Re: Shell zinc additive at Autozone
[Re: GMP440]
#2370341
09/13/17 09:16 PM
09/13/17 09:16 PM
Posts: 1,637 Florida
GMP440
[Re: 360view]
#2371209
09/15/17 01:55 PM
09/15/17 01:55 PM
Posts: 4,445 Morristown Tn.
71birdJ68
Morristown Tn.
He was talking about putting auto oil in an aircraft engine. Mobil 1 used to make a aviation oil, but their formula didn't mix well with the lead in the fuel, and they had to buy a bunch of ruined engines, so Mobil 1 doesn't make a aviation oil now. The jest of the story is the amount of zinc that is used is very important.
[Re: 360view]
#2371324
09/15/17 05:36 PM
09/15/17 05:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
So former Shell Oil engineer Ben Visser's article in July 20 2017 General Aviation News page 12 leads to the conclusion that a bit less than 1400 ppm of ZDDP is optimum for wear.
But his comments on non-zinc detergents in some automotive oils burning up and leaving ash deposits that cause pre-ignition pinging also trigger some thoughts.
Which automotive rated oils have the lowest levels of ash deposits? He was talking about using AUTOMOTIVE OILS in an AVIATION engine and why that may be a bad idea. He goes into how the 1400 PPM level may not be RELEVANT for AUTOMOTIVE engines because they are designed and built DIFFERENT than an AVIATION engine and are not as susceptible to the problems an AVIATION engine is with high levels of ZDDP. But hey let's take away whatever from wherever.
