A pilar gage mount #2368033
09/09/17 09:13 PM
09/09/17 09:13 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
I have a 1999 3500 that I am mounting gages in how are you mounting the gage A pillar to the factory A pillar screws ,glue rivet etc? and where are you running the wires through the fire wall ? thanks
Re: A pilar gage mount [Re: dragon] #2368131
09/10/17 02:04 AM
09/10/17 02:04 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
most gauge pods overlay the existing A pillar and attach with small plastic push pins. There's a plate where the clutch pedal linkage would go through the firewall so if you have an auto that's a handy spot. I have the Xmonitor gauge on my 01. module is under the dash and there is one wire going to the display mounted on the lower A pillar. Easy and non intrusive install.
Re: A pilar gage mount [Re: dragon] #2372790
09/18/17 04:07 PM
09/18/17 04:07 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Check Geno's Garage - they have some nice set ups for pillar gauges . . .
