E-85 Update
#23711
04/13/06 09:32 PM
04/13/06 09:32 PM
Posts: 6,389 nielsville, minn.
quickd100
nielsville, minn.
Well I've heard the naysayers and the doom and gloomers talk about all the bad aspects of running E-85. I've had people tell me it will corrode aluminum, ruin rubber fuel lines, eat plastic, eat carburetors alive. After hearing all these predictions I decided to put it to the test. Last Sept. I drove my truck down to Interstate Dragways to see Don1 and JericoGTX. After I got home that night I parked the truck in the garage. That was the last time it was started or run until tonite. It had a 3/4 full tank of E-85 in it. I shut the electric fuel pump off and let the engine run until it died. The rear float bowl was almost full, I didn't touch anything, I didn't even open the hood until tonite. I went out to the garage tonite, opened the hood, pulled the aircleaner. As I always do after sitting all winter, I started the fuel pump and let the carb fill and made sure the floats weren't stuck before hitting the key. I checked the accelerator pumps and found the rear one wasn't pushing fuel out the squirters. I pulled the rear bowl and metering block off along with the rear squirter. Everything looked as good as the day I screwed it together last summer. The needle under the squirter was stuck and a shot of carb cleaner in a can fixed that. I put everything back together let the carb fill and hit the key. The engine started instantly and ran as sharp as it did the last time I drove it in Sept. The plastic fuel cell, 3/8" aluminum fuel line, no name electric fuel pump, rubber fuel line, inline fuel filter, and carb look and work as good as they did in Sept. So much for the naysayers and the rest that said it wouldn't work. The only down side I can see is that the 105-110 octane E-85 is now only $.30 under 89.5 octane regular at my local station.Dave
Re: E-85 Update
[Re: quickd100]
#23713
04/14/06 05:48 AM
04/14/06 05:48 AM
Posts: 9,985 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Dave, nice to hear it is working for you. It is great to read storys about others that think outside the box a bit, and can engineer something to success. Good job! What power differance have you seen and how much compression do you run? I would think a motor built with optimum compression for E85 would reduce the loss of mileage some?
Re: E-85 Update
[Re: gregsdart]
#23714
04/14/06 06:18 AM
04/14/06 06:18 AM
quickd100
nielsville, minn.
Greg; I'm running 11.2-1, I'd like to have had 12.5-13-1. The motor was junk off the garage floor and I didn't want to spend any money on it. 11.2-1 was as much as I safey dared squeeze it without having valves poking holes in the pistons. As far as mileage goes, the last time I drove it going to the strip I was bucking a 25 mph headwind on the way down there. My mileage was 9.5 mpg, 1 mpg less than the last time I checked it on gasoline. I think it is probably as good or better than when the motor was on gasoline. I do believe most of the mileage issue can be made up by bumping the compression up as high as possible. Another point, I'm running it quite a bit on the rich side, for max power, I could lean the mixture down about 7%. I haven't run it at the strip on E-85 but it feels as strong, or stronger on E-85 than it did on gasoline. Here's an example; Last fall my brother and a buddy of his stopped by one Sunday. I was tuning on the carb. They decided I should take them for a ride. So the 3 of us piled into the truck, (650lbs.) I had the street tires and full exhaust on and the caltracks. We went east on a good hooking new asphalt road. I stood on it at 40-45mph. The rearend started to come around on me, we were at a 45 degree angle before it finally hooked up again. On gasoline it never did that before at least not at 80 degree temps.Dave
Re: E-85 Update
[Re: gregsdart]
#23716
04/14/06 08:10 AM
04/14/06 08:10 AM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
That 15% gasoline is enough to prevent the white chalk and the drying out of rubber and plastics that 100% alcohol does. You also have to remember our cousins in south central and south america have been running straight alcohol for years.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
Re: E-85 Update
[Re: quickd100]
#23720
04/14/06 09:37 PM
04/14/06 09:37 PM
Posts: 16,923 NC
440Jim
NC
You have to richen EVERY curcuit by 27-35%.
I don't know much about methanol either, but it sounds like methanol needs richer than ethanol. It might make sense to start with an alcohol (methanol) carb, and lean it out? Or is methanol more like 100% richer?
I have never seen E85 in Maryland, never mind in my remote section of the state.
Re: E-85 Update
[Re: 440Jim]
#23721
04/14/06 09:52 PM
04/14/06 09:52 PM
Posts: 681 Illinois
493_Scamp
super gas
super gas
Illinois
I plan on running E85 in my nearly done 493. I am going to buy a Proform 950 to modify because it is the cheapest carb of that size and some mods would be nonreversable. I should have the motor running in a couple weeks.E85 is $2.29 here.
Post deleted by Defbob
[Re: 493_Scamp]
#23723
04/14/06 10:00 PM
04/14/06 10:00 PM
Re: E-85 Update
[Re: quickd100]
#23725
04/15/06 07:00 AM
04/15/06 07:00 AM
One thing to remember, all the bad juju is taken from those running methanol. It is NOT the same as ethanol which is far less corrosive.
