Page 6 of 17 < 1 2 4 5 6 7 8 16 17 >
#2370086 - 09/13/17 12:44 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: johnnycuda]
416challenger Offline
Loc: New Braunfels, TX
Is Randy Heinselman on Moparts? I talked to him a few time at San Antonio Raceway and Texas Motorplex?
#2370089 - 09/13/17 12:46 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
second 70 Offline
Loc: central il.
Talked with Farone yesterday and he said the first day it pushed out the cam plug on the back of the block and he was able to get that fixed but it was eating the bearings so it was turned way down for his run at Gateway. He was going to work on it all night and hope to make it today.
#2370154 - 09/13/17 02:28 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
fast68plymouth Offline
Loc: So. Burlington, Vt.
I didn't see Dart451's red RR make a run on Monday....... I guess they didn't make it??
68 Plymouth Satellite, 383, stock 906's, 3550lbs, 11.18 @ 123, 1.51 60' PRH is a Comp Cams W/D......competitive pricing on entire line. Custom cams available. ** dealer for Indy Cylinder Heads **
#2370166 - 09/13/17 02:40 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
SCATPACK 1 Offline
Loc: TN
What about JYRKI (the Swede) and his VIP. Is he running or out? Any times for him?
Old Geezer Racing
#2370170 - 09/13/17 02:48 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: SCATPACK 1]
Skeptic Offline
Loc: The Pale Blue Dot
He's out but working on the engine to try and finish (no pun) the week.
"Talking tough is easy when it's other people's evil and you're judging what they do or don't believe" Mike Cooley / Drive-By Truckers © Razor and Tie Music (BMI)
#2370177 - 09/13/17 02:54 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: Skeptic]
Rhinodart Offline
Rhinotruck
Loc: Round Lake Beach, Illinoisy
haha
JB Rhinehart, Realist
2018 Carlisle All-Chrysler Nationals July 13-14
Hurst Nationals held in conjunction includes
1968 Dodge Dart and Barracuda Hemi Super Stock Reunion!
Expo Center across from the main gate, register online!
#2370425 - 09/13/17 09:50 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: fast68plymouth]
furious70 Offline
Loc: IL
he made passes Mon/tue. I didn't get to see today's.
JYRKI didn't make runs today?
#2370465 - 09/13/17 10:44 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
Hemi_Joel Offline
Loc: Minnesota
Yes, we are out. Here is the story:
I was so confident that I would have the Coupe ready, I never tested the GTX since we finished the changes to it last fall. Everything I did on the coupe took longer than I planned. This was a complete build from a frame and body shell, so there was a ton of small things to fabricate, and the last 2 months was a major thrash. Jerico GTX helped a lot, and I’m very thankful for that. The last few days I did almost nothing but wiring. Finally saturday evening, 18 hours before we had to be in the tech line at Cordova, I drove the car for the 1st time. The fuel pressure gauge (with an isolator) was not working right, and upon an attempted restart it hydro-locked the engine. Too much pressure had blew fuel past the 8 needles and seats and filled the engine with gas. Then we pulled the plugs, cleared it, and one of the plugs wouldn't go back in the head right. I had to run a tap into the head, then got the plug back in. Got it started, and then it started spraying gas out of one of the fittings that connects to a carb. When I tried to tighten it, I could feel the threads pulling out. It has those stupid hard nylon washers under the fittings, and they just don’t seal well without a lot of torque. But you can only put so much torque onto threads in an old pot metal carb body. How could I safely race this car? There are so many unknowns to sort out. The test drive made it clear that this car still needed a lot of work. And there was no time to do it. I sat down and contemplated everything I had sacrificed to get to this point, and I didn't want to give up. I didn't mow my lawn, go to church, hang with friends or family for 2 months, or go to our car club events all summer, or back to the 50's, and I missed the eclipse. I was numb from fatigue and every fiber of my body hurt from the wiring thrash, especially my chest from laying across the door bar of the cage while working inside the car. The realization that this wasn't going to work out for 2017 slowly started sinking in, and it was hard to accept.
With 100% of the car unproven and untested, and no time to find parts or fix it, and not knowing what the next issue would be, it would be best to just stay home. I felt a small bit of relief that it was over, and I could rest. (haha)
Then I wandered over to the corner of the shop, where the GTX sat. I hadn't really even looked at it in a year. It hadn't been on the track since 2010 when I blew up the motor at a FAST race. The new combination with the slicks, caltacks, quicktime bell, fuel system, etc was untested. But I should take a closer look, I figured. So I started moving junk out of the way, and Jeff joined me. 15 minutes later it was out in the middle of the shop and an hour later it was running! OK, we are going to Drag Week 2017 after all!
