Shell zinc additive at Autozone #2370335
09/13/17 09:05 PM
09/13/17 09:05 PM
GMP440 Offline OP
GMP440  Offline OP
Saw this last week at Autozone.
Has anyone tried this zinc additive?
Re: Shell zinc additive at Autozone [Re: GMP440] #2370339
09/13/17 09:09 PM
09/13/17 09:09 PM
Kirkland, Washington
Pacnorthcuda Offline
No linky to zinky.
Re: Shell zinc additive at Autozone [Re: GMP440] #2370341
09/13/17 09:16 PM
09/13/17 09:16 PM
GMP440 Offline OP
GMP440  Offline OP
Shell zinc additive
Re: Shell zinc additive at Autozone [Re: GMP440] #2370344
09/13/17 09:21 PM
09/13/17 09:21 PM
I've never seen that one. Odd that it has such a 'retro' look to it!
Google it, might be a good product, Shell knows what they are doing..
Re: Shell zinc additive at Autozone [Re: Pacnorthcuda] #2370349
09/13/17 09:37 PM
09/13/17 09:37 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I read a good article by a Shell engineer that said to much zinc will eat up parts, especially copper.
Re: Shell zinc additive at Autozone [Re: 71birdJ68] #2370352
09/13/17 09:46 PM
09/13/17 09:46 PM
IN
ahy Offline
ahy  Offline
IN
I tried to look it up but AZ site was offline. In general, a FT cam likes 1200-1500 PPM zinc. Standard new(er) car oil has 600 PPM. Need to do the math based on the additive specs to determine if it can get "standard" car oil into the 1200 - 1500 PPM range with the additive.
Re: Shell zinc additive at Autozone [Re: Pacnorthcuda] #2370353
09/13/17 09:47 PM
09/13/17 09:47 PM
GMP440 Offline OP
GMP440  Offline OP
Shell additives.
Re: Shell zinc additive at Autozone [Re: GMP440] #2370354
09/13/17 09:47 PM
09/13/17 09:47 PM
BDW Online content
BDW  Online Content
Seems to be low concentration, 12oz to only do 5qt?
Go to Advance Auto and get the Lucas zinc, 16oz is good for 3 oil changes.
Re: Shell zinc additive at Autozone [Re: BDW] #2370361
09/13/17 10:05 PM
09/13/17 10:05 PM
GMP440 Offline OP
GMP440  Offline OP
Found info on the concentration. Shell claims 2000ppm.
Here is the link.
https://www.shellx100oil.com/faqs
Re: Shell zinc additive at Autozone [Re: GMP440] #2370365
09/13/17 10:14 PM
09/13/17 10:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Here is the link.
Nope, that's for their oil
Try this
https://www.shellx100oil.com/product-page/shell-x-100-zinc-additive-12-oz no data though
Don't be the exception.
Re: Shell zinc additive at Autozone [Re: Supercuda] #2370381
09/13/17 10:34 PM
09/13/17 10:34 PM
GMP440 Offline OP
GMP440  Offline OP
Sorry. My bad. I should have spotted that. Maybe do a phone call
or email to their people.
Re: Shell zinc additive at Autozone [Re: GMP440] #2370384
09/13/17 10:36 PM
09/13/17 10:36 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Thanks for posting this info.
Always good to have options. thumbs
Re: Shell zinc additive at Autozone [Re: 71birdJ68] #2370401
09/13/17 10:57 PM
09/13/17 10:57 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Go to General Aviation News web site and look for a red plane rolling over on its back which is the July 20th issue No, 14, and read the article by Ben Visser, which is on page 12, it's very Informative.
Re: Shell zinc additive at Autozone [Re: GMP440] #2370473
09/14/17 12:51 AM
09/14/17 12:51 AM
Thanks for the info thumbs
so I guess I'll keep the silver and copper internal parts to a minimum grin
and the ppm to 1400.
link to above page
Re: Shell zinc additive at Autozone [Re: GMP440] #2371198
09/15/17 01:22 PM
09/15/17 01:22 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
So former Shell Oil engineer Ben Visser's article in July 20 2017 General Aviation News page 12
leads to the conclusion that
a bit less than
1400 ppm of ZDDP
is optimum for wear.
But his comments on non-zinc detergents in some automotive oils burning up and leaving ash deposits that cause pre-ignition pinging also trigger some thoughts.
Which automotive rated oils have the lowest levels of ash deposits?
Re: Shell zinc additive at Autozone [Re: 360view] #2371209
09/15/17 01:55 PM
09/15/17 01:55 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
He was talking about putting auto oil in an aircraft engine. Mobil 1 used to make a aviation oil, but their formula didn't mix well with the lead in the fuel, and they had to buy a bunch of ruined engines, so Mobil 1 doesn't make a aviation oil now. The jest of the story is the amount of zinc that is used is very important.
Re: Shell zinc additive at Autozone [Re: GMP440] #2371263
09/15/17 03:48 PM
09/15/17 03:48 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Would .14 on a spec sheet be 1400? I see Valvoline VR1 has .14 listed. https://sharena21.springcm.com/Public/Do...10-ac162d889bd3
Re: Shell zinc additive at Autozone [Re: GMP440] #2371270
09/15/17 03:54 PM
09/15/17 03:54 PM
MI_Custumz Offline
MI_Custumz  Offline
Lucas Hot Rod oil 10W30 is 2100.
Re: Shell zinc additive at Autozone [Re: 360view] #2371324
09/15/17 05:36 PM
09/15/17 05:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
a bit less than
1400 ppm of ZDDP
He was talking about using AUTOMOTIVE OILS in an AVIATION engine and why that may be a bad idea.
He goes into how the 1400 PPM level may not be RELEVANT for AUTOMOTIVE engines because they are designed and built DIFFERENT than an AVIATION engine and are not as susceptible to the problems an AVIATION engine is with high levels of ZDDP.
But hey let's take away whatever from wherever.
Re: Shell zinc additive at Autozone [Re: GMP440] #2371625
09/16/17 09:55 AM
09/16/17 09:55 AM
USA
3
360view Offline
360view  Offline
3
USA
Sometimes it is good to read things 3 times.
So I did.
He discusses engine lube oils with emphasis on wear additives and detergents.
He believes his readers should learn the practical and legal aspects of both aviation and automotive engine oils.
He goes into detail about ZDDP and its concentration.
He brings up the interesting topic of ash from oil detergents causing pre-ignition.
