Mopar Performance air cleaner filter element? #2370577
09/14/17 10:07 AM
09/14/17 10:07 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Anyone know what appliation or part number air filter element that fits the cast Mopar Performance air cleaner.
Thanks,
nd65
Re: Mopar Performance air cleaner filter element? [Re: nd65] #2370718
09/14/17 01:50 PM
09/14/17 01:50 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The 13"? As I recall, 1968 road runner 383. 1972 Newport 400 or 440.
If I remember right it's the generic OEM size for the 60s/70s v8.
Rich H.
Esse Quam Videri
Re: Mopar Performance air cleaner filter element? [Re: nd65] #2370724
09/14/17 01:58 PM
09/14/17 01:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Mopar Performance air cleaner filter element? [Re: nd65] #2370787
09/14/17 03:50 PM
09/14/17 03:50 PM
WA
tman Offline
tman  Offline
WA
The standard one I remember is the Fram CA305. Check the dimensions out and see if this works.
http://www.autozone.com/external-engine/air-filter/fram-air-filter/246459_73461_6156
You are talking about this one?
http://www.jegs.com/i/Mopar-Performance/...ASABEgIPQPD_BwE
Re: Mopar Performance air cleaner filter element? [Re: tman] #2370913
09/14/17 08:32 PM
09/14/17 08:32 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Yeah tman, that is the MP unit. I think it is listed as 12 3/4" in diameter. That Fram looks close.
Thanks,
nd65
Re: Mopar Performance air cleaner filter element? [Re: nd65] #2370929
09/14/17 09:16 PM
09/14/17 09:16 PM
WA
tman Offline
tman  Offline
WA
Can try your local auto parts store and test fit. Here is cross reference if you can't find the Fram. Dimensions look very close.
http://www.airfilter-crossreference.com/convert/Fram/CA305
Re: Mopar Performance air cleaner filter element? [Re: nd65] #2372035
09/17/17 01:45 AM
09/17/17 01:45 AM
Earth
Rob C Offline
Rob C  Offline
Earth
I got my replacement filter from summit and they have many 12-3/4 hive to filters. Take measurements and order up!
