#2367291 - 09/07/17 11:32 PM MSD Hemi 6 box on 6.4
8secDart Offline
Loc: Salisbury North Carolina
Hope someone can help. I have called everyone under the sun and no one can answer why the MSD Hemi 6 box will not work on the 6.4 in a carb form.
My guess is the tone ring is different from the early 08 down 5.7?? Can a early 5.7 tone ring be made to work on the 6.4??
Thanks guys
#2367307 - 09/08/17 12:09 AM Re: MSD Hemi 6 box on 6.4 [Re: 8secDart]
sycboi Offline
Loc: Norwalk, Ohio
You'd need to use the early 6.1 tone ring because of it's 4 bolt mounting. The 5.7 only uses a 3 bolt mounting configuration. I am running an '08 6.1 crankshaft in my 5.7 and it has the 32 tooth reluctor you're after to enable the box to work with it...
SuperBeast
An enforcer for the Mopar Mafia!
#2367391 - 09/08/17 09:43 AM Re: MSD Hemi 6 box on 6.4 [Re: 8secDart]
MattW Offline
Loc: Ontario Canada
Thanks guys
Simple solution is K1 part # TR 32 It's a 4 bolt design and a 32 tooth reluctor wheel. Molnar has them also.
I believe the MSD 6 will not recognize the 6.4 64 tooth count and will not work.
Matt
Edited by MattW (09/08/17 09:46 AM)
#2367394 - 09/08/17 09:55 AM Re: MSD Hemi 6 box on 6.4 [Re: 8secDart]
Hemijoejr Offline
Loc: NJ, USA
The Hemi 6 will not work on a 6.4L due to the tone wheel. To use the Hemi 6 you would need to change the tone wheel to a 6.1L wheel or according to FAST their XIM can be used in a stand alone carb application and can be setup to use the 6.4L fine tooth wheel. You will still need to lock the phaser in the timing chain.
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
25,495 Registered Members
193,141 Topics
74 Dart
by Neil
09/25/18 02:16 PM
66 Cornut 500
by Neil
09/25/18 02:13 PM
Carb switch or not...
by TonyS451
09/25/18 02:09 PM
What happened to the steve juliano post?
by rdrnr6970
09/25/18 02:04 PM