Packing tools and supplies, my brain was in a fog from lack of sleep in the last few days. I couldn't even think of what I should bring. But we were on the road for Cordova about 12:30 am. After 2 hours of driving I had to stop and sleep for a few hours, then we continued on. A 20 mph headwind slowed the progress of the old 1st gen Cummins hauling the big camper and the trailer, and put it in fuel guzzle mode. We finally got to the track at about 12:25 on Sunday, unloaded the car, and made it into the tech line at 12:45, 15 minutes before the cut-off. By the time I got thru tech about 6 hours later, the staging lanes were closed for the day, so no test passes for me. I spend most of the time in line fixing blinkers, figuring out the fuel pump switch, and sitting in the car resting. Jeff installed the seat belts that we had robbed from the coupe before we left. I didn't get out into the lanes and meet and greet and ogle the cars like I usually do. But I did talk to a bunch of Drag Week friends who came by the car. It was great to see them all, and helped wake me out of my stupor.
After tech, we found a water hose behind the mens room and used it to wash the GTX. It was filthy from a year of storage without its cover. (my bad). Then out for dinner in town, (chauffeured in a Lincoln by my friend Kevin) and then back to the camper for the night. I slept like a log.
Monday morning, Jeffs alarm didn't go off because his battery was dead. He had plugged the charger into an inactive outlet. So we got up late. I was thinking the drivers meeting was at 9, but it was at 8. So a last minute rush happened to pack the car and get out of the camper and trailer.
My first pass, the car laid down right after launch, then picked up, then died, then restarted. I aborted the pass and motored easy down the track. Also, the GTX pushed to the right, I had to correct a lot.
Back in the pits, we checked the fuel pressure and it was fine. Maybe a needle and seat is sticking from a year of dormancy? So I pulled the carb tops and all 4 bowls of the dual Carter AFB's were well stocked with 112 octane. If the fuel is OK, then it must be ignition. How shall I diagnose this? (At this point I was discovering how poorly I had selected my tools and supplies when packing) But after another hour of messing around, And Jeff adding some preload to the right caltrack to try and make the car go straight, we were ready for another try. I got into the staging lanes 10 minutes before they closed for the day. I dumped the clutch at 4000 RPM, and it felt strong! The tire spun a bit, then grabbed. With the force of the launch pushing my head back, the tach (with integral shift light, which is mounted too low) disappeared from my field of view. By the time I was able to glance down, the shift light was on, for I don’t know how long, so I grabbed second. The car lurched forward at the shift, and the 2-3 shift went well except the shift light never went off, but I was too busy correcting to the left to pay attention to it. The car was going right, towards the wall. It was definitely out of the groove as I passed the 1/8 mile, so I aborted the run. The time slip showed a 1.59 60’, and a 7.004 1/8th. I was happy with that for an initial test pass, it showed a lot of potential. The pit stop gas cap was open when I got back to the pit. Later I learned that it dumped fuel on the track like the Exon Valdez into Prince William sound. Reviewing the in-car video, we saw that the rpm never dropped on the 3-4 shift. The clutch was on an initial, break in setting with maximum spring pressure and no counter weight. The cure for the 4th gear slippage is counterweight on the levers. Due to the rush last year, I didn’t have time to order a bellhousing with a window, I had to use an off the shelf unit. Adding weight to the clutch meant pulling the trans, and I didn’t have nearly enuff tools. I was talking about quitting, but Scott Abbot came by and gave me a pep talk and offered to help with tools and stuff. That got me motivated to find a way. When I looked in thru the clutch fork hole of the Quicktime scattershield, I figured there was a slight possibility I could add a bolt and nut to each lever without pulling the trans by working thru the fork hole, but unfortunately I could also see the levers had been hitting the inside of the bellhousing. The ends were scuffed and bent. Adding weight would only make it worse. (lesson: Quicktime bellhousings do not have sufficient clearance for an adjustable clutch) The only solution I could think of would be swap in a Lakewood bellhousing. To find one and install it could be 5 or 10 hours. It just wasn’t going to happen on DW17, when we still had a 6+ hour drive to St. Louis. So reluctantly, I threw in the towel, and we loaded up and slunk home.
Good luck to all my fellow drag weekers who are still in. I will definitely be back for 2018, much more prepared!
