet Belle
by BigMoneyLewis
07/21/18 10:28 PM
Boogered up LA valve cover bolt hole - Suggestions?
by GoodysGotaCuda
07/21/18 10:00 PM
Information Binder on Car
by GTXKARL
07/21/18 09:59 PM