Re: E-85 Update
[Re: Lou_Steger]
#23727
04/15/06 09:43 AM
04/15/06 09:43 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
I'm interested in the stuff, but so far around here the prices are higher than premium gas. here's a site that has a station-finder: www.e85fuel.com
Re: E-85 Update
[Re: quickd100]
#23729
04/15/06 01:56 PM
04/15/06 01:56 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Humm this is interesting. My question is this, what kind of changes should I do to run it in my Coronet? 440 engine 750 edelbrock carb, headers stock everything else engine wise.
Mike
1969 Dodge Dart Swinger
Re: E-85 Update
[Re: MikeyT]
#23731
04/15/06 06:35 PM
04/15/06 06:35 PM
quickd100
nielsville, minn.
MikeyT; I'd say a qualified yes. You could modify a 750 eddy for it but, you will run into problems you wouldn't have with a holley. First problem, no one makes jets big enough that I'm aware of, you'd have to drill your's. To get your idle curcuit rich enough you'd have to drill the emulsion tubes in your boosters. If you go to far there isn't any going back unless you can solder the hole and redrill. My 750 AFB #4327S test mule's emulsion tubes started out at .037 I increased them to .040 when I installed a 509 cam on gasoline to get it to idle. With E-85 I'd have to drill them to .043 to get it 35% richer over the .037 baseline. With a long duration cam it would be a bit more. Also you still would have to increase the squirter size and pump shot duration for your accelerator pump curcuit. I'd do it to my carb if I had a spare 1407 eddy laying around but I hesitate to recomend it to someone else. As much as I like AFB/AVS/TQ carbs there just aren't as many tuning parts available as there are for holleys.Dave
Re: E-85 Update
[Re: quickd100]
#23732
04/15/06 06:58 PM
04/15/06 06:58 PM
MikeyT
Watertown, WI
Thanks Quickd100
Here are the detail specs on my engine
440 engine (9:1) 230/236 degree cam from comp with .491lift headers 750 Edlebrodck carb edelbrock performer intake
Is this still too long a throw of a cam to run it? Also what size/style holley would you recomend to run e85?
thank you again for your help. Mike
Re: E-85 Update
[Re: MikeyT]
#23733
04/15/06 08:15 PM
04/15/06 08:15 PM
quickd100
nielsville, minn.
First let me stress I'm no carb expert. If it was my motor and was going to run E-85 though i'd increase the compression first thing. You have to remember, E-85 has less BTU's per gallon than gasoline. It's high octane fuel and will like more compression which will offset some of the loss. The 750 double pumper carb would be tough to beat. Also I would HIGHLY recomend a LM-1 meter, it will speed the tuning process and keep you out of trouble. IMO E-85 will be becoming more common all around the country in the next couple years. Currently Holley and the other big carb companies haven't done any work with E-85. I think you will see this changing as they get more calls about it.Dave
Re: E-85 Update
[Re: quickd100]
#23734
04/15/06 11:47 PM
04/15/06 11:47 PM
Posts: 3,504 DFW
mr_340
DFW
All of the common alcohols have lower heating values than gasoline components. So does nitromethane for that matter. The power gains come from the fact that you can put more fuel in the cylinder since the A/F ratio is lower. Fuel Heating Value (BTU/lb higher) Stoich. A/F Toluene 18,245 13.5 Iso-Octane 20,556 15.1 Methanol 9,770 6.4 Ethanol 12,780 9.0 Nitromethane 5,160 1.7 An approximation to the power potential (my terminology, not from the engineering text books) of the fuel is to divide the heating value by the A/F ratio. I'm a little fuzzy on all this since I took a class in college on internal combustion engines twenty years ago. I think it's pretty close to what is right. Fuel Heating Value / Stoich. A/F = Power Potential Toluene 18,245 / 13.5 = 1351 Iso-Octane 20,556 / 15.1 = 1361 Methanol 9,770 / 6.4 = 1527 Ethanol 12,780 / 9.0 = 1420 Nitromethane 5,160 / 1.7 = 3035 I think from this you can see why methanol makes more power than gasoline. And it should really be obvious that nitro will make twice as much power as methanol (assuming you could run 100% nitro). I don't think the octane rating is as great as you seem to think, but results are results. The difference between the RON and MON octane numbers gives the SENSITIVITY of the fuel to changes in load, speed and temperature. Fuel RON MON Sensitivity Toluene 120 109 11 Iso-Octane 100 100 0 Methanol 106 92 14 Ethanol 107 89 18 Nitromethane not rated, but probably close to zero I know guys that run methanol in their dirt track Shivies and they run less timing than with race gasoline. I think this is due to a relatively low octane rating, particularly the MON numbers which is the more severe test and gives a lower number accordingly for most fuels. I'd watch for signs of detonation closely if it was my engine. But for pump fuel, it's better than the 93 premium. QuickD100: let me know how the optimum timing is for E85 vs. race gas if you have the data. I'd be interested in your test results.
Floyd Lippencott IV
Re: E-85 Update
[Re: mr_340]
#23735
04/16/06 10:30 PM
04/16/06 10:30 PM
Posts: 752 North Dakota
Jesse_Lackman
super gas
super gas
North Dakota
The reason you can put more E-85 fuel in (richer) is because the fuel is oxygenated, its oxygen content is higher than that of gasoline.
That is where the power increase comes from, more oxygen and the fuel to go with it = more power.
There is a power increase at the same CR, icing on the cake is its 100+ octane rating which allows a CR increase for an even bigger power increase.
Here in ND it has all the normal road tax on it.
