#2360682 - 08/27/17 03:33 PM Borgeson Box wants P/S fluid, P/S pump wants ATF...
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
Has anyone run into a situation where their power steering box and power steering pump call for different fluids?
From what I understand, Borgeson only calls for power steering fluid in their boxes. Alternatively, my GM-type power steering pump only wants ATF.
I am up to 200 miles on my car and have only run RedLine P/S fluid in it and cannot seem to get rid of the pump whine. I am thinking I will try swapping over to ATF and see how that goes...what have you used?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - Build page -> https://www.facebook.com/GoodysGotaHemi<-
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 BMW X1, 2016 Subaru WRX
#2360716 - 08/27/17 04:53 PM Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda]
BigBlockMopar Offline
Loc: The Netherlands
ATF in mine.
Now my Borg box leaked like a sieve the moment I started the engine, but was due to a pinhole in a weld.
A few strikes with a punch fixed that.
BigBlockMopar.com
#2360867 - 08/27/17 08:59 PM Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda]
MarkM Offline
Worthy
Loc: USA, MI
Call Scott at Bergman.
'87 Fifth Avenue: 512 low deck roller / 518 / 8.75
#2360898 - 08/27/17 09:49 PM Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: BigBlockMopar]
5.7L Hemi, 6spd
Loc: Texas
Originally Posted By BigBlockMopar
ATF in mine.
Ok, there's one Borg box with ATF in it that's lived. Good news!
#2361576 - 08/29/17 07:20 AM Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda]
5.7L Hemi, 6spd
Loc: Texas
Bump, anyone else using ATF in a Borgeson box?
Thanks!
#2361594 - 08/29/17 08:36 AM Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda]
Jerry Offline
Loc: Warren, MI
atf will be fine.
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
#2368440 - 09/10/17 06:00 PM Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda]
BergmanAutoCraft Offline
Loc: Long Island, NY USA
Either way is fine, but synthetic PS fluid is best. If you have a hydroboost, atf is poison.
#2368458 - 09/10/17 06:39 PM Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: BergmanAutoCraft]
ahy Offline
Loc: IN
In general, older style PS pumps which ran ATF as original seem to do fine on power steering fluid. I would not worry about the pump with either.
#2428931 - 01/04/18 12:47 PM Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: BergmanAutoCraft]
Moparmatty Offline
Loc: Hanover, Ontario, Canada
Why is ATF poison to Hydroboost setups? Dodge diesel 4x4 trucks use ATF+4 in their power steering systems.
Matt Tebbutt
Ontario, Canada
#2429220 - 01/04/18 07:49 PM Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: BergmanAutoCraft]
Skeptic Offline
Loc: The Pale Blue Dot
The bus yard I work @ has 30 small busses- Fords and GMs over a span of 30 model years, they all have Hydroboost and all use ATF- factory fill.
"Talking tough is easy when it's other people's evil and you're judging what they do or don't believe" Mike Cooley / Drive-By Truckers Razor and Tie Music (BMI)
25,381 Registered Members
191,067 Topics
440 STROKER KIT
by rickb67
07/16/18 11:54 PM
How do you read the date code of Polyglas tire?
by PAULS_340
07/16/18 11:10 PM
New truck
by 6pakdakota
07/16/18 10:45 PM
transmission pan cast aluminum vs stamped steel
by mopar12345
07/16/18 10:15 PM