#2370468 - 09/13/17 10:46 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
Hemi_Joel Offline
Loc: Minnesota
Our Drag Week pit at Cordova
Trunk MOnky working
#2370566 - 09/14/17 07:25 AM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
squirrel Offline
Loc: AZ
Spectacular effort, Joel! Sorry for the outcome, but you sure gave it your best. so glad I got to talk with you for a while Sunday
#2370778 - 09/14/17 01:29 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
Hemi_Joel Offline
Loc: Minnesota
Thanks Squirrel. Writing the story helped me decompress and relax. You make drag week look easy. But I know it's not. Good luck for the rest of the event and safe travels home.
#2370782 - 09/14/17 01:40 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: Hemi_Joel]
Rhinodart Offline
Rhinotruck
Too bad you didn't make it to Byron, I have a nice Lakewood bell sitting around doing nothing. frown
#2370786 - 09/14/17 01:47 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
Hell of an effort Joel! Hope you get that badazz coupe sorted out for next year!
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan SXT...baby hauler
#2370864 - 09/14/17 04:45 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: Hemi_Joel]
MR_P_BODY Offline
Loc: Romeo MI
Thats a major bummer Joel... sorry to hear that
wave
W-9 8.94 @ 151 NOW ON E-85
Mike "Raff"...(180)Watching over us
CAR IS FOR SALE
#2371000 - 09/14/17 09:23 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MR_P_BODY]
Rhinodart Offline
Rhinotruck
Billy, don't know if you noticed a guy in a Ram pulling a trailer with a bunch of engines in it waving frantically at you going the opposite direction after you got through Antioch, IL heading back to Byron, that idiot was me! wave Saw the Gremy about 5 miles before you too. Hope you had a good day today. luck
#2372450 - 09/17/17 09:54 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
squirrel Offline
Loc: AZ
fun race this year!
We're still on our way home.
#2375593 - 09/23/17 04:24 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
I have a question about the late model cars running, in some instances, well below the 11.50 cut off before needing a roll bar rule.
I know at one point there was a lot of banter on the net about interpreting the wording that allowed "stock" late model cars to run quicker than that and not require the roll bar.
However, "stock" Hellcat Chargers don't run 10.0's...... Nor do Caddys and Mustang 5.0's run high 10's.
Did those cars have roll bars?
If not, I'd be interested to see how that rule is interpreted for the late model entries.
I also noticed that during the DW staff Hellcat challenge races that no one was wearing a helmet.
Is the helmet rule not 13.49 anymore?
#2375602 - 09/23/17 04:50 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: fast68plymouth]
MoparBilly Offline
Loc: Phoenix, AZ
Jim and Kim made it. They killed Drag Week, didn't look like rookies at all. Guess all that Moparts advice paid off!
C'mon Fast, This ain't your first rodeo...
The first rule of Drag Week is we don't talk about the Drag Week rules. Track officials are human beings too you know, and human beings like free pizza and beer...I'm not saying, I'm just sayin'
At DW16 there was a little kick back on the late models at St Louis, but not anywhere else. This year I don't think it was an issue but there were "rumblings and discussions".
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
#2375605 - 09/23/17 04:59 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: MoparBilly]
Don't ask, don't tell??
A secret hand shake? And maybe some window tint?
Well...... Except for the fact that Freiburger pointed out numerous times during the live feed how the cars could only run as quick as they were legal to run.
Correction......they could only turn in a time slip that was no quicker than they were legal to run.
I was watching the live feed replays later at night, and I think on each day other than the first......... It seemed like there were a few cars running that I hadn't recalled seeing the day before.
Its entirely possible I had nodded off and missed them the day before(obviously).
I did see the Jim and Kim show on day 3 and on, so I musta just missed the run on day 2.
Nonetheless, I'm looking to forward to reading the official MoparBilly "Drag Week 2017: Hey, we're starting to get the hang of this" thread.
#2375649 - 09/23/17 06:12 PM Re: Hot Rod Drag Week 2017: The Experience. [Re: fast68plymouth]
JERICOGTX Offline
Loc: MN
popcorn
I too am eager to read all about this years adventure, since we packed up and left on Monday.
69 GTX 68 Road Runner
25,081 Registered Members
185,726 Topics
Anyone make the OEM Abody Power Steering pump
by PAULS_340
Yesterday at 11:12 PM
Final thoughts about Old Bridge Township Raceway Park
by DragtimeDodge
Yesterday at 11:08 PM
GO EAGLES
by A12
Yesterday at 10:57 PM
Repair panel for upper fender area search inquiry
by Billy
Yesterday at 10:48 PM
